Join TDPRI Today
Richter tweed with Weber Alnico Speaker
Discussion in 'Shock Brother's DIY Amps' started by Badabing, Feb 2, 2013.
  1. Badabing
    Badabing Friend of Leo's
    Oct 13, 2009
    San Marcos, Ca
    I own a Richter amp and the previous owner said he switched the speaker out to a Weber Alnico...
    Can anyone help me understand if this was a good move or bad? Any info would be great!
    Thanks!
  2. Viejo
    Viejo Tele-Holic
    599
    Feb 12, 2011
    Southern IL
    I don't know what speakers Sara puts in her amps stock, but Webers are fine speakers and probably the closest to the stock Jensen that would have come in an original Fender tweed that anyone manufactures today. Also from all the sound samples I've heard, the Richters are very good sounding amps.
  3. Badabing
    Oct 13, 2009
    San Marcos, Ca
    Viejo,
    yes this amp sounds very good to my ears. I was just curous about the speaker change and what the previous owner was trying to achieve.
    Thanks for the info I appreciate it!
  5. telex76
    telex76 Doctor of Teleocity Ad Free Member
    Jun 24, 2006
    Fort Worth,Tx.
    Probably an improvement, can't be sure without knowing what original speaker was.
  6. Badabing
    Oct 13, 2009
    San Marcos, Ca
    Does anyone know what tone/genre the Weber Alnico speaker is designed for???
    Why would you use this speaker over another speaker?
    Thanks in advance for your help!
  7. onenotetom
    onenotetom Tele-Afflicted
    Jun 27, 2009
    Colbert, WA
    You need to give us the specific model. If it is something like a 12a125 it was pretty much designed for a tweed deluxe style amp. From the Weber site "The favorite for period-correct Tweed Deluxe tone (5E3): [12A125A, 8 ohm, 30w, light dope]"
    If you go to Webers website you can look up the model numbers and read their recommendations.
    https://taweber.powweb.com/weber/
  8. Badabing
    Oct 13, 2009
    San Marcos, Ca
    Where is the model number located? can I see it from the back of the amp?
    Thanks!
  9. Badabing
    Oct 13, 2009
    San Marcos, Ca
    Found it...
    Here it is...
    12a125-a
    8ohm 30 watt
    date 3.31.10
    I couldn't find this one on their website???
  10. onenotetom
    Jun 27, 2009
    Colbert, WA
    Follow the link I provided. Select vintage series, scroll down to the 12" speakers, left column 5th one down 12A125A, it has HOT flashing next to it, click on it and you will get the specs.
    It is the one that says "The favorite for period-correct Tweed Deluxe tone (5E3): [12A125A, 8 ohm, 30w, light dope]" Yours is in Blue. Do you have a Blue amp jewel as well? That combo is supposed to sound the best.;)
  11. Badabing
    Oct 13, 2009
    San Marcos, Ca
    Are the amp jewels all the same color for the Richters?? Mine is a blue violote kind of color..??
  12. Badabing
    Oct 13, 2009
    San Marcos, Ca
  13. EdMax
    EdMax Tele-Meister
    273
    Mar 18, 2008
    Northern Illinois
    If you get the build date on the label and email Sara she can likely tell you what the original was.
    I believe for the past 4-5 years they came stock with Jensen Electric Lightning speakers. Seems they use that speaker a lot.
  14. onenotetom
    Jun 27, 2009
    Colbert, WA
    Don't know, but I now know you got the combo! Hope you are playin it loud and proud. Enjoy!:cool:
  15. Fatknuckle
    Fatknuckle Tele-Holic
    981
    Jun 28, 2012
    Gainesville FL
    Weber speakers are AWESOME. That model should be fine for your amp, but if you don't like the tone, you can always try something else.
