Push Chords
Discussion in 'Bad Dog Cafe' started by Lowthesd, May 21, 2019.
  1. Lowthesd
    Lowthesd TDPRI Member
    Chugiak, Alaska
    I am working on getting push chord down (they show up as a tie in music notation), but how I have been looking at them as say on a 8th note or 16th making the change on the ‘and’ of 4 or in 16ths the and or the ‘uh’ (but last strum of the measure before the new chord. I have heard Laurence Juber discuss then like there are many ways to do these pushes. Is there a jazz or well versed person out there that can help
    Thanks
    Sean
    Sean
  2. Lowthesd
    Chugiak, Alaska
    Since I can seem to add/edit I will reply to my own post. To. Clarify my post, The last beat of a measure if its a measure of 8th notes I have been adding an extra 16th note extra strum where I make the change, essentially say dotting the final 8th note to add in the final strum as a 16th as the chord change to make the change pushed into the measure before the measure with the new chord...
    Anyway that’s the premise
    Sean
    Sean
  3. E5RSY
    E5RSY Poster Extraordinaire
    Georgetown, TX
    You need to have this moved to the appropriate forum. You'll get better responses.
  4. Lowthesd
    Chugiak, Alaska
    I was trying to figure out which forum that would be, I am very happy to take a suggestion to help on this, on which forum is best. Thanks for the reply I appreciate the help
    Sean
  5. Lowthesd
    Chugiak, Alaska
    I’ll move it to the writers block
    Sean
  6. Mark the Moose
    Mark the Moose Tele-Meister
    Erie, CO
    If I understand your question, this is really a rhythm exercise in which you land a chord on the final 16th of the measure instead of the following downbeat. Here's an idea:
    1. Start by practicing simple chord changes ON the beat with a metronome clicking on the beat.
    2. Same progression/placement of chords, but with the metronome on the fourth 16th of each beat. FYI: this is difficult. It will make you very aware of the inside of the beat. Then try pushing one of those chords a 16th early without losing the beat.
    If you are strumming be consistent with your downs and ups, so your downstrokes happen at the strong 8th note level and the upstrokes happen with the off 16ths.
    Lowthesd likes this.
  7. Lowthesd
    Chugiak, Alaska
    Yes it is a rhythm exercise. Thanks for having the insight to recognize that as my post lacked that. Thank you for your reply. that is how I mostly understand them, and your practice tip is excellent, thank you
    They show up as ties in notation
    Sean
  8. E5RSY
    Georgetown, TX
    Tab, Tips, Theory and Technique
  9. Lowthesd
    Chugiak, Alaska
    I have moved this post to tab-tips theory and technique
