Scotty Anderson's Tele under the hood
Discussion in 'Tele-Technical' started by toetap, Aug 25, 2017.
  1. toetap
    toetap TDPRI Member
    4
    Oct 27, 2014
    ohio
  2. hanerlend
    hanerlend TDPRI Member
    14
    Aug 23, 2017
    Stavanger, NO
    Interesting. What does the second switch do? :cool:
  3. toetap
    toetap TDPRI Member
    4
    Oct 27, 2014
    ohio
    In Scotty's words "three high tones and three low tones" My friend Doug Drews who works on all Scott's guitars shared the pic with me last night. Never had my hands on it yet but, I assume in? out phase series parallel. Unique as scotty for sure::)
    telemnemonics likes this.
  4. telemnemonics
    Mar 2, 2010
    Would that be this one?
    Neck mini hum and sweet tones...
    The neck sound at :56 is sweet as hell.
    But then at 1:49 he flips two switches and gets a seemingly different neck pup sound (after some bridge pickup).
    Dan R likes this.
  5. rze99
    rze99 Poster Extraordinaire Silver Supporter
    Feb 26, 2014
    South London UK
    Wow amazing playing. What's that he's got on his nut?
    Dan R likes this.
  6. rebelwoclue
    rebelwoclue Poster Extraordinaire Platinum Supporter
    Jan 15, 2012
    kentucky
  7. Tony Forman
    Tony Forman Tele-Meister
    Does anyone have a clue on how to wire the Scotty Anderson circuit?
  8. telemnemonics
    Mar 2, 2010
    I want to know what that neck mini hum is!
    Also, what holy grail Peavey amp makes him sound so good!
  9. telemnemonics
    Mar 2, 2010
    I'd guess it's a piece of paper to shim up the string where the nut got a little low.
    ukepicker and Doug 54 like this.
  10. rze99
    Feb 26, 2014
    South London UK
    Thanks. If so, plain weird. So many better options.
  11. telemnemonics
    Mar 2, 2010
    I'd guess the problem just happened and the paper was temporary until he could get to a tech.
    Pretty funny though!
  12. rze99
    Feb 26, 2014
    South London UK
    Yeah. And to be honest his playing is so good who gives a c****. Great sound he gets out of that and the Peavey.
  13. rebelwoclue
    Jan 15, 2012
    kentucky
    I believe Scotty told me the neck was a Gibson miniHB and the bridge was a Seymour Duncan. He used to use a small practice Peavey- like a backstage or something- just a clean platform. He uses only one pedal- a delay.
    toetap and telemnemonics like this.
  14. telemnemonics
    Mar 2, 2010
    I read on another forum (TGP?) that a member there knew/ talked with Scotty and got that it was a Gibson mini. (Maybe it was you?)
    I've always like them a lot compared to any other HB and actually have an old one now that needs the base plate repaired. They used to sit in shops for $35- $50 cause nobody wanted them, but players are wising up.
    Still, his fat round but not bassy neck pup sound is not just straight mini hum with player touch IMO.
    I suspect that the volume turned down with his particular treble bleed recipe cuts some bass and retains just the right treble to get that sound, along with of course a masters touch on the strings.
    I gotta say that his sound is closer to exactly what I want and try to hear, IMO not your typical Tele tone, and while my skills are far behind Scotty's, I can cultivate my tone fairly well.
    I only use delay too, so there's that.
    I'd be very curious to know what cap and what resistor values he has in the treble bleed.
  15. telemnemonics
    Mar 2, 2010
    Could you ask Mr Drews what the treble bleed cap and resistor values are?
    If so then thank you, if not thanks for the pic anyhow!
  16. Tremade
    Tremade Tele-Holic
    612
    Jan 30, 2016
    Sthlm, Sweden
    Thanks for the picture!
    Looks like 1nF/150K for the bleed.
  17. telemnemonics
    Mar 2, 2010
    Could you actually see the bands and read the codes on the orange drop, to get those numbers?
    Or more of an educated guess?
    I just dug out the old pat sticker mini hum I have and it reads 6.02k, so I'm hopeful for a nice fat clear neck tone.
    Just have to fix the broken patched mounting tab.
    Hit the back with a file and the cover is indeed solid nickel silver.
    Gotta pick a body to rout and fab a template...
  18. Tremade
    Tremade Tele-Holic
    612
    Jan 30, 2016
    Sthlm, Sweden
    I clearly see the 102k on the orange drop (1nF).
    The resistor is a bit unclear. I see from left to right: Brown, Orange, Black, Green, Brown. Green cannot be second to last so it is Brown, Green, Black, Orange, Brown.
    It could be yellow and not orange, that's the thing I'm uncertain of. Yellow would give you 1.5M. Sounds high for the application?
  19. trev333
    trev333 Doctor of Teleocity Ad Free Member
    The cavity must be cut deeper to house those honking big parts hanging down... ;)
    a 300V cap in a circuit that carries millivolts is a bit over kill.....
    telemnemonics and ukepicker like this.
  20. boredguy6060
    boredguy6060 Friend of Leo's
    Mar 28, 2012
    Sou Cal
    1nF and 150k is a fairly common combination.
