Short knobs to solve selector switch interference?
Discussion in 'Telecaster Discussion Forum' started by Slim Chance, May 23, 2019.
  1. Slim Chance
    Slim Chance Tele-Holic
    Beltway, USA
    So the other day I briefly held a Deusenberg and noticed that it had very nice knurled knobs about half the height of Telecaster knobs. My first thought was that this could be a solution to easier access to the Tele selector switch. I believe that the Deusenberg knobs would sit below the switch making it easier to grab. Might necessitate new pots, but still. . . Whaddya think?
    brookdalebill likes this.
  2. RodeoTex
    Nueces Strip
    Very cool, but where to find?
  3. guitartwonk
    guitartwonk Tele-Meister
    People's Republic of Blighty
  4. SecretSquirrel
    SecretSquirrel Friend of Leo's Ad Free Member
    PNW USA
    I like the idea. In fact, I use smaller knobs on my control plate for just that reason (I also just tend to prefer smaller knobs). The switch location always seemed crowded to me.
  5. cleanheadsteve
    cleanheadsteve Tele-Meister
    Arkansas
    if i'm using plastic knobs, i often cut part of the bottom off for strats and teles. helps to keep my picking hand from hitting them
  6. VintageSG
    Yorkshire
    Those knobs look neat. May need to Dremel the shaft a little, but still, pots are cheap. I use a Strat switch tip, which overcomes switching anxiety for me.
  7. guitartwonk
    Same here with the switch tip. This one's a 5-way switch so it seemed appropriate... [​IMG]
    Sent from my Phone using Tapatalk
  8. brookdalebill
    Austin, Tx
    Cool!
    G&L ASAT knobs are also smaller/lower profile.
  9. boris bubbanov
    New Orleans, LA + in the
    I'd just do a custom control plate, with the hole for the volume pot skootched down the plate. I also move the tone pot hole up about half that amount.
  10. boris bubbanov
    They are? I don't see it.
  11. brookdalebill
    Austin, Tx
    Here’s a pair on my Cabronita, perhaps G&L have changed knob sources.
    They are off an ASAT Bluesboy I had briefly.
    I’d say they are 40% smaller.
  12. boris bubbanov
    Yeah. Look at how little distance from the set screw to the top of the knob. That is different.
  13. Larmo63
    Larmo63 Tele-Afflicted
    Timbuktu, Earth
    It's. Only. 2 knobs. 1 switch.
    Mike Simpson and Norris Vulcan like this.
  14. KG7IL
    KG7IL TDPRI Member
    Eatonville, WA edge of cowtown
    MrHamburger likes this.
  15. horseman308
    horseman308 Tele-Holic
    US
    Yeah, buddy. I know this is off topic, but the Mike Campbell sig Dusenberg is gorgeous.
    Sent from my SM-G930P using Tapatalk
    guitartwonk likes this.
  16. jvin248
    jvin248 Poster Extraordinaire
    Lions & Tigers oh Mi !
    This was my solution... Got it from Bill Kirchen.
    SAguitar, hellopike and brookdalebill like this.
  17. TokyoPortrait
    TokyoPortrait Tele-Holic
    Tokyo, Japan
    And from his Dusenberg artist page, it appears he's in another band called the Dirty Knobs. Seems apropos the thread...
  18. Ess Eff
    Ess Eff Tele-Meister
    Take care that the knob goes down far enuf to cover the nut. Many will not, and will look ugly. It is quite a job to find good fitting Tele knobs that are low profile.
    All my Teles get the Allparts cupcake knobs, which are about 4mm lower, slightly wider and fit perfect.
    They don't completely solve the switch issue but I use different control plates for that. I have found a supply of plates that have an extra 5mm space and with the low profile knobs it works out pretty good.
  19. MrHamburger
    MrHamburger Tele-Holic
    Portlandia
    KG7IL likes this.
  20. guitartwonk
    I had the opposite problem. Recently bought an Ibanez S670. When the knobs are pushed down as far as they go they brush against the finish, which is not cool.
    It was annoying me, so I packed them out with a couple of washers. Problem solved.
    I also didn't like the bridge pickup but that's another story...
