PT Primary Switching/Fusing
Discussion in 'Shock Brother's DIY Amps' started by muswell_hillbilly, May 20, 2019.
  1. muswell_hillbilly
    muswell_hillbilly Tele-Meister
    Greenfield, WI
    I'm still new to this amp-building obsession, so I apologize in advance if I'm walking down a well-worn road...
    Regarding PT primary switching/fusing, shouldn't both be on the "hot" conductor? On a different thread, I found myself reviewing a Mojotone 5F1 schematic, and found this:
    Then I looked around a bit more and found this on their 5F2A schematic:
    Aren't these both wrong? Shouldn't the switching/fusing be on the "hot" conductor? (I really hope I'm not poking some hornet's nest with this question)
  2. muswell_hillbilly
    Greenfield, WI
    Here's my thinking (which may be completely wrong): in both cases above, the return path is interrupted, but the source remains (potentially) active (no pun intended).
    With an active source looking for a return path, I'm a potential candidate, however remotely.
    If the source path is interrupted, the return path is looking for a source, and I believe I'm a poor candidate (been a long time since my wife called my "hot")...
  3. VintageSG
    Yorkshire
    Why not interrupt both and be certain?. The switches don't cost much, and it's better than being zapped. I'm fairly certain it's a requirement in Europe, and it makes sense to me.
    Paul-T, muswell_hillbilly and Wally like this.
  4. Wally
    Switch both hot and neutral...run the hot through the fuse as VintageSG shows us.
    Paul-T, Nickfl and muswell_hillbilly like this.
  5. Nickfl
    Nickfl Tele-Afflicted
    As mentioned it ideally should be both, pretty sure UL listing requires it too. But if you are right that if you're doing a spst it should definitely be on the hot side.
    There is some argument over the order of the fuse and switch too. I do mine power cord hot -> fuse -> switch -> PT. The theory is that way if the fuse blows it isolates as much of the circuit as possible from the mains power.
  6. corliss1
    Lansing, MI
    Yes, those are both wrong. Every time we mention this to Mojoton they say "we try and keep things vintage correct." Yeah, well.............
    Modern "real" companies break both hot and neutral, as I believe that is required in Europe and elsewhere. American stuff you'll see one of the following:
    live side >> fuse >> switch >> one side of PT. Neutral to other side of PT
    or
    live side >> switch >> fuse >> one side of PT. Neutral to other side of PT
    People argue it both ways, fuse or switch first, all the time.
    muswell_hillbilly likes this.
  7. muswell_hillbilly
    Greenfield, WI
    Hmm - bloodletting was once a "cure" ;)
  8. Finck
    Finck Tele-Afflicted
    São Paulo - Brazil
    Break hot and neutral is always safer, because there are faulty electrical installations in what a potential exists between neutral and ground.
    The fuse always goes in the hot wire, because in the case of a short circuit, the current will probably returns through ground wire, so a fuse in the neutral wire will be useless.
  9. FenderLover
    FenderLover Friend of Leo's
    Minnesota
    That 'vintage correct' crap has really run its course. I wish people would accept that many things have been learned in the last lifetime.
    If vintage correct is so important, do they also wire their heaters with one wire? If not, why? It takes conviction to be wrong and stand by it.
    Bill Moore, Paul-T, Wally and 2 others like this.
