psud2 little help please
Discussion in 'Shock Brother's DIY Amps' started by arcticbreaze, Dec 6, 2017.
  1. arcticbreaze
    arcticbreaze Tele-Meister
    123
    Aug 2, 2014
    Oamaru NZ
    trying to work out power supply for scratch amp, how much current do two 12ax7s draw at 200 volts.
    or better still how do I work this out.(give a man a fish...)
  2. Fiat_cc
    Fiat_cc Tele-Holic
    510
    Oct 8, 2016
    Melbourne, Australia
  3. arcticbreaze
    123
    Aug 2, 2014
    Oamaru NZ
    D'tar can you use that calculater for a trany with no center tap
  4. D'tar
    D'tar Tele-Afflicted
    Jan 11, 2013
    WNY
    Select diodes as rectifier type
  5. arcticbreaze
    123
    Aug 2, 2014
    Oamaru NZ
    Ok that tells me my trany is almost overkill.
    but i still have to work out how to use the Duncan amps power supply designer to work out the correct resistances to get my voltages in spec
  6. clintj
    clintj Friend of Leo's
    Apr 4, 2015
    Idaho
    https://robrobinette.com/Drawing_Tube_Load_Lines.htm
    If you can learn from here to figure out the operating point based on your component values, you can figure out the current draw for any tube at any voltage.
    Here's your fishing pole. :)
    A quick guesstimation number for a 12AX7 is about 1ma per triode (or 2ma per tube).
  7. arcticbreaze
    123
    Aug 2, 2014
    Oamaru NZ
    ok this is for an ultra linear el84pp build pre amp either 18watt lite or 5e3 not sure which yet.
    using c2 as B+ to OT and c3 as B+2 feeds to 2 12ax7's
    Just trying to work out components ahead of time instead of trial and error like I normally do.
