Reverb pedals vs. amp spring reverb
Discussion in 'The Stomp Box' started by jonkay1, May 20, 2012.
  1. jonkay1
    jonkay1 Tele-Meister
    I see that digital reverb pedals are a hot topic on this forum. I'm curious about the general consensus. Are reverb pedals preferable over the amplifiers spring reverb? If so, why? Does anyone prefer the amps' reverb rather than a reverb pedal? Once again, if so, why?
  2. nosuch
    nosuch Friend of Leo's
    Apr 4, 2008
    Cologne
    I think you can't generalize that much - there are a lot of different pedals (some mock spring reverb, some try to give a clean, natural reverb) as well as in built in spring-reverbs in an amp. I think the surf guys favour spring reverbs like in a twin reverb or the fender tube reverb unit - which does not at all sound like a natural room ambience. there is a boss pedal copying that kind of effect.
    others like more of a natural ambience - I do which I can achieve from a digital pedal as well as the spring reverb in my sessionette or vibrolux which are set up for that kind of reverb.
  3. nic'o'caster
    nic'o'caster Tele-Afflicted
    Apr 10, 2004
    Middle Earth
    There are many good reverb pedals on the market nowadays : Strymon blue Sky, TC Hall of Fame, T-Rex Roommate, Neunaber WET, Wampler faux spring, Plush Verbrator, etc...
    Most of them are digital but they no more sound cold and sterile like old digital racks used to sound. They offer way more control over the settings than a typical spring reverb tank, and their possibilities are almost limitless.
  4. WireLine
    WireLine Tele-Holic
    718
    Mar 23, 2003
    Midland TX
    If given a choice, why not just use the real thing? It works, works great, and delivers a certain something that digital models try to emulate, but just don't seem to deliver.
  5. nic'o'caster
    Apr 10, 2004
    Middle Earth
    I agree with you if one's after just a great spring reverb but you've no choice if you want long dark reverb with a hint of modulation and shimmer on top !
  6. Paul in Colorado
    Paul in Colorado Doctor of Teleocity Ad Free Member
    Fort Collins, CO
    Most of my amps have reverb, but I have a TC G-Major effects unit that I use with my Rivera amp (that has a spring reverb tank). There are a lot of ways to use reverb and lots of different textures available from pedals and rack gear. It just depends on what kind of sound you're going for. Caverns, surf, big church, small reflective rooms...
    Simple is good, too.
  7. RubyRae
    RubyRae Friend of Leo's
    Dec 8, 2009
    Cincinnati
    There is nothing like true spring reverb, just like there is nothing like true tape echo. I use a Hermida Reverb on my non reverb Princeton and it certianly sounds darn good for $99 bucks. Most people use them for the sake of saving money and not being able to afford a Fender Reverb Unit. Same with the tape echo's, who has a grand to buy a Fulltone tape echo? Not me. There are some real good reverb pedals for under 200$. There are also some smaller true spring reverb units. Easier to take to gigs too.
  8. Ringo
    Ringo Poster Extraordinaire
    Mar 16, 2003
    Memphis TN
    There are plenty of amps with spring reverb where the reverb doesn't sound that great, usually those amps have an IC solid state reverb circuit, but I have had amps with tube reverb circuits that also didn't sound great, vintage Traynor, Vox etc..
    The tube driven Fender reverb (and Ampeg) are the benchmarks IMO, but some of the newer reverb pedals sound really good.
    I had one of the early Holy Grail reverb pedals that sounded good, the Hermida reverb sounds very good IMO and it works with distortion / gain, something that a "real" spring reverb usually does not do well.
  9. ac15
    ac15 Poster Extraordinaire Ad Free Member
    May 9, 2005
    CHICAGO, IL.
    Use "the real thing?" You mean a large, cavernous room, right?
    Or did you mean that phony spring reverb?
  10. 1955
    1955 Poster Extraordinaire
    Apr 10, 2010
    Certain uncertainty
    I remember bringing a centerfold to a neighborhood football game when I was About 12. All the guys went gaga. Except- The oldest guy there was probably 14 and he goes "Ain't nothin like the real thing, man" just to bust my bubble. I'm sure he hadn't tried the real thing yet.
    Spring reverb is a couple of springs in a metal tank, and that's what it sounds like. I like it, but also like other types of reverb, emt plates, chambers, digital, etc. Bathrooms can be great. They are all real, just different.
