Quick pickup wiring question
Discussion in 'Tele-Technical' started by mherrcat, Sep 9, 2017.
  1. mherrcat
    mherrcat Tele-Meister
    447
    Dec 12, 2013
    California
    Twist or don't twist leads between pickup and switch/controls?
  2. sjtalon
    sjtalon Poster Extraordinaire Ad Free Member
    Well, whatever you prefer, but twisting them means nothing.
  3. SPUDCASTER
    SPUDCASTER Poster Extraordinaire Platinum Supporter
    Just looks cleaner to me. as sjtalon sez, no benefit from doing so.
    I braid the ones with three wires, usually the neck pickup.
    If you feel it makes a difference, other than aesthetics, then do it.
    But I'm sure we'll hear more on this one.
  4. dsutton24
    dsutton24 Poster Extraordinaire Gold Supporter
    Dec 29, 2010
    Illinois
    There are those who believe that wire twisting is a good noise reduction technique. I'm not one of those. Or is it they?
    At any rate, I do twist, but it's just for wire management.
    Huddy likes this.
  5. mherrcat
    447
    Dec 12, 2013
    California
    Only two wires on each p/u. Neck p/u cover appears to be grounded via the ground wire from the p/u winding.
    One final unexpected question. There was no separate ground wire from the bridge plate, but the bridge p/u has a metal base plate that is grounded via the p/u ground wire and I assume electrically connected to the bridge plate via the three p/u mounting screws. Any need for a separate bridge plate ground wire if the replacement p/u is configured the same way? (I'm thinking "no.")
    FYI I am replacing the stock Baja pickups/selector/S1/tone pot with different pickups, standard controls and 3-way switching.
  6. sjtalon
    Winner winner !!!
  7. mherrcat
    447
    Dec 12, 2013
    California
  8. Huddy
    Huddy Tele-Meister
    305
    Nov 5, 2016
    Newport News, VA
    You're all good. I twist all wire groups (each pickup has own twist) for wire management and it keeps them just a smidge longer and easier to reuse in a future swap.
