Short Scale Resonator Bass
Discussion in 'Other Guitars, other instruments' started by Zepfan, Jun 5, 2016.
  1. Zepfan
    Zepfan Poster Extraordinaire
    Nov 30, 2013
    Horn Lake, MS
    Thanks. They are basically a neck bolted to another long piece that goes through the ends of a tin or box cause the tin or cigar boxes can be flimsy. The box or tin gives some influence on the overall tone of the instrument.
  2. Deneb
    Deneb Tele-Afflicted Silver Supporter
    Feb 16, 2011
    Ukraine, Dnipro
    Now it is clear. I will follow the progress of the build of this bass.
  3. Doug 54
    Doug 54 Poster Extraordinaire Silver Supporter
    Dec 12, 2004
    Ohio
    So
    C
    O
    O
    L
  4. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    Got to go shopping this weekend for the aluminum flat stock for the fretboard, brass bolt for the nut, steel bolt for the bridge and the eye bolts for the tuners. May use a metal framing bracket at the tuner end of the through piece to add some strength and keep that end from bowing under string pressure.
  5. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    Thanks, glad you like it.
    Doug 54 likes this.
  6. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    Didn't go shopping, ran out of money. Have to wait til next month to finish.
    I did get the back of the neck shaped, just need to go over it with sandpaper.
  7. richa
    richa Tele-Afflicted Ad Free Member
    Apr 23, 2016
    At first I thought that was a skunk stripe. :) I like it. You going to leave the stripe or sand it natural?
  8. RevMike
    RevMike Poster Extraordinaire
    Jul 15, 2004
    Raleigh, NC
  9. Doug 54
    Dec 12, 2004
    Ohio
    If I send you some euros, will you finish it?
    Ahhh, shoot!
  10. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    Not sure yet, the dark stain looks nice with the tin.
    Euros, What part of Ohio are you in?:p
  11. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    Got my tuners yesterday.
  12. richa
    Apr 23, 2016
    Now there's some serious hardware. Looking forward to seeing them in action.
  13. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    Their 5/16ths". I thought they would handle bass strings okay. The slot in the end piece is just big enough for 3 on one side and 2 on the other.
  14. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    A member here gave me 3 humbucker pickups. 2 of the buckers were actually single coil pups with 2 magnets stuffed in a double coil housing. One was apart already and I thought about taking the other one apart and making a real double coil pickup out of the 2. The other one was encased in epoxy and would be destroyed trying to get it apart. So I put the other pup together, mounted them stacked in the middle position and wired them together in series like one big humbucker. Looks kinda ugly, but it doesn't matter because they'll be under the top lid and unseen.
  15. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    Here's a few pics.
  16. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    The 2 buckers were low output, 5.7k and 5.3k. So now I'm getting 11k out of them.
    richa likes this.
  17. richa
    Apr 23, 2016
  18. 2after909
    2after909 Tele-Meister
    483
    Dec 23, 2010
    brooklyn, ny
    wow, clever use of those pickups!
  19. Zepfan
    Nov 30, 2013
    Horn Lake, MS
    I used P Bass pups in a CBG. So I thought, why not guitar pups in a Bass?:cool:
  20. Revv23
    Revv23 Friend of Leo's
    Oct 9, 2009
    Michigan
