Rangemaster trouble?
Discussion in 'Pedal/Effects Owners Clubs' started by DucDone, Feb 11, 2019.
  1. DucDone
    DucDone TDPRI Member
    65
    Apr 9, 2011
    Bergen
    Hi. I am trying to put together this Rangemaster, I get sound, but it's almost like a no booster, very low. Does anyone see a probable cause for this in the picture? I have built it twice, same result. (I am using a SFT308 transistor. The base seems to be the one in the "middle", at least that's the only place there is sound. It's seems difficult to find a proper diagram for it.) The only thing that I might be unsure about, is where the grounding goes, the pic doesn't say. I have taken a ground from the input jack to the strip ground point an another from the same jack to the ground on the other jack. Ok or not?
  2. fraser
    fraser Tele-Holic
    902
    Sep 8, 2007
    Hamilton, Canada
    Are you getting correct voltages at the transistor?
    My first build was the range master.
    For a simple circuit it caused me much frustration.
    Sounds like the transistor is passing signal but not turning on.
    I would check it’s voltages.
    Did you just follow the schematic for part values?
    The collector resistor May need adjustment,
    I use a pot there to determine the correct value.
    Maybe the transistor is faulty or unable to bias correctly as well.
    If you haven’t already, check out the geofex.com article
