Replacement bridge for Indo Affinity?
Discussion in 'Squier Tele Forum' started by rlyrlybigman, Jun 11, 2018.
  1. rlyrlybigman
    rlyrlybigman TDPRI Member
    6
    Jun 10, 2018
    Langley, BC
    Hey all. Let me preface this post by saying I am very VERY new to Tele's. I recently purchased an Indonesian Affiity and I absolutely love it. Hardly vintage correct but it's made a Tele fan out of me.
    One thing I would like to eventually replace is the bridge. As far as I've been able to tell, there aren't many aftermarket ones for this particular style. Just for clarification, it's a 5 hole, string through body style with the string holes situated between the bridge and the 3 rear mounting holes.
    I know GFS makes this one, https://www.guitarfetish.com/Modern...dge-Stainless-Steel-Saddles-chrome_p_501.html
    But it really doesn't seem to much different/better than what I've got already.
    Are there any other direct swaps I can do without drilling extra holes? Or is this likely a mod I'm gonna have to do to my second Telecaster :D
  2. kaynray
    kaynray TDPRI Member
    38
    Mar 30, 2012
    IMHO affinity tele's are a great value and every bit as fun as " regular " tele, but--- that bridge does not have a direct replacement. You can put all manner of after market bridges on, but most will leave your old bridge holes exposed. Some folks don't mind, others put colored screws in the left over holes. If you're just looking for replacement saddles (brass?) Look here or Google "bubba mod". Good luck, welcome, and play the crap outta that thing.
  3. kaynray
    38
    Mar 30, 2012
    Ok just re-read and see you have a string thru bridge/body. Never had one of those so don't know if any of the above applies. Gotta read more carefully next time. Sorry.
  4. StuartJames
    StuartJames TDPRI Member
    11
    Jun 10, 2018
    I just ordered a genuine fender/squire standard bridge that comes with saddles to for very cheap for my affinity. According to the measurements there will be no screw holes showing and should be a perfect fit. Will report back when I get a hold of it
  5. nicod98
    nicod98 Tele-Holic
    695
    Jul 7, 2014
    Belgium
    A Squier standard bridge should cover your affinity original bridge holes, but I wonder what you hope to win?
  6. StuartJames
    11
    Jun 10, 2018
    My affinity is a top loader, I'm going to drill through for string through body. It's a cheap axe I got to practice mods. I'm not doing for better sustain but because I want a rock solid bridge. I'm getting buzz from the saddles ( which I have upgraded). I'm pretty confident the new bridge and string through will rectify this
  7. nicod98
    nicod98 Tele-Holic
    695
    Jul 7, 2014
    Belgium
    Oh you are going for a string-through conversion. This made me think it WAS a string-through guitar already:
    and apparently, I'm not alone:
    The 2012-2017 pack Indonesian Affinity was string through, but if you've got a 2018 top load Indonesian Affinity, I can see why you'd change that.... I just change strings from 9s to 10s, 10.5s or 11s. That usually reduces buzz as well!
    Or it could be your guitar just needs a good, professional setup.
    Drilling holes through the body usually ends up in a not so tidy looking back of the guitar. It would bother me, and I'd recommend buying a Squier Standard (or better) instead. The standard is just a few dollars (in my case euros) more than an Affinity over here.
  8. rlyrlybigman
    6
    Jun 10, 2018
    Langley, BC
    Hey guys, thanks for the replies . Let me clarify. The model I own is already string through body. I guess it's one of the 2012-17 models as someone mentioned. My thinking was that I might get an ashtray style bridge, but there doesn't seem to be much available for this particular configuration. I thought I included a pic the first time around but apparently I did not, so I'll upload one now.
    I'm thinking that for now I'm just going to upgrade my saddles to something a little better, probably some Graph Tech ones. I imagine my next Tele will probably be a CV so I'll worry about more "vintage correct" details then .
  9. nicod98
    nicod98 Tele-Holic
    695
    Jul 7, 2014
    Belgium
    In that case the best thing I think you can do is the Bubba mod (search this forum you'll find dozens of examples)... Three barrels (take compensated barrels if you want easier intonation), just three holes to drill in the existing bridge plate.
  10. jerrymelons
    jerrymelons TDPRI Member
    11
    Feb 15, 2018
    Lafayette, LA
    Yeah, ashtrays won't fit on these at all. You may be able to find a modern style replacement. or do the bubba mod for 3 barrel saddles. It's too bad, since these would look great with an ashtray!
  11. Ira7
    Ira7 Poster Extraordinaire
    Jan 8, 2008
    Coral Springs, FL
    It is NOT easy drilling string-throughs, even with a drill press. With a hand drill, say a few prayers first.
    The bit wanders, and although it will work, the ferrule holes in the back will be totally unaligned, unless you really know what you're doing.
    Check out a few hundred YouTube videos before attempting.
    No big deal if the ferrules aren't aligned, but it's real fugly.
  12. StuartJames
    11
    Jun 10, 2018
    I plan on practicing on some wood first. I'm feeling brave , hope I don't regret it....
  13. Ira7
    Jan 8, 2008
    Coral Springs, FL
    I tried it twice and regretted it twice. I'm a spaz.
    Actually, just joking. There's not much to regret.
    They work just FINE, and no one ever sees the ugly misaligned ferrules anyway. Only my groin sees it.
    Ironically, on one of them, I went back to top-loading anyway, but can't remember why! So don't expect a drastic improvement, but you never know.
    The majority consensus here...well, I think it's the majority...is that there's not much of a difference, but you gotta do what you gotta do, like I did.
  14. bgmacaw
    bgmacaw Tele-Meister
    410
    Feb 11, 2006
    Near Athens GA USA
    You can do this but there can be fit issues.
    For example, on my Rondo SX Tele copy I installed one several years ago. As you can see in the photo, I had 3 holes from the original bridge that had to be filled in and I ended up with a "butt crack" where the bridge pickup rout had to be extended slightly and the pickguard doesn't fit well. I'm OK with it because it sounds really good but it does have a certain funky, homemade-ish, look.
