Recommend me a BRAND of Small Allen Wrenches
Discussion in 'Tele-Technical' started by micpoc, Dec 1, 2018.
  1. micpoc
    micpoc Friend of Leo's
    Louisiana
    Most of the smaller ones that I actually use were pretty cheap to start with, and all their edges have worn down enough that making saddle adjustments and the like is problematic, so I'd like to get a decent set - down to a .05 - that will last for a good while (I am actually pretty good at holding onto them, oddly enough). Amazon as a source is preferred, but I'll certainly consider other dealers.
    Also, is stainless steel the way to go, or is there something better for Allens?
    Chicago Matt likes this.
  2. Finck
    Finck Tele-Afflicted
    São Paulo - Brazil
    I have never found Allen wrenches that last too much, no matter how expensive they were. Nowadays, I'm happy with the cheapest I can find in the tool store near home, and just change them when needed.
    Fuelish and micpoc like this.
  3. Chicago Matt
    Chicago Matt Friend of Leo's
    Woodstock
    I need the same. Looking forward to some more replies.
    micpoc likes this.
  4. Old Tele man
    Old Tele man Friend of Leo's
    Tucson, AZ
    German-made WIHA #26491 Precision Hex-Ball set (hex metric sizes: 1.3, 1.5, 2.0, 2.5 & 3.0) available in USA.
    Jim603 likes this.
  5. Tempus_Fugit
    Tempus_Fugit TDPRI Member
    SW Michigan
    Yes most of them are cheaply made.
    But...you can grind a little bit off the ends to freshen them up.
  6. CK Dexter Haven
    GCDB
    I had a set of Eklind for years untill they were stolen, replaced w/ Crafstsman, which were Ok at the time but I probably wound't buy again, based on the recent reviews. Still have them, but they live in the car box. I have a set of small sizes from Dollar Tree of all places that I use for saddles & such, and a larger T handle set from Harbor Freight. If I was working on other peoples stuff for a living, I would be asking the same question you are.
    micpoc likes this.
  7. Hags
    Hags Tele-Meister
    Northwest CT
    Wera is another German company, I've been using there tools for years without a complaint
    Piggy Stu, loco gringo and micpoc like this.
  8. drf64
    drf64 Poster Extraordinaire Silver Supporter
    Ada, MI
    harbor freight.
    DonM, bluesky1963 and micpoc like this.
  9. dsutton24
    dsutton24 Doctor of Teleocity Ad Free Member
    Illinois
    Cheap allen wrenches are horrible things. Good allen wrenches are relatively cheap. Look for Allen, Bondhus, Elkind, Wera, Wiha. Don't buy ball end wrenches, especially for adjusting trussrods.
  10. kelnet
    kelnet Telefied Ad Free Member
    Port Moody, BC
    What does Ikea use?
    Rusty Stauffer likes this.
  11. Chunkocaster
    Chunkocaster Friend of Leo's
    In space with Ziggy
    Just order them in bulk. You can probably get 20 sets for a few bucks on fleabay.
    I buy small drill bits like that and just throw them away when blunt and use a new one. It works out cheaper than buying expensive bits.
    micpoc likes this.
  12. bender66
    on my bike
    Any will do as along as they're hardened. The thing with using cheap ones is as the become rounded they also misshape your head.
    I've got a bunch of sets from Park Tool from years of bike work. You can get then at any bike shop.
    telemnemonics and micpoc like this.
  13. Papa Joe
    Papa Joe Friend of Leo's
    Swanton Ohio
    Just buy any of them and have a grinder handy..
    micpoc and drf64 like this.
  14. mefgames
    mefgames Tele-Afflicted Platinum Supporter
    North Bay, Ca
    micpoc likes this.
  15. The Ballzz
    The Ballzz Tele-Afflicted
    Las Vegas, NV
    I've found the junk from Harbor Freight to be about as good as most. The trick is to take your digital caliperwith you or at least use it as soon as you get them home. :eek: Those youngsters who put them in the packages/holders rarely get them all correct, especially on the smaller sizes! :rolleyes: The grinder is certainly your friend here, in the long run! ;)
    And thanks @mefgames for that review link and to all the mentions of brands I've not heard of before! I'm a card carrying "Tool Junkie" and really appreciate good items!
    Just Sayin'
    Gene
    micpoc likes this.
  16. Telecasterless
    Telecasterless Tele-Afflicted
    los angeles
    +1 on bondhus. It was the only wrench that would tighten a nut where I only had a few degrees of room to turn it, and the wrench didn't flex so I could actually tighten the screw.
    micpoc and DugT like this.
  17. Brokenpick
    Brokenpick Tele-Afflicted
    Dixie
    Why is this?
    micpoc likes this.
  18. DugT
    DugT Tele-Holic
    northern CA
    micpoc likes this.
  19. dsutton24
    Illinois
    Ball end wrenches are used for running screws in and out after you've broken them loose with a conventional allen wrench. You don't use them on anything that requires any torque to speak of. The ball ends tend to snap off, and when they do snap off they often wedge in the screw. Ball ends have much less bearing surface than conventional allen wrenches, they cam out easily, also damaging the screw.
    You don't want to use ball end wrenches on trussrod nuts. Partially because of the torque need to turn a trussrod screw, see above. Mostly because the broach in a Fender trussrod nut is shallow, and a ball end doesn't seat very deeply in the nut. It's very easy to damage the nut to the point that it's useless.
    I know StewMac sells ball end trussrod wrenches. They're in the business of selling replacement hardware and specialty tools to replace hardware damaged by improper tool use. It's kind of ironic in a way.
    telemnemonics, Tuxedo Poly and micpoc like this.
  20. micpoc
    Louisiana
    telemnemonics and DugT like this.
