Removing Poly from guitar body
Discussion in 'Tele-Technical' started by Webfoot, Mar 30, 2012.
  1. Webfoot
    Webfoot Tele-Holic
    Oregon
    Just hypothetically speaking...
    If I had a Baja tele body and wanted to strip the paint down to the wood...
    1) How would I do this (chemicals?, chisel? sanders?)
    2) How long would it take?
    3) What would the body wood like?
  2. Mightyaxeman
    Mightyaxeman Tele-Afflicted
    Pennsylvania
    Heat gun and paint scrapper. I've heard a damp rag and an iron will do the trick but I've never tried it.
  3. wemedge
    wemedge TDPRI Member
    Victoria, Vancouver Island, Canada
    Not a Baja, but a 'MIM '50s:
    May be atypical- the finish started to lift in some spots so I just used a pick and carefully lifted pieces of the finish off the body. After that I sanded down the pore filler that was left with 220 grit. I plan to refinish with wipe on poly.
    Mine turned out to be a 3-piece body, nice grain.
    wemedge
  4. Webfoot
    Webfoot Tele-Holic
    Oregon
    wemedge... did you use a heat gun to strip the paint?
    what kind of heat gun?
    nice looking wood.
  5. cband7
    cband7 Friend of Leo's
    Thule, Greenland
  6. Webfoot
    Webfoot Tele-Holic
    Oregon
    cband7... thanks... great link
    So when done, you don't end up with mega burn marks that can't be sanded out?
  7. wemedge
    I did not use a heat gun. The finish just flaked off, for some reason.
  8. Webfoot
    Webfoot Tele-Holic
    Oregon
    wemedge... you mean you didn't do anything to the guitar and the paint just started peeling off?
  9. wemedge
    Right. I first noticed that the paint had lifted where the neck plate sat. I tried to glue it down but it lifted again, so I started picking at it. I wanted to remove it anyway because the finish was so thick! After that it started coming out pretty much in flakes and big pieces, like an M&M shell. Maybe the surface of my tele wasn't properly prepared before painting?
    wemedge
  10. brians356
    brians356 Tele-Meister
    Reno, NV
  11. Vizcaster
    Vizcaster Friend of Leo's
    Glen Head, NY
    I think cband7's link is a little misleading where the "job" of the particulate mask is concerned. We need to be clear that such a mask is useful when there is dust in the air, and of course there can be when scraping off paint chips. The issue of fumes coming off of softening paint is entirely different, and they'll go right through a mask like that. Unless you've got plenty of fresh air circulating, I'd be using a cartridge respirator, not a dust mask.
    Having said that, a heat gun is definitely the way to go. Such a shame no one has ever recommended it on any other threads here...
  12. Webfoot
    Webfoot Tele-Holic
    Oregon
    Any maximum temp for heat gun suggested?
    When I googled it they range from 500F to >1000F
    Single settings, multiple settings
    Kind of like a soldering iron... high wattage for big metal but l5 watts for small components. So I know I don't want to over 'cook' things.
    Gun model suggestion for those that have done this before with success?
  13. KokoTele
    KokoTele Doctor of Teleocity Vendor Member
    albany, ny [not chicago]
    Go for a higher wattage gun with a low heat setting. Start someplace that's not so noticeable, like on the back near the rear strap or something. You'll want to learn to get the paint hot enough so that it bubbles and lifts, but not so hot that you scorch anything. Little wisps of smoke are the beginning of scorching.
    Polyurethanes soften and melt a little as they warm, which is why it's best to get the paint to bubble away from the surface. Then you just get the corner of your scraper under the edge of the bubble and lift it away. If you're scraping the paint from the surface you'll be pushing gooey paint around, which will leave an uneven paint residue on the surface that you'll have to sand.
    If you're careful while you do it, you won't have any problems.
  14. brians356
    Reno, NV
    Look at that Stew-Mac Trade Secret article. He's learning as he goes. Don't apply too much heat to start, and never in one spot for long. Heat, probe, heat some more, probe etc until you see the film softening and starting to lift. Get a scraper under it, start loosening it and heating as you go. You will soon get the hang of it and start making fast progress. There's not way to figure it out except by diving in and being cautious to start.
    I don't think that film is going to gas unless you get it way too hot, enough to melt or scorch it. I personally wouldn't bother with a respirator.
    Brian
