removing knobs and switch tip
Discussion in 'Stratocaster Discussion Forum' started by big jimmy, Feb 20, 2005.
  1. big jimmy
    big jimmy Tele-Holic
    908
    Feb 10, 2004
    Melvis, TN.
    want to change out my pickguard. whats the best way to remove knobs and switch tip without damaging anything?
  2. kickz28
    kickz28 Tele-Holic
    752
    Jan 1, 2004
    Gaspe, Quebec, Canada
    The knobs: Use two spoons to pry them off.
    The switch tip: pull on it.
  3. paulh
    paulh TDPRI Member
    61
    Apr 25, 2003
    Southside VA
    removing knobs
    I loop string under the knobs to pull them off without scratching the pick guard.
  4. Frank Roberts
    Frank Roberts Tele-Meister
    232
    Another old trick for removing Strat knobs is to wrap a cloth, like a polish cloth or old T-shirt, under the knob and pull straight up.
  5. big jimmy
    908
    Feb 10, 2004
    Melvis, TN.
    2 spoons
    used the 2 spoonmethod, works great.
  6. photoweborama
    photoweborama Friend of Leo's
    Dec 16, 2003
    Sacramento, CA
    I put a screwdriver under the knob, and then slip a pick under the screwdriver. Then pry up. Rotate the knob and repeat.
  7. mike_levitt
    mike_levitt Tele-Meister
    316
    Nov 13, 2004
    Rob DiStefano invented a great method that I've been using that's even more gentle than the spoons.
    Take an old leather belt, and cut about a 3" slit right through the middle - lengthwise. Then just thread the knob into the slit - like a buttonhole, and pull straight up.
    It works great, and is totally non-invasive.
    Thanks Rob!!!!!
    Mike
