PSU Designer Help
Discussion in 'Amp Tech Center' started by funandfunny20, Jun 9, 2019.
  1. funandfunny20
    funandfunny20 TDPRI Member
    Southern CA
    Hi Folks,
    Building another amp. Trying to calculate the power supply.
    I'm confused about the source impedance. When I input the secondary DCR (per hammond's spec sheet, http://www.hammondmfg.com/pdf/EDB269JX.pdf) in the source impedance calculator, I'm getting voltages much lower than I would expect. Am I doing this wrong? Trying to get 350v on the first B+ node.
    Am I doing something wrong? I don't have the transformer yet, so I can't measure the secondary DCR myself.
  2. trobbins
    trobbins TDPRI Member
    Melbourne
    The HT secondary resistance in the PSUD2 model refers to half the total V-CT-V resistance, as the V-CT resistance is the current path resistance for a full wave rectifier configuration.
    So replace 350 ohm with 175 ohm.
    funandfunny20 likes this.
  3. funandfunny20
    Southern CA
    thanks! that worked perfectly.
