Join TDPRI Today
Saddle Sore!
Discussion in 'Telecaster Discussion Forum' started by tkdcal, Oct 23, 2012.
  1. tkdcal
    tkdcal TDPRI Member
    77
    Jan 15, 2008
    Los Angeles
    Hey all,
    What do you guys do, if anything, about the tele saddle screws sticking up? Those buggers irritate the heck out of my hand. Any suggestions?
  2. stevopacnw
    stevopacnw Former Member
    79
    Dec 31, 2011
    Northwest
    Get a shorter set of saddle adjustment screws.
  3. Formerblonde
    Formerblonde Tele-Meister
    203
    Sep 17, 2012
    Ottawa
    Well, you can't grind the top off the screws or you won't be able to adjust the string height anymore. What I'd do is count the number of threads sticking out the top, and remove that much from the bottom with a grinder or.... go to the nearest hardware supplier and watch them roll their eyes when you say you want 6 just a bit shorter than 'this' one.
  5. Bones
    Bones Doctor of Teleocity
    Dec 31, 2005
    Luddite Island, NY
    Put the ashtray on.
  6. 1955
    1955 Poster Extraordinaire
    Apr 10, 2010
    Certain uncertainty
    You can cut them with a jigsaw, your foot, pair of pliers, and a metal cutting blade. Use care. Can you tell i am not a craftsman? Then you use a demel type tool with a few metal grinding attachments to get it smooth. The Big Lots store has a tool plus attachments for 10 bucks. Once youve done your setup you can use a marker to color the screw to know how much to trim off roughly on the screw.
  7. waparker4
    waparker4 Doctor of Teleocity
    Nov 9, 2011
    Philadelphia, PA
    I don't do anything about it and keep the meaty part of my hand still
  8. tkdcal
    tkdcal TDPRI Member
    77
    Jan 15, 2008
    Los Angeles
    Somethin' tells me I been doing it wrong. :neutral:
  9. Camplain
    Camplain Tele-Holic
    670
    Aug 2, 2011
    Hamburg, Arkansas
    You have 3 options I can think of. Get new shorter screws, cut the old ones, or shim the neck...
    I wouldn't go changing my picking style to accommodate uncomfortable height screws... I'd be most likely to shim the neck slightly at the rear of the pocket, that's not as practical as getting shorter screws, but I like my strings up kinda high off the body, so it works for me.
  10. nadzab
    nadzab Friend of Leo's
    Mar 23, 2009
    New England
    Dremel those babies.
  11. waparker4
    Nov 9, 2011
    Philadelphia, PA
    I think I am just lucky that I have never had an issue with even really overly long saddle height screws sticking out.
  12. 1955
    Apr 10, 2010
    Certain uncertainty
    Make sure your tetanus shot is up to date as an aside!
  13. trev333
    trev333 Doctor of Teleocity
    ..if screws stick out or if the saddles need to go right down to get an acceptable action...I shim the back of the neck and raise the saddles, so the screws are flush....
    or fiddle about and trim the small grub screws shorter....
    either method will work..:)
  14. Dr. Bill
    Dr. Bill Tele-Afflicted
    May 1, 2003
    Upstate, SC
    I bought some shorter screws for the low and high E strings as the Fastenal store. Fixed!
  15. Bartholomew3
    Bartholomew3 Friend of Leo's
    Dec 8, 2010
    Montreal
    I also shimmed the neck on a vintage tele.
    Plus it gave me more space for pick-up adjustments as I had to raise the bridge to compensate for shimming.
    Solved 95% of the problem.
  16. Rolling Estonian
    Rolling Estonian Friend of Leo's
    Aug 23, 2009
    Bethesda, MD.
    Shorter screws is the way to go. Smaller mom and pop hardware stores are a better bet than big box. If you know the diameter, look online, I know Callaham offers them for their saddles.
    M
  17. qblue
    qblue Tele-Afflicted
    Jan 12, 2009
    Clarks Summit, PA
    You are too sensitive ...MAN UP, DUDE!
  18. FenderGuy53
    FenderGuy53 Friend of Leo's
    May 14, 2008
    WNC foothills
    +1 re: "shim the neck".
    There may always be a reason for longer screws.
  19. ringosoft
    ringosoft TDPRI Member
    81
    Nov 6, 2009
    out there
    lol
  20. ringosoft
    81
    Nov 6, 2009
    out there
    And yes, shim the neck... it is easy and completely reversible
  21. dadder
    dadder Tele-Meister
    211
    Sep 10, 2011
    Northern Ireland
    A combination of "either or" as described above to suit. Sad to say they used to be made with different height screws.
    But hey, think about us luthiers. If all guitars left the factory player perfect, we'd have much less work.
