Sealing acrylic.
Discussion in 'Finely Finished' started by gagidlof, Apr 17, 2013.
  1. gagidlof
    gagidlof Tele-Holic
    Marysville, WA
    I'm doing a project that will be donated as an auction item for a fund raiser to send a mission group to Africa to help aids babies. Anyway I'm going to have the body painted in an African tribal-esque theme. Something along the lines of the Kai Eckhardt bass. The artist is working in acrylic so I'm just thinking ahead as to the lacquer. I'm thinking that a layer of de-waxed shellack before lacquer clear, does that sound right?
    Other ideas?
    I think I'll see if I can get a test piece with the same paint cause I figure I'll only have one chance at this one.
  2. Colt W. Knight
    Tucson, AZ
    What type of Acrylic? There are water based Acrylics, Acrylic Enamels, Acrylic Lacquer, and more.
    Compatibility between most modern finishes is a trial and error process. It sucks, I know.
  3. gagidlof
    gagidlof Tele-Holic
    Marysville, WA
    Hmmm... well I don't know yet. I'll find out more from the artist.
    Thanks Colt.
  4. TotallyReptiles
    TotallyReptiles Tele-Meister
    Gainesville, GA
    Cant wait to see it. I love all these handpainted designs on guitars. It makes it truly a one of a kind guitar!
  5. HardlyDangerous
    HardlyDangerous Tele-Holic
    Muskoka Ontaio Canada
    Most Artists paints are a water based Arcylic paint.
    the safest and most durable clear is a 2k urethane.
    Alsa corp or dupont make them in rattle cans
    Acrylic enamel clear is good to seal it as well. Spray very lightly your first couple coats, a heavy coat can make the paints bleed.
    Lacquer clear can be used but again VERY light first couple coats. I would also test it on a test peice first. Some lacquers will eat the Acrylics
    my paintings and guitars I seal with arcylc enamel then clear with 2k urethane
  6. gagidlof
    gagidlof Tele-Holic
    Marysville, WA
    Thanks, HD.
    I'll look at the 2k stuff. I was hoping to clear in lacquer but we'll see what we have to work with.
  7. gagidlof
    gagidlof Tele-Holic
    Marysville, WA
    Well, Its finally ready to post pics.
    So what I ended up doing, I sealed the whole thing in shellac then buried it in a ton of lacquer.
    This one is destined for a charity auction to raise money for a mission to Africa, thus the theme of the art work. Cross your fingers folks and hope she raises some healthy bidding.
  8. TotallyReptiles
    Gainesville, GA
    Really cool looking and awesome job!
    So after the artist did his painting thing, you just coated it with shellac then lacquered it up?
  9. gagidlof
    gagidlof Tele-Holic
    Marysville, WA
    basically yes.
    I gave it a light coat of shellac then a 2nd heavier coat.
    Then I put on the lacquer, after a couple coats, a light block sanding to level out the texture from the art. Then lacquer, sand, lacquer, sand, etc.
    Once it was leveled out I layed on the lacquer heavy for a couple more coats and then let it sit for a couple weeks before polish.
  10. Buckocaster51
    Iowa USA
    Admin Post
    Very nice.
  11. gagidlof
    gagidlof Tele-Holic
    Marysville, WA
    Thank you, that means a lot.
    I got much of my technique from your epic thread.
  12. gagidlof
    gagidlof Tele-Holic
    Marysville, WA
    And after only being completed for a couple days she found a new home today at a charity auction. Here she is with the new happy owner:
  13. Buckocaster51
    Iowa USA
    Admin Post
    You're welcome.
    You made me proud.
    He looks very pleased with it.
  14. 61fury
    61fury Tele-Afflicted
    knoxville, TN
    That is really nice, I like the design a lot. The colors go well with the natural wood. I like the way the stripe weaves around the knobs.
  15. drmcclainphd
    drmcclainphd Tele-Afflicted
    Abingdon, Virginia
    For future reference, Minwax makes a water based poly that's as good IMO as urethane: Polyacrylic. Water based means low odor/less hydrocarbon exposure. The surface tends to be smoother than the equivalent polyurethane (clear gloss comparisons), so I used it for aerospace stuff, over carbon fiber and texalium, and for pick guards cut from those materials.
  16. Waylanderer
    Waylanderer TDPRI Member
    Buffalo, NY
    That's a sweet looking guitar. Kudos. Glad it raised money for a good cause.
  17. gagidlof
    gagidlof Tele-Holic
    Marysville, WA
    Thanks.
    and I learned stuff along the way.:D
  18. Silverface
    Lawndale CA
    FWIW most thin-film acrylics can handle a couple lightly-sprayed seal coats of lacquer sanding sealer better than shellac, where the heavy alcohol content can bleed the heck out of many acrylic binders. Glad it worked OK.
    PS - one of my favorite color-coat products is Vanex (now owned by PPG) Breakthrough. I buy tinting bases or white, use universal colorants, spray the stuff - and once it's dry for 24 hours I can blow lacquer just like normal. It's an industrial acrylic - stuff's so tough it'll work as a floor coating, I use it on the deck of a 32' ocean sailboat, and it works great on guitars, Even handles relic processes really well and sands great.
  19. gagidlof
    gagidlof Tele-Holic
    Marysville, WA
    Hmmm... you've piqued my curiosity. I'm going to look this one up, I might have to give it a try sometime.
