SD Quarter Pund wiring?
Discussion in 'Tele-Technical' started by RoCkstAr256, Sep 2, 2017.
  1. RoCkstAr256
    RoCkstAr256 Tele-Meister
    400
    Jan 3, 2017
    Poland
    Hey
    Ive been reading lots of forums, threads about wiring a Seyomur Duncan Quarter Pund Bridge Lead and can't get one thing, how do i make grounding for it? Old Squier Affinity Pickup Bridge has metal plate under it where groudning connects. I have no idea what i should do now, for sure im getting it to tech. Anyone had same problems?
    Ill try to make photos later , phone need to charge :p
  2. RoCkstAr256
    400
    Jan 3, 2017
    Poland
  3. tessting1two
    tessting1two Tele-Meister
    353
    Apr 13, 2014
    Southern California
    There should be two grounds: first, the black wire of the pickup should be soldered to the back of the volume pot. Second, there should be a ground wire that touches the bridge plate on one end and the other end is soldered to the back of the volume pot. Many guitars don't have this wire and rely on the metal baseplate of the bridge pickup which touches the pickup mounting screws which touches the bridge plate. Since you don't have this metal plate you'll have to run a separate wire.
    This thread shows pictures of a few different methods of running a bridge ground wire: https://www.thegearpage.net/board/i...oblem-on-my-52-ri-tele.1806857/#post-23749767
    RoCkstAr256 likes this.
  4. RoCkstAr256
    400
    Jan 3, 2017
    Poland
