Princeton Reverb 2x10?
Discussion in 'Amp Central Station' started by Mark the Moose, Apr 24, 2019.
  1. Mark the Moose
    Mark the Moose Tele-Meister
    Erie, CO
    Planning a build for this summer! Thinking Princeton Reverb with upgraded Allen transformers and a 2x10 cab. Now I know many purists will say that underpowered trannies and a 1x10 are what give a PR its charm, but I'm wondering if any of you have built or upgraded your PR to something along these lines and what the outcome was like.
  2. thunderbyrd
    thunderbyrd Poster Extraordinaire Silver Supporter
    central ky
    I have a prri that was put into a head then runs through a 2x12 cab. I am not as knowledgeable and experienced with amps as most are here, so all I can tell you is I think it sounds great.it loves any guitar. certainly not "boxy" sounding at all. a 2x10 would surely sound very fine.
    nojazzhere likes this.
  3. nojazzhere
    Foat Wuth, Texas
    Not what you're asking, I know, but I had a 1964 Princeton (non reverb) that I put a 12" Jensen in.....and it sounded wonderful.
  4. Snfoilhat
    Snfoilhat Tele-Holic
    Oakland, CA
    Last year I built a 2 10" open back combo cab to fit a Princeton reverb chassis (18.375" wide cutout). Eminence 1058-alike speakers. Surprisingly light weight and sounds good.
    I haven't listened to it with any 15ish watt amp yet, only a 5ish W and a 2ish W (both built in PR chassis).
    Go for it. If you like the sound of a PR you likely can't lose, unless the combo's weight or dimensions pass your personal threshold for too much. I haven't developed an opinion on OT contributions to sound. I fully support PTs that can actually handle the circuit. Good luck
    Dismalhead and thunderbyrd like this.
  5. Mark the Moose
    Erie, CO
    I suppose my gleeful hope is that it will put me in the neighborhood of a lower wattage vibroverb/vibrolux reverb.
    Dismalhead likes this.
  6. archetype
    archetype Fiend of Leo's Silver Supporter
    Williamsville NY
    I use my SCX2 combo as a head, sometimes, and aside from the SS preamp it's 99% Princeton. Run through my Tremolux 2 x 10" cab with the back removed, it's got a surprisingly large, open, room-filling tone.
    I'd say that you can't go rong with your idea, but... yes you can go rong.
    If I were me, I'd use the stock transformers to start with, just as a baseline to see how it sounded. If you go with Allen transformers, choose wisely from the different models. You can 'improve' a Princeton too much and end up losing some of the characteristics you want to retain.
  7. Snfoilhat
    Oakland, CA
    edit: new photo because distortion in the previous one made the grill cloth look more crooked than it is. TDPRI Shock Brothers is a proud institution:p
    Recycled pine, plywood, back doors, and grill cloth. So you could make something considerably better looking, but here's the basic shape.
    thunderbyrd likes this.
  8. aerhed
    aerhed Friend of Leo's
    Boulder, WY
    The phase inverter is a big part of the Princeton sound. Bigger transformers usually mostly sound like a bigger Princeton. Like using two of them.
  9. caspersvapors
    caspersvapors Tele-Meister
    CA
    Id probably just go for a head + cab configuration in the event you ever want to sell that amp down the road.
    Selling a 2x10 combo that only fits a Princeton chassis is a pretty esoteric thing. Selling a 2x10 cabinet isnt too tough.
    And I think you get a bit more utility/ease of use out of the amp going with a head.
  10. Mark the Moose
    Erie, CO
    Probably wise.
  11. charlie chitlin
    Spring City, Pa
    DO IT!!
    I'm gonna put mine in a 4x10 one day.
    Really.
  12. Ess Eff
    Ess Eff Tele-Meister
    Well, just talkin Princeton mods... I did the 12" thing with a C12N. Nice!
    Got a 5F1 coming so might do a Champ 10" next.
  13. Bob Arbogast
    Bob Arbogast Tele-Afflicted
    Lowell, Michigan USA
    I tried several times to get a smaller version of a Vibrolux Reverb using a Princeton Reverb chassis and circuit as a starting point. It never worked. What did work is a 2x10 Deluxe Reverb using the lower voltage winding of an Allen TP25. Yep, the result sounds like a lower wattage Vibrolux Reverb!
  14. Mark the Moose
    Erie, CO
    That's a sweet amp. How do you like the trem?
  15. jsnwhite619
    jsnwhite619 Friend of Leo's
    Georgia
    I just finished a PR build with Hammond transformers. 100mA PT 290AX, 15 OT 1750E, and 5u4 rectifier. All new JJ's and 12" Cannabis Rex. Best sounding amp I've built or played I think. It didn't break up with single coils until 8 on the dial. Added a NFB switch that ended up kinda like a bright switch. Added a lot of top end, but worked great with the CRex. Headroom didn't change much til after 6 or so, just brighter and louder. That transformer set kept it as clean as I could ask for at vintage levels. Turned out great! Legend 1258 sounded amazing, but too bright with treble past 5 or so
    Sent from my XT1585 using Tapatalk
  16. horseman308
    horseman308 Tele-Holic
    US
    Ok, that is f'ing rad. Would love to hear more. Like, what's the head room compared to a stock DRRI?
    Sent from my SM-G930P using Tapatalk
  17. Bob Arbogast
    I like the trem a lot, though in this case it's a bias-vary trem, same as on a Princeton Reverb.
  18. Bob Arbogast
    I've never played a DRRI (or a Deluxe Reverb of any kind, for that matter!), so I can't compare. To my ear this amp has about the same headroom as a Princeton Reverb, maybe a bit more. But the voice is closer to a Vibrolux.
    For the techie types: with the TP25 lower voltage winding and a solid state rectifier, I have a B+ of 375V (with 122Vac on the line). I'm guessing that set up like this it's maybe a 15W amp.
    I've thought about trying the higher voltage winding for standard DR voltages, but for the paces I tend to play I don't need the extra volume/headroom.
  19. horseman308
    US
    Thanks. Did you find it for sale somewhere or do it/have it done yourself?
    Anything different (that you know of from a stock DRRI)? I'm assuming there would have to have been some other components swapped out, but I don't quite have the tech knowledge to hazard a guess as to what.
  20. Mark the Moose
    Erie, CO
    Now you're talkin'! If I could figure out a DR with a bias vary and 2x10's that would be a perfect amp.
