SF Champ day and an old Thomas Organ Crybaby too
Discussion in 'Glowing Bottle Tube Amp Forum' started by Ringo, Aug 12, 2017.
  1. Ringo
    Ringo Poster Extraordinaire
    Mar 16, 2003
    Memphis TN
    Picked up a SF Champ today, I am thinking it's mid 70s as it has the glued in baffle w separate grill cloth frame.
    It was pretty dirty and has a lot of wear and tear.
    But I cleaned it up some and it's better.
    I plugged it up and it works and sounds good but the speaker is bad, not real loud and it is buzzing some.
    It has what looks like a factory alnico speaker.
    So I'll pull the chassis, clean it up and clean up the cabinet some more, and find a speaker.
    It's been a while but the last Champ I bought didn't have a speaker, I put one of the Jensen MOD 8" 4 ohm speakers in that one and it had a good sound.
    So maybe one of those, or something else.
    And yesterday I got an old Thomas Organ Crybaby, made in Chicago, has the stack of dimes inductor.
    It works and sounds very good, I will eventually do the DPDT switch for true bypass, I figured the pot would be bad but it seems fine, so I will use the factory pot until it dies.
    And it came with a Crybaby manual! I've never seen one before, pretty cool.
    Champ before and after cleaning
  2. Ringo
    Mar 16, 2003
    Memphis TN
    CoyotesGator and TMoxness like this.
  3. AlbertaGriff
    AlbertaGriff Tele-Meister
    387
    Mar 2, 2016
    Alberta, Canada
    Nice, congrats! I picked up a 77 Vibro Champ earlier this year and stuck a WGS G8C in it. Great speaker - meant for this amp.
  4. Riffraff12571
    Riffraff12571 Tele-Holic
    763
    Sep 30, 2011
    Dutchess County NY
    Congrats. I have a mid '70s Thomas Organ CryBaby too. I got it new when I was just a 14 year old kid. MAN was that a long time ago....LOL.
    It's a great sounding wah.
  5. Dacious
    Dacious Poster Extraordinaire
    Mar 16, 2003
    Godzone
    Weber Sig alnico ribbed. Awesome match in my SFVC. Never should have sold that amp...
  6. Ringo
    Mar 16, 2003
    Memphis TN
    I cleaned up the Champ yesterday, from the pot dates it a 1975 model.
    I had ordered a replacement speaker and it came in Friday, Line 6 labeled ceramic 15 watt 4 ohm ribbed cone.
    I repaired a lot of tears in the tolex, also the corners actually had some wood that was damaged too.
    I'm not trying to make it "new" but it does look a lot better now IMO.
    I got it put it back together and played through it a bit.
    It sounds good but was making some noise at idle (with the volume all the way up) microphonic tubes? they look to be original. I changed the 12AX7 and 6V6 tubes, didn't have a spare 5Y3.
    It sounds pretty good now.
    Not sure I will keep this, if I do I'll get my amp guy to check it and maybe replace the can cap.
    I can say that I'm impressed that even on the cheapest amp Fender made, the chassis is heavy duty, and that it works after years of abuse and neglect is a testament to a good design and build, even in the according to some, dreaded CBS era.
    I don't foresee modern PCB amps that suffer the same abuse still working 42 years down the road.
    before
    after
  7. muscmp
    muscmp Tele-Holic
    758
    Jul 1, 2008
    california
    within the last year i've picked up a 76 sf champ and a 75 sf vibro champ. i run an aby pedal into them and match the volume. great combo. oh, and i run a thomas organ, supulveda thru mine. great wah too.
    play music!