    Great point AC15!
  11. cowie86
    cowie86 Tele-Meister
    305
    Apr 18, 2008
    I have true spring reverb on my amp and a Yamaha MagicStomp with a ton of reverbs.
    I use the amp's reverb if I'm just messing around a want a general spring reverb, but if I'm spending a lot of time on something, or what something special from the reverb then I'll use the Yamaha MS. It is digital, but the software is the same as what's in Yamaha's rack mount and studio gear.
    Once you can tweak your reverb using a whole host of parameters, then it becomes a lot more than something to just simulate a large cavernous room IMHO.
  12. WireLine
    WireLine Tele-Holic
    718
    Mar 23, 2003
    Midland TX
    Spring reverb is what it is...natural ambience is what IT is... currently I don't use anything other than natural ambient reverb live, (but so use a touch of echo).
    I'm sure you knew this, but unless you are playing direct or in some anechoic chamber, every gig has a natural ambience, some are great and some are awful...spring, digital, or whatever reverb just adds to what is already there, and more times than we might be aware of the results are not very pleasant (to my ear, anyway)... People in the audience may not notice too little, but they sure will notice too much reverb in the house mix, and truthfully, most of us have no idea what we sound like 25 ft (or where ever the audience starts)..
    Like everything else - just my opinion based on my observations from doing this since 1971, and it may not be everyone's else's observations or experiences
  13. Durtdog
    Durtdog Poster Extraordinaire
    May 19, 2004
    Tennessee
    For playing live, I use the reverb in my Twin. If I gig the Peavey C30, I use a Boss FRV-1 because it gives a reasonably realistic Fender reverb sound, and that's what I'm usually after.
  14. Gold Rush
    Gold Rush Tele-Meister
    133
    Sep 13, 2010
    East Coast U.S.
    Woke the Mrs up a few weeks ago while I was jamming late one night in my music room. She told me the next day she liked that "surf" song I was playing. All I'm using is a Boss FRV-1 fed into a Tech 21 R.V.B./Boost. She mentioned nothing about me needing a spring tank!
  15. FenderLover
    FenderLover Friend of Leo's
    Jun 11, 2009
    Minnesota
    I'd opt for an amp with an FX Loop before a built-in spring reverb. Springs are good when you want them. I like ambience from reverb most of the time, and you can't beat a Lexicon for that. With so many reverbs available, I can't see being married to just one built-in reverb, let alone having a single knob to control it. Not to mention, other FX may be used in the same loop.
  16. spankdplank
    spankdplank Tele-Afflicted
    Jan 19, 2007
    Houston, Tx.
    There is no substitute for tube driven spring reverb. Unless your amp doesn't have it. Then your choice is no reverb, a reverb pedal or outboard reverb tank. In a gig situation, I use a good pedal all the time when I play my non-reverb amps. No one can tell the difference.
  17. mad dog
    mad dog Friend of Leo's
    Jun 27, 2005
    Hard to generalize. The Hermida Reverb works so well for me. I use it even when playing my only reverb amp, an Allen Encore. But if I still had the old super reverb, that reverb would be on, pedal off.
    It varies amp to amp, pedal to pedal. I'll be getting another outboard reverb soon, as that sound is rather different from either pedal or in amp reverb.
    MD
  18. RockerDuck
    RockerDuck Friend of Leo's
    Jan 29, 2010
    Marietta,GA
    Nothing like two DRRI's in stereo and reverb from both amps on. I have both.
  19. mal paso
    mal paso Banned
    Nov 24, 2011
    Bloomington, IN
    The correct answer should be amp reverb, but they don't make amps like they used to, so unfortunately(or maybe fortunately), my answer is pedal.
    Currently using an EHX Cathedral, and it is ridiculous. Room, hall, spring, plate, reverse, etc. It has flange, delay, and the ability to go 100% wet.
    I wish I could rely on my amp, but this thing just does too much, and I'm a man who loves his reverb
  20. Lowbassnotes
    Lowbassnotes Friend of Leo's
    Feb 7, 2012
    Pacific Rim USA
    MSLP Spring'd Steen is a pedal that drives a real tank of your choice(long or short spring). Real spring reverb that plugs into non-reverb amps and for a couple hundred bucks total you've got real spring reverb. Google MSLP pedals and you'll find his info.
