saddle angle?
Discussion in 'Tele-Technical' started by Silent Otto, Sep 18, 2017.
  1. Silent Otto
    Silent Otto Tele-Meister
    193
    Jun 1, 2015
    3rd rock
    hi all.
    im changing strings (MIM tele) and sight down the string line to see that all the saddles (6-saddle bridge)are slightly angled side to side, towards the high E -- each saddle's grub screws are set at unequal lengths.
    so the question is -- should the saddles be square to the bridge plate, or should i just leave as is?
    ta.
  2. Budda45ftw
    Budda45ftw Tele-Meister
    139
    Aug 21, 2017
    Rochester NY
    You want a bit of a radius at the bridge.
  3. Silent Otto
    193
    Jun 1, 2015
    3rd rock
    so they should mimic the fretboard radius?, totally makes sense!
    ta
    fenderchamp likes this.
  4. Ricky D.
    Ricky D. Poster Extraordinaire
    Oct 22, 2006
    Garner, North Carolina
    I set my saddles individually as low as possible so there is no buzz or rattle, then raise as needed to mimic the fretboard radius. Just feels better that way imo.
  5. philosofriend
    philosofriend Tele-Holic
    568
    Oct 28, 2015
    Kalamazoo
    If it ain't broke, don't fix it. When you do need to adjust the saddle height you might strategically do it so they come out more level, but if its not buzzing, leave it alone.
    rich815 likes this.
  6. LutherBurger
    LutherBurger Friend of Leo's
    Oct 29, 2013
    NYC
    In my opinion, yes. I'm a bit obsessive about such things; I like nice, orderly parallel lines and right angles.
    For string height, I use a ruler and set each string 5/64" above the 12th fret. Or with a capo at the first fret, 5/64" above the 17th. With .010" of neck relief, on my guitars the resulting string height is the same using either method. I find that comforting.
    danpan likes this.
  7. FenderGuy53
    FenderGuy53 Friend of Leo's
    May 14, 2008
    Marion, NC
    In a 6-saddle set-up, a flat or slanted method will work; so the question becomes: Does one method work better?
    IMHO, adjusting the saddles so that the bottoms are parallel to the body surface provides for: 1) optimal stability and 2) best saddle-to-saddle contact.
    Good luck!
    LutherBurger likes this.
  8. Vizcaster
    Vizcaster Friend of Leo's
    Sep 15, 2007
    Glen Head, NY
    I would try to have the saddles parallel to the bridge plate, but to correct it at this point you're risking getting the action height out of whack. Whoever adjusted the string height last probably didn't pay attention to how many turns were being made on each screw so they were left a little cockeyed. It would have to be really bad for it to create a problem in terms of spacing (tilted saddles require more room side to side).
  9. FenderGuy53
    May 14, 2008
    Marion, NC
    It's better to have it right; it's a 10-minute fix, if you have a 6-inch rule which measures 32nds and 64ths of an inch.
  10. boris bubbanov
    I like to split the difference, with more weight towards having each neighboring saddle somewhat congruent to its neighbor,.
    If you elevate one screw that much over its partner, it will will take on much more of the load applied to the saddle. At the extreme, the screw with inadequate tension starts moving around.
    But at the other end, when the saddles are absolutely parallel to the face of the body, the saddles may stick up a bit more and fall into the path of the picking hand, and that can be aggravating.
    Finally, the more you cant a block saddle relative to its neighbor, the more this splays the 6 saddles when seen as a whole.
    Put it another way, if I'm fooling with a MIM Standard (or a T style with that type of bridge) and the outboard (E) strings are too close to the edges of the frets, I'm gonna adjust them towards being flat (and less following the radius) because then the saddles can group up more tightly to one another. Might be .015 inches but every little bit makes for a better playing guitar
  11. telemnemonics
    telemnemonics Poster Extraordinaire
    Mar 2, 2010
    The lower the saddles the less it matters.
    Think of a saddle as a triangle of forces.
    The two screws at the bottom, and the string pushing down at the top.
    If the saddle is set high, like it often is on a Tele, that triangle is twice as tall as it is wide at the base, so it is less stable when tipped at an angle than if the string pressure is centered over the two base points.
