Silvertone 1357 1954 Danelectro influenced Low Budget Lo-Fi build.
Discussion in 'Tele Home Depot' started by guitarbuilder, Feb 14, 2019.
  1. guitarbuilder
    Thanks. With the pickguard on top, the router bit would need to be a flush trimmer and the pickguard material would be right where that gap is between the cutter and the bearing. Remember the underside of the rout is undercut for the pickguard plate. If it weren't for the undercut part, that process would sure work though.
    I am kind of doing this on the fly and almost decided to make the pickguard/pickup access a little bigger like I saw in another picture today. Here:
    http://rover.ebay.com/rover/1/711-5...0001&campid=5338148343&icep_item=272281388200
  2. crazydave911
    East Tennessee
    That would be appropriate though not historically accurate,but who cares lol
    guitarbuilder likes this.
  3. guitarbuilder
    Some random orbit sanding on the edges and a roundover before the jack hole drilling:
    Barncaster and Ekko like this.
  4. guitarbuilder
    Drill some holes. Locate the jack hole. Make a dent for the drill.
  5. guitarbuilder
    Drill it on the drill press with 7/8 Bormax forstner bit ( Available at woodcraft and worth the higher price).
  6. guitarbuilder
    Next I drilled wiring channels through the neck pocket to the bridge pickup cavity. I made a dent a bit above the cavity on the centerline of the body which is also the glue line.
    Drilled it through. I elevated the back edge slightly on a 1/4" piece of plywood scrap so that it came out lower.
  7. guitarbuilder
    Last thing was to drill from the jack hole into the bridge pickup cavity. I used long aircraft bits for these wiring holes ( Irwin brand).
    Ekko, Barncaster and CraigB like this.
  8. guitarbuilder
    Slowdown while I'm waiting for the rabbeting bit. I sanded about 1/16" off the bottom edge to achieve a flat similar to the originals. While I was at it, I sanded the top to 120 to get rid of the snipe and pencil marks.
  9. guitarbuilder
    Artsy unintentional B&W shot
  10. Barncaster
    Northern California
    Sweeeet!
  11. guitarbuilder
    Thanks. I am having fun with this one. I snagged a Dano bass bridge for maybe the next project up.
  12. guitarbuilder
    Sometimes you feel like a nut, sometimes you don't.
    angle aluminum...cut a hunk off, then cut another hunk off
  13. guitarbuilder
    sanded it down to a nut shape....
  14. guitarbuilder
    Located the center for the screw hole and drilled it, then drilled with a larger bit to countersink the hole
    Ekko and Barncaster like this.
  15. guitarbuilder
    Drilling the hole presented a problem because the drill chuck would interfere with the peghead with a short drill. I found a brass rod I had and machined the end to do some drilling. I sanded 4 facets on the end. It worked out fine. I drilled the hole and found a short screw that works, although I think I want a flat head for this.
  16. Mat UK
    Mat UK Tele-Afflicted Silver Supporter
    London, UK
    I know you’re not there yet. But how easy do you find cutting and filing the slots in metal? Is it just a matter or taking more time?
  17. guitarbuilder
    I cut it pretty close to final dimensions so I'm hoping it won't be too bad. I may use my old files so I don't mess up the Hoscos ones.
  18. Mat UK
    London, UK
    Maybe it’s time to crack out the welders tip cleaners - I imagine they’ll work a treat on Aluminium ;)
    I’ll be watching closely. Might have a go at some copper...
  19. guitarbuilder
    I figure I'll use a saw to make some kerfs to be widened from files.
    Mat UK likes this.
  20. guitarbuilder
    The Yoniko rabbeting bit came today.
    https://www.amazon.com/dp/B00V7AP8JK/?tag=tdpri-20
    I routed the rear cover recesses and also countebored the neck screw washers so they wouldn't stick out so much. The bit came in a nice corregated box. It was packed in a plastic/vinyl bag but didn't have protective plastic on the cutters. Must be a cost saving thing...:)
    Barncaster, zippofan, Ekko and 2 others like this.
