Pony Express build thread for OCD's 1st T-classic
Discussion in 'Tele Home Depot' started by PonyExpress, Oct 6, 2017.
  1. PonyExpress
    PonyExpress Tele-Meister
    160
    Sep 28, 2017
    Templates arrived today. Man it like I'm a little kid a christmas!!!
    So I'm thinking that I should go ahead and get the bridge, neck plate, string ferrules, neck screws, tuners, control plate and pick guard to have at the ready for fitting / make sure everything right as I go.
    What say yous guys with all the x-speriance?
    Bu-daaaaaaaaaaaaaay
    nojazzhere likes this.
  2. RickyRicardo
    RickyRicardo Friend of Leo's
    Mar 27, 2012
    Calgary, Alberta
    Yes. Have your parts on hand first. No surprises.
  3. nojazzhere
    nojazzhere Friend of Leo's
    Feb 3, 2017
    Foat Wuth, Texas
    Just be careful how you post your progress.....we don't want TDPRI to have a meltdown...:) ;) ;)
  4. PonyExpress
    160
    Sep 28, 2017
    ordered lots of stuff yesterday from Darren Riley. Seemed to have best prices for real fender parts. got tuners, control plate, neck plate, pick guard, bridge,
    bone nut blank. jack ferrule.
    looking at a electronics parts in kit form from Guitarelectronics.com.
    Also looking at pickups at GFS. Like the idea of the Kwik plug system. Any cons?
    Need to start ordering tools and frets etc.
    Off today. Going to dads to cut out shape on band saw and route with template. Hope to complete all the router work today. Neck blank arrives tomorrow. Update tonight with pictures
  5. PonyExpress
    160
    Sep 28, 2017
    So today went pretty good. could be better but most blems are under pick guard.
    So next time I will stop short of full depth when drilling our wood with forstner bits so the points wont show. Drilled the string thru holes from the front about 3/4 of the way thru.
    Then drilled the ferrule recess with a 10mm brad point bit, then drilled out for the ferrule with a 5/16 brad point bit. Then drilled the string hole the rest of the way and they all met up perfectly.
    Used an 1/8" round over on the edges. That a really small round over. Is that all its supposed to be?
  6. John Nicholas
    John Nicholas Tele-Afflicted
    Jun 26, 2014
    Poughkeepsie, NY
    If you're aiming for a vintage Tele look and feel, yes the 1/8 inch roundover is correct.
    This is fantastic for a first time build!! Do you have some previous woodworking experience?
    Welcome to the insane asylum. Building guitars is like eating potato chips, you can't build just one!!
  7. PonyExpress
    160
    Sep 28, 2017
    I have built some cabinets in a remodel once , just piddling mainly. Its just comes naturally to me, working with tools and stuff
    John Nicholas likes this.
  8. PonyExpress
    160
    Sep 28, 2017
    UPDATE
    so I've been busy. Had to clean out garage and build a workbench to work on. Wife kicked me off the dining room table.
    Then I made myself a fret cutting jig. Got the saw from harbor freight. It cut a perfect .030 slot. so I bought a cheap sharpening stone at HF and laid the blade on a flat surface and ran the stone over the blade, both sides and kept measuring the kerf till I got to to .024.
    Cuts a slot now that a .024 feeler gauge is a tight fit.
    Also got the white pick guard, truss rod, bone nut blank, and Darren Riley order should be here any minute.
    Tomorrow going to surface the maple neck blank to 1 1/8" and cut fret slots, and route and install truss rod.
    BorderRadio and Steveinthesticks like this.
  9. RickyRicardo
    Mar 27, 2012
    Calgary, Alberta
    And you have 2 beer fridges.. :)
  10. PonyExpress
    160
    Sep 28, 2017
    And a deep freezer. It actually just 1 beer frig and the other is a brisket aging frig.
    callasabra and esetter like this.
  11. oldrebel
    oldrebel Friend of Leo's Gold Supporter
    Oct 23, 2011
    Lynchburg Tennessee
    Great start. Looking good!!
  12. ponce
    ponce Tele-Meister
    433
    Dec 21, 2011
    Croatia
    Looking good!
  13. PonyExpress
    160
    Sep 28, 2017
    Update
    yesterday installed the truss rod in the maple blank. Used a low profile double action rod from stew mac and put it in from the back of the neck. Put in a walnut skunk strip.
