Sapele / Maple Thinline Build
Discussion in 'Tele Home Depot' started by thecableguy, Jun 20, 2013.
  1. thecableguy
    thecableguy Friend of Leo's
    I picked up this piece of quarter sawn sapele a couple months ago with the intention of building a tele. I prepped the body blank about a month ago.
  2. thecableguy
    Use the router to joint the body halves.
    Cleaned up the faces a bit.
    Glued up.
  3. thecableguy
    Thinned to 1.5". Gonna have a 1/4" maple cap.
    This side has nicer grain so this will be the back.
    Cut out and sanded to the line on the new second hand ROSS.
  4. src9000
    src9000 Poster Extraordinaire
    Nice piece of wood you got there.
  5. thecableguy
    Crap, I can't find the glue line anywhere :D
    This end was no help either. Managed to see a bit of it on the front of the body and marked the centerline.
    Screwed the template down and routed. Took it real easy with the routing to avoid tearout. Made several light passes.
  6. Mark Adkins
    Mark Adkins Tele-Meister
    251
    Feb 17, 2013
    Petoskey, MI
    Amazing job joining the two pieces together! Looking good! What is the weight of it so far?
  7. thecableguy
    Thanks Mark. I was really careful this time with the jointing. I made sure the seam was light tight along the entire length before gluing.
    Looks like it's just over 6 lbs 4 oz. It'll lose a substantial amount after chambering though. Then gain a little with the maple top.
  8. thecableguy
    I think I'll use the leftover maple from my previous build. The small piece is neck size and the other one should be big enough for a bookmatched top. This board ended up having really good figure so I think it will work alright for this build as well.
  9. clsatt
    clsatt Tele-Afflicted
    Mar 14, 2009
    virginia
    This is going to be one stunning guitar!
  10. gitlvr
    gitlvr Friend of Leo's
    Aug 18, 2008
    Northern Va.
    +1. The sapele is lovely.
  11. thecableguy
    Thanks Steve, they have a bunch at Windsor Plywood and the price is pretty good. I'm thinking I should probably pick up some more. I've been reading lots of LP threads lately. ;)
    Thanks Chris, I hope so! I learned so much from the previous build that I'm going to roll into this one, such as how to properly joint a 2 piece body. :D
  12. thecableguy
    Hey thanks Mike, I had never heard of sapele until Herb's Elpee thread. I guess it's a type of mahogany. Smells like mahogany when I cut it.
  13. gitlvr
    Aug 18, 2008
    Northern Va.
    I'm not sure if they are actually related, but sapele, along with khaya(spl?) are often used as mahogany substitutes, and correctly or not, often referred to as mahogany by many factory builders.
    I don't really care what people call it, I think it is lovely wood. The piece you have is particularly nice, IMO.
  14. thecableguy
    According to this they're in the same family:
    http://en.wikipedia.org/wiki/Sapele
    I agree, it really is nice wood regardless of the name. I can see myself building quite a few guitars with it.
  15. thecableguy
    I made this chambering template earlier (I love the ROSS).
    Lines marked and started hogging.
    It already feels quite a bit lighter. It'll be interesting to see how much weight it loses after the chambers are done.
    I'm going to leave the back around 1/4 inch thick. I'm drilling to about 1.1" with the forstener not including the tip. Should have a nice clean bottom to the chambers after routing.
  16. Cat MacKinnon
    Cat MacKinnon Friend of Leo's
    Nov 13, 2011
    Colorado
    mmm, i absolutely love sapele! i'd rather have that than "real" mahogany because it usually has such beautiful grain patterns!
  17. adirondak5
    adirondak5 Wood Hoarder Extraordinaire Ad Free + Supporter
    Oct 24, 2009
    Long Island NY
    Looking good Brian , Sapele is beautiful , it machines wonderfully in my experience
  18. Telenator
    Sep 19, 2005
    Vermont
    Very nice build!
    If it's not too late, may I suggest you do not route the pocket behind the bridge. In my experience with Thinlines, leaving that area solid seems to help the guitar project better in a live situation, and just over all sound better.
    Thinlines can be tricky to get a good sound from. In my opinion, the pocket behind the bridge is part of the reason. Even on my Ric 360/380L style builds I left the area behind the bridge solid and both those guitars will simply flatten a Ric in a side by side comparison.
    Can't wait to see the finished product. I really like working with sapele. It sounds great!
  19. allen082
    allen082 Friend of Leo's
    Jul 16, 2009
    fort worth
    Looks great! I'm working on a similar build right now with sapele.
  20. bug10
    bug10 Tele-Meister
    280
    Aug 12, 2012
    That is looking amazing. What are you thinking for a finish?
