Removing dried lacquer from frets
Discussion in 'Finely Finished' started by sleazy pot pie, Aug 26, 2016.
  1. sleazy pot pie
    sleazy pot pie Tele-Holic Gold Supporter
    752
    May 31, 2014
    austin
    I sprayed a neck using ace hardware clear lacquer. It has been atound 45 days and i am now wet sanding. I should have removed the lacquer from the frets while it was still softer, but did not.
    What is the best way to remove it now that it is harder than a math teachers heart?
    Tape off the board and qtip lacquer thinner?
  2. Flakey
    Flakey Friend of Leo's
    0000 steel wool and tape the fret board before.
    xafinity likes this.
  3. Blue Bill
    Blue Bill Poster Extraordinaire
    Feb 15, 2014
    I use 0000 steel wool, with these fretboard protector thingys:
    http://www.philadelphialuthiertools...s/fingerboard-protector-fret-guards-set-of-2/
    The most important thing about steel wool is to keep it away from your pickups!!!!! Take the neck off, or really cover the pickups well with masking tape!!!!!!! The steel wool fibers will stick to the pole pieces like dog mess on a shoe, and are nearly impossible to clean off.
  4. ponticat
    ponticat Tele-Meister
    211
    Jan 11, 2008
    Alexandria, Virginia
    JayFreddy and songtalk like this.
  5. Wally
    +1 on the tape off...using pinstriping tape. There is no reason why one should have to back to the frets to remove any lacquer, ime.
    Since you are there, though.... IF you use steel wool, please tape off around and on top of the pickups to prevent steel wool from becoming part of the pickups. Then, use some fresh tape to gather the accumulated wool bits that will be magnetically attracted to those magnets before you pull the tape off of the pickups. I dislike 'make work'. (;^)
  6. Tony Done
    Tony Done Friend of Leo's
    Dec 3, 2014
    Toowoomba, Australia
    I would use a fret mask*, as shown above, and scrape it off with something just a bit softer than the fret itself, a copper coin or piece of shim brass, for example.
    * I make them from aluminium drink can, which can be cut with ordinary scissors.
    JayFreddy and dkmw like this.
  7. moosie
    Jul 18, 2010
    Western Connecticut
    I would avoid the steel wool mess by wrapping a micromesh sheet around two fingers, and then rubbing them vigorously across the frets, the long way (bumpity bumpity bump). Tape the board first, of course. Scale the MM to go from something coarse enough to remove the lacquer, all the way to 6000-12000 for a fine polish.
  8. sleazy pot pie
    752
    May 31, 2014
    austin
    Lots of great info. Thanks.
    This is the first time i have used the ace hardware lacquer. It is great so far. Really easy to sand, minimal orange peel. I buried a waterslide decal with it on a neck plate and left that out in the sun for a week and the neck plate looks like gold instead of chrome, so it will amber nicely over time or with direct sunlight. Plus its cheap too at 7 bucks a can.
  9. Blue Bill
    Feb 15, 2014
    Pictures, please.
    Castercrazy likes this.
  10. sleazy pot pie
    752
    May 31, 2014
    austin
    I will post some later today when i get home. I cut an import paddle headstock into a snakehead shape. It turned out pretty good for not using a template. Its not perfect. The sides arent perfectly even to eachother, but unless you have a really sharp eye, you wouldn't notice. I am not totally happy with the color, it is a little too orange, but not chinese neck velveta orange.
  11. dkmw
    dkmw Tele-Afflicted Silver Supporter
    Mar 30, 2016
    Florida USA
    I'm glad I'm not the only one making fret protectors out of aluminum cans!
  12. sleazy pot pie
    752
    May 31, 2014
    austin
    I like this idea. Do you just cut the can with scissors and then do the same for the opening for the frets? Do you need to sand the edges of the can to dull them?
  13. flyingbanana
    flyingbanana Poster Extraordinaire
    If the finish is fresh, score on either side of frets and peel off. Gotta be fresh though....like a fresh Georgia peach.
  14. sleazy pot pie
    752
    May 31, 2014
    austin
    Yeah, we are way past that point.
  15. Tony Done
    Dec 3, 2014
    I just cut them out to the size of the stewmac ones in the pics. I cut them with one end open, because it is much easier, then close the open end with a few thickness of tape. I flatten the pieces, but I've not found any reason to smooth off the edges. If I did, I would likely just put some tape on them rather than try using abrasives.
  16. dkmw
    Mar 30, 2016
    Florida USA
    I just cut two strips (one for each side of fret) and tape the ends together, that way I can determine the ''slot'' more precisely. Like Tony said, the edges are surprisingly benign but I feel better taping over the corners on the ends.
  17. sleazy pot pie
    752
    May 31, 2014
    austin
    Sounds good. Going to give it a shot. Sounds like i need to stop for a tall boy on my way home.
  18. dkmw
    Mar 30, 2016
    Florida USA
    Like this....
  19. Tony Done
    Dec 3, 2014
    Mine looks the same, except only one end has tape, and it would be a VB can.
    dkmw likes this.
  20. PinewoodRo
    PinewoodRo Tele-Afflicted
    That's great! It combines my two favourite activities...
    dkmw likes this.