    Then cut the nut slot and all the fret slots.
    I even got the nut slot perefect
    So far everything is going well. Waiting on the 9.5" radius profile router bit.
    Got the lute from Darren riley yesterday also.
    laid out the bridge and pick guard and control plate. Looks like everything is in the right place
    I bought the "squire" control plate. Whats the difference compared to the fender? thickness?
    BorderRadio and Mat UK like this.
  14. old wrench
    old wrench Tele-Meister
    About the "squire" control plate . . . . I came across those when I was looking for a reasonably priced nickle-plated cover. I bought one from Steve at Angela Instruments; his description of the cover matched up with what I was wanting, so I bought it. All the holes are in the right place, the holes are the right size, and the nickle-plating is real nice. If you shop around a bit, the price is right too. I've bought a couple more since then :).
    The only "problem" I've encountered with the Squire plate is that sometimes, when using the 4 position switches, the lever makes contact with the plate at the far end of the switch's travel - like in position 1 or 4. That is very easy to correct with a few strokes of the file to the lever; there is plenty of meat to the lever and you can file it in a way that will go unnoticed.
    By the way, your build is coming along real nice!
    Best Regards,
    Geo.
  15. TRexF16
    TRexF16 Friend of Leo's
    Apr 4, 2011
    Tucson
    Check the hole diameter on the Squier plate and make sure it is wide enough for American pot shafts (3/8"). If not, just drill it out. I find them to be high quality and thicker than the Fender. Don't hesitate to make some minor fitting so the pickguard mates perfectly with the control plate with no force required. And to get the best look, fit the pickguard and mark out the hole locations to mount it and then fit the control plate to the pickguard and mark the hole locations for the plate. You want to get the pickguard with an equal reveal all around its edges (and the bridge) for best looks. If it's off even a little it "shows."
    Also, if you just mark but don't drill out all your hole locations, your wet sanding when the body is finished will be a lot safer and easier, and once it is all polished out and dry, then carefully drill the holes. There are some techniques that Google knows that will help keep it clean. Any open holes are a nightmare when wet sanding and can lead to finish cracking. I have used naphtha as the wet sanding agent, which does not harm the finish if it gets in holes, but notice the finish I get is quite inferior to that achieved with just water with a drop of dish soap. Thus, I now drill those pickguard holes last.
    And I echo the compliments on what you're achieving with a limited shop. Heck, what you're achieving...period.
    Rex
  16. TRexF16
    Apr 4, 2011
    Tucson
    PS, those fret slots look kind of wide...do you have feeler gauges where you can measure the kerf that saw left? Those Horror Fight saws vary a lot. I have some that cut a very clean narrow kerf and some have a ton of set and cut much wider.
  17. PonyExpress
    160
    Sep 28, 2017
    A .024 feeler fits tight. I have already used a triangle file to open the top of the slot. I honed the saw to get the correct slot width. I even cut on a test piece of wood and hammered in a fret and it went in tight. So I think I good but we'll see when I do all the frets in the maple.
  18. TRexF16
    Apr 4, 2011
    Tucson
    That's the way to do it. Should be fine. Stoning the edges of the teeth until the kerf is just right is the ticket.
  19. PonyExpress
    160
    Sep 28, 2017
    Update!
    So yesterday I radiused the fret board to a 9.5" radius using a router bit I bought on the bay. See here for a more indepth description
    http://www.tdpri.com/threads/router-bit-for-radiusing-the-fret-board.774905/page-2#post-7947113
    Then last night I got started on the neck shaping. Once I got started I couldn't stop. Was up till 1:30 this morning.
    Started out buy making myself a neck shaping stand/jig. Really worked good.
    20171023_184744[1].jpg It held the neck so steady and I could also clamp it so a side was up so I could see the line at the fret board better.
    Here you can see I have started with the main facet. I used only files and sandpaper. And you were right. Very easy using the facet method and satisfying.
    and here another view
    This is the neck shape template that came with my template set from the bay. Not bad.
    Still so work to do here on the heel
    and here too
    So I will continue to refine the shape. It still feels fat to me but its getting there 20171024_105252[1].jpg
  20. DrASATele
    Jul 6, 2012
    North of Boston
    Nice progress!
    I want to build myself a collapsible neck shaping stand that attaches to my desk. I love yours, I'm jealous.