    And as noted, when tipped, there is less tension on one screw than the other.
    In the real world, I have worked on many guitars where this had become a real functional problem, because once the saddle is tilted and the long screw has little tension on it, strumming tips the saddle and it just gets worse and worse.
    Try slipping your pick in between the saddles and prying a bit.
    Can you move them pretty easily?
    You shouldn't be able to tip them easily with a pick.
    Tippy saddles that move can effect the sound and response, as well as not staying adjusted due to loosening screws.
    Guitars come into shops like this regularly.
    If you have a modern 12" radius board and low saddles, and it makes you happy, it might be fine to angle the saddles so it "looks" like they are all lined up in a neat radius. Keep an allen wrench in your gig bag.
    But if you need a tech to adjust your guitar, have a 7.25 radius board, or have a guitar where the six saddles are as high as they are wide at the screws, keep those saddles level for stable lasting adjustment, and secure string anchoring that won't move when you play!
  12. teleplayr
    teleplayr Tele-Meister
    To answer your question I have the saddle screws even on the saddle and the saddle itself set to the radius.
  13. user34603
    user34603 Tele-Meister
    330
    Dec 5, 2016
    Richmond VA
    .... follow the radius of the fretboard with the saddle tilt. Make sure to adjust the Allen screws with no tension on the string.... the Allen screws are to raise and lower the saddle sides.... not fight the string pressing the saddle down on its Allen screws.
  14. tessting1two
    tessting1two Tele-Meister
    279
    Apr 13, 2014
    Southern California
    I'm sorry but the saddles should not be tilted to form any kind of arc as there is no mechanical advantage in doing so and can only lead to problems. The saddles need to be parallel to the bridge plate and each saddle raises or lowers evenly to conform to the fingerboard radius (like steps). If the saddles are tilted there is uneven string pressure on the saddle which can allow the saddles to shift laterally and also puts most of the force onto one of the set screws allowing the other one to loosen over time, which can even lead to buzzing at the saddle.
    You want the downward pressure of the string to exert evenly on the saddle, straight down onto the bridge plate. This provides the best mechanical coupling from string to saddle to bridge plate.
  15. user34603
    330
    Dec 5, 2016
    Richmond VA
    ...then explain to the readers about the fretboard having a radius and how the hand plays the fretboard/strings and not the flat bridge surface. I believe you are focusing on mechanics and not guitar playing.
  16. beninma
    beninma Tele-Holic
    513
    Mar 17, 2017
    Massachusetts
    I've been through this. Mine were tilted pretty bad when I got my MIM.
    You can have the strings radiused perfectly with all of the saddles parallel to the bridge. There are an infinite # of angles of the saddles being tilted that will put the strings in the same spots. You can absolutely have all the saddles *angles* parallel to the bridge for good screw contact and still have them radiused perfectly.
    Tilted too much does cause issues. You can get the "sitar" sound if they're tilted too much. IME especially on the treble strings if they tilt with the radius of the fretboard as you've lowered the edge that is away from a downstroke. Hit a hard downstroke and you can have the string vibrate in/out of the slot in the saddle.
    I think when tilted mine also hit the issue that Boris mentioned... my high e string seemed like it was too close to the edge as if the nut slot was off. But in reality it was just the tilted saddle splaying a little to the outside... It should have been obvious to me because it was only an issue higher up the fretboard where the saddle has more leverage to pull the string spacing wider.
  17. beninma
    beninma Tele-Holic
    513
    Mar 17, 2017
    Massachusetts
    You set the heights of the strings respective to the radius of the fretboard. Not the angles of the saddles. The saddles don't rest on a radiused surface, they rest on the perfectly flat bridge.
    Steve Holt and tessting1two like this.
  18. beninma
    beninma Tele-Holic
    513
    Mar 17, 2017
    Massachusetts
    Hah.. "radiused" is not a word. My browser works really hard to change it to "radiuses".
  19. Old Tele man
    Old Tele man Tele-Afflicted
    May 10, 2017
    Tucson, AZ
    Can't "fix" stupid SpellChex.
