Silvertone 1434 3 wire conversion
Discussion in 'Glowing Bottle Tube Amp Forum' started by AA eron, Oct 6, 2017.
  1. AA eron
    AA eron Tele-Meister
    142
    Jul 18, 2013
    Ann Arbor MI
    See the pen drawing? Compare to the schematic below. Is this what I should do for a 3 wire cord? Thanks.
  2. Andy B
    Andy B Tele-Afflicted Silver Supporter
    Mar 16, 2003
    Colorado
    Yes the black wire to the switch, the white wire to the transformer.
  3. robrob
    Dec 29, 2012
    United States
    If your power cord isn't color coded correctly in the US the narrow plug blade is hot to the fuse and switch, the wide blade is neutral to the transformer and the center ground connector is bolted to the chassis. You can use a multimeter's continuity "beep" function to confirm the wires and blades.
    If your plug doesn't have wide and narrow blades then look how it plugs into the wall and the wall socket will have narrow and wide blade slots.
    BobbyZ likes this.
  4. AA eron
    142
    Jul 18, 2013
    Ann Arbor MI
    Thank you both so much. I'll work on it this weekend.
  5. corliss1
    corliss1 Tele-Afflicted Gold Supporter
    Sep 13, 2008
    Lansing, MI
    Hey hey - I'm up in Lansing. If you get stuck or have issues feel free to send me a message.
  6. AA eron
    142
    Jul 18, 2013
    Ann Arbor MI
    Corliss1- thanks for the offer! I'll def get ahold of you if I get stuck.
