Putting together a Pinecaster
Discussion in 'Tele Home Depot' started by wemedge, Mar 4, 2012.
  1. wemedge
    wemedge TDPRI Member
    Victoria, Vancouver Island, Canada
    Hiya all:
    Just got this off ebay:
    and will use this neck:
    What do y'all think of the body? I plan to finish it with a transparent, clear, slightly amber finish, sealing with de-waxed shellac.
    I don't know the build quality of the body yet, but I got it pretty cheap, so am taking a chance. I love the knots and imperfections.
    cheers
    wemedge
  2. Suttykins
    Suttykins Tele-Meister
    United Kingdom
    This is exactly what I've been thinking about doing recently, knock together a really stripped down but well playing pine esquire.
    That body looks great.. going to be a looker for sure.
    I'm keeping my eye on this one, good luck! :D
  3. wemedge
    Thanks!
    I've got a bakelite pickguard, Callaham compensated brass saddles, Fender bridgeplate, and a set of Fralins (I know it's an Esquire neck :D, but I'll go tele for now). Also have a set of Fender OV pickups, not sure which ones to go with yet.
  4. tommym1
    tommym1 TDPRI Member
    Connecticut
    Looks great, nice grain lines! Should sound as good as it looks. Looking forward to it finished...
  5. Bush Wiebe
    Bush Wiebe Tele-Meister
    Manitoba, Canada
    YES! I love it!! Good luck with the build, I'll be watching :D Looks a bit like mine. Sooooo good!
  6. wemedge
    Thanks for posting yours! Very nice, without a pickguard. How did you do your finish?
  7. Glen Smith
    Glen Smith RIP
    That looks like a pitch pocket on the back. If it is, you will want to seal that very well so it doesn't bleed through the finish.
  8. wemedge
    Thanks, what do you suggest. I was going to use de-waxed shellac to seal.
  9. Glen Smith
    Glen Smith RIP
    No pro here, I used shellac on pine pitch pockets on an outdoor structure and the stain peeled off in those areas after just one year. I will be checking to see what solution is proposed by those with experience.
  10. crazydave911
    East Tennessee
    You are planning on putting the shellac under the finish, right? De-waxed shellac is a primer/sealer. Seal the pitch pocket/knot with water thin CA (superglue), then it won't bleed through :)
  11. Bush Wiebe
    Manitoba, Canada
    Mine was finished with a hand-rubbed amber wood dye. Unfortunately, I don't have any skill with these kinds of things and I had mine built for me, so I won't be much help to you except to sit by and watch jealously:D. Would love to do my own someday though. But that amber dye looks beautiful, it turned out very blonde. I'm very happy with mine.
  12. wemedge
    Correct. Using a harder finish on top of the de-waxed shellac. Thanks for the superglue suggestion also!
    wemedge
  13. wemedge
    Well, the body arrived today. I've started the prep. It need fine sanding, sealing, etc. Checked measurements, fit and finish; all is good. Neck pocket fits the neck just fine.
    I'm probably a freak, but I really like the imperfections, esp the mineral streak. Sealing the pitch pocket and mineral streak now with de-waxed shellac. I plan to do a clear poly on top. Going to be a pretty rustic pine tele.
  14. wemedge
    Done for now!
    Put a bone nut on the Esquire neck, dressed the frets for a falloff on the higher registers.
    I'm not happy that the ferrule holes were not drilled straight, but since the body was really cheap, I can put up with it for now (will rectify that in the near future, probably with a tone bar). What a shame, because it is a really nice sounding guitar. I would have scrapped it and gone for another body otherwise.
    In the meantime, I'll tell myself that it's vintage-correct, like the butt-crack. :D
    Sorry for the crappy pics (no camera this weekend):
    It's no Kirn, but it will serve me well until I get one.
    wemedge
  15. Bush Wiebe
    Manitoba, Canada
    Yeah baby! Love it!!!
