Join TDPRI Today
Quick! opinion on which TOM
Discussion in 'Tele Home Depot' started by Bentley, Jan 4, 2013.
  1. Bentley
    Bentley Friend of Leo's
    Jul 25, 2012
    Kelowna B.C, Canada
    Okay, if you've been watching my Firecaster build then you'll know I'm in need of a new bridge because I wrecked the other one.. I figured I'd just replace the whole thing because It's a five dollar chinese one. I'm just wondering what you guys like, Conventional TOMs or rolling toms? I think I might go with the rolling one, since it locks somewhat. I don't think that the cheaper ones really are any different in quality from say wilkinson.. Idk, but It's either one of these, I'm not spending a tonne of money. And do you think both insert are the same size?
  2. R. Stratenstein
    R. Stratenstein Doctor of Teleocity
    Aug 3, 2010
    Loganville, Ga.
    Unless you're going to use a Bigsby or other whammy bar, I don't see much point in using a roller bridge. Conventional bridge will give you more solid coupling with the body, and in theory, perhaps a bit more sustain, plus more likely to intonate more easily and stay that way. With a cheapo bridge, no telling if the inserts are the same size. If it was sold as a replacement for Gibby TOM, it should have the same center-to-center measurement, and the same thread pitch, but as far as fitting in the holes you've already drilled--?????
    Good luck with it. You're a real trooper, keep after it
  3. Bentley
    Jul 25, 2012
    Kelowna B.C, Canada
    I bought the one i had before. And a new stop bar.. The screws annoyed me. I'll use the messed up screws until i actually finish it. Anywho, i figured out none of the rolling briges had a 52 mm spacing... So my whole design would have been off. Thanks for the reply, yeah the rolling bridge was useless. I just do a lot of bending, but realistically its not going to move it that much. Snowboarding tomorrow, so no updates.
  5. Picton
    Picton Friend of Leo's
    Feb 7, 2009
    Reading, Massachusetts
    The cheaper, non-rolling Gotoh TOM that StewMac sells is an excellent bridge. I've used it many times with no complaints.
  6. Barncaster
    Barncaster Poster Extraordinaire
    Feb 3, 2010
    Santa Rosa, CA
  7. Bentley
    Jul 25, 2012
    Kelowna B.C, Canada
    If I encounter problems with this bridge, then I'll replace it, it's only 5 bucks, so that's why I'm not too worried.
  8. Nick JD
    Nick JD Doctor of Teleocity
    How's Big White?
  9. Cat MacKinnon
    Cat MacKinnon Friend of Leo's
    Nov 13, 2011
    Colorado
    ^this. it's hard to go wrong with Gotoh. i also like that Gotoh because it doesn't use that annoying retainer wire that seems to cause more problems than not.
    keep in mind that most of the Wilkinson bridges are actually made by the same Korean company that makes a lot of the "budget" bridges (Sung-Il is the manufacturer.) unless it says "Wilkinson by Gotoh", there's really not going to be much of a quality difference. i'm certainly not saying the Wilkenson stuff is bad (in fact most of it is a pretty good deal), just that Trev Wilkinson licenses his name and designs to several different factories.
  10. GigsbyBoyUK
    GigsbyBoyUK Friend of Leo's
    Apr 30, 2008
    Peterborough, UK
    I always use cheap no-brand tunomatic style bridges (but from a retailer I trust) and they work fine. Once, after about three years, one saddle started to rattle and I just changed the bridge altogether since it was not expensive. I use the Nashville type as I like the extra room for intonation adjustments.
  11. guitar2005
    guitar2005 Tele-Holic
    710
    Oct 22, 2010
    Canada, Québec
    Agreed.
