Reranch color advice.
Discussion in 'Finely Finished' started by vintagelove, Sep 29, 2017.
  1. vintagelove
    vintagelove Tele-Meister
    364
    Oct 18, 2014
    NY
    Hello and thanks for looking. I'm looking for advice on matching the color of this neck to the body. From what I read it seems I can scuff up the finish with 400ish sandpaper, then apply some reranch aerosol tint and clear, and hopefully get the desired result.
    So the question is which color do I get. It looks like either butterscotch, or butterscotch blonde. What do you folks think? Should I also go with the tinted clear?
    Any advice is greatly appreciated. Thanks again.
    (The upper non cutaway bout is the most accurate body color)
  2. Silverface
    Mar 2, 2003
    Lawndale CA
    I don't understand the question.
    Are you looking for just general color matcvhing information? IF so you'll need to post non-grainy, in-focus pictures. It's not possible to tell what colors you currently have wth the blotchy-looking images.
    Also - what is the neck coated with now? If it's not conventional lacquer you're looking at the wrong product line. Reranch's lacquers will not adhere properly to a polyurethane, polyester or UV-cured resin coated neck.
  3. cabra velha
    cabra velha Tele-Afflicted Platinum Supporter
    Jan 21, 2016
    estados unidos
    I generally like reranch products but try to steer people away from tinted clear. My experience with both the reranch and stew-mac tinted clears were pretty negative, no matter what you do with any finish somewhere somehow you will experience some runs, unfortunately with tinted clear you build pigmented density unevenly in these areas and good luck trying to fix that.
    YMMV
  4. tele12
    tele12 Friend of Leo's Silver Supporter
    Dec 2, 2006
    NY
    Well since you said any advice.......I would not change the neck color.
    Look at pictures of vintage natural guitars, the body is almost always darker than the neck.
    I think it looks great the way it is, contrast looks really good.
  5. vintagelove
    364
    Oct 18, 2014
    NY
    Appreciated. I would like to darken it a bit, but it doesn't need to match. Advice on which to darken rather than match would be appreciated from any other experienced folks too.
    Thanks
