Join TDPRI Today
Replacing a nut- too "short"
Discussion in 'Tele Home Depot' started by TelZilla, Jan 30, 2013.
  1. TelZilla
    TelZilla Friend of Leo's
    Jan 21, 2007
    Cleveburg, USA
    So I bought a cheapo epi Les Paul off of ebay with a broken headstock. I've got the headstock repaired but I figured while I was at it, I'd replace the nut with a good bone one. I got a replacement bone nut from Stewmac- pre slotted.
    The string spacing matches the old one, but the new one is "shorter" by about 1/16". Like, if you put both nuts in the slot, the string slots are about 1/16" closer to the fretboard on the new one.
    So a couple of questions:
    • How far off of the fretboard do I need the nut slots to be?
    • If I need to somehow "raise" the new nut, any advice on how to do it?
    Thanks
  2. crazydave911
    Feb 23, 2010
    East Tennessee
    A snipped up credit card comes to mind........................
  3. Nick JD
    Nick JD Doctor of Teleocity
    I've raised a nut before using a slice of hardwood veneer glued to the underside of the nut.
  5. TelZilla
    Jan 21, 2007
    Cleveburg, USA
    I'm a total woodworking noob. So that means an exterior slice of plywood?
  6. Rich Rice
    Rich Rice Poster Extraordinaire
    Jul 15, 2005
    Chicago 'Burbs
    He means glue a skinny piece of wood to the bottom of the new nut, trim it flush all around, and glue it into place.
    Just a drop of Titebond to attach it, you may need to get it off someday.
  7. TelZilla
    Jan 21, 2007
    Cleveburg, USA
    So what's a good source for a little slice of wood that's 1/16" thick?
  8. Rich Rice
    Jul 15, 2005
    Chicago 'Burbs
    Try Hobby Lobby if you can't slice one yourself. Or someplace that carries radio control airplanes- someplace like that which carries stuff for arts and crafts. To be honest, a popsicle stick would work pretty good.
    As an aside, I'd either make a new nut or make a bone block to extend the height.
  9. TelZilla
    Jan 21, 2007
    Cleveburg, USA
    Thanks for the help.
  10. Rich Rice
    Jul 15, 2005
    Chicago 'Burbs
  11. I_build_my_own
    Mar 9, 2012
    New York
    as an alternative to popsticle you can alse keep an eye out for wooden coffee stires. I have seen birch and maple ones.
  12. guitar2005
    guitar2005 Tele-Holic
    710
    Oct 22, 2010
    Canada, Québec
    The strings are closer to the fretboard... but is it a problem? The strings should be as close as possible to the fretboard without buzzing.
