Refret a Squire Affinity neck
Discussion in 'Squier Tele Forum' started by 1954 Esquire, Nov 29, 2018.
  1. 1954 Esquire
    1954 Esquire TDPRI Member
    13
    Nov 10, 2016
    Panama City, Florida
    Going to try my hand at refretting a Squire Affinity neck and would like to know if anyone has experience doing one of these. My biggest question is would the pre-bent medium jumbo frets that Fender makes work. Doing this with minimal tools and want to keep from having to re-cut the fret slots.
  2. RodeoTex
    Sep 14, 2005
    Nueces Strip
    Warmoth also has prebent fretwire which is very good. Don't know about the Fender wire.
    Doing it with minimal tools will surely help you buy more tools in the future.
    Nightclub Dwight likes this.
  3. Ira7
    Ira7 Poster Extraordinaire
    Jan 8, 2008
    Coral Springs, FL
    Now THAT'S funny!!!
  4. gip111
    gip111 TDPRI Member
    37
    May 5, 2016
    New Jersey USA
    Go for it. I have done dozens of refret jobs with minimal tools, some files, a semi homemade fret puller and a rubber mallet to tap the frets in, I like the Fender fret wire sold at Sam Ash. Lots of good info on the net on this topic, I do have to tell you to do your research, there is a little more than just pulling frets out and installing new ones but it is not rocket science. I've done many Fenders and Squiers with Fender wire.
  5. preactor
    preactor Tele-Meister
    292
    Nov 27, 2009
    gainesville, ga
    If you are not worried about hurting the neck and wanting to learn how, it is a perfect opportunity.
  6. jvin248
    jvin248 Poster Extraordinaire
    Apr 18, 2014
    Near Detroit, MI
    Use a soldering iron and solder under the tip on top of a fret to heat any glue (and finish if maple fretboard) to release the old fret.
    Use end-nipper pliers ground flush or those side cutters with a hole you drill in to let the fret wire through as you lift the wire out.
    then this going back the other way.
    http://www.tdpri.com/threads/fret-leveling-yer-tele-101.201556/
    gip111 likes this.
