Please help me decide on a Multimeter
Discussion in 'Burnt Fingers DIY Effects' started by jddub440, Mar 26, 2019.
  1. archetype
    archetype Fiend of Leo's Silver Supporter
    Williamsville NY
    My daily driver is a $10 Harbor Freight digital multimeter. I'm careful, but if I smoke that thing it's not a real loss. I have a Simpon 260 that I use almost as much. In troubleshooting things the Simpson is essential. If you have a situation where the value (V, mA, etc.) is "bouncing," all you can see on an inexpensive DVM is a chaotic mess of ever-changing numbers. An analog meter like the Simpson responds more slowly to the bounce and you can readily see the high and low values.
  2. rogb
    rogb Tele-Holic
    London, England
    The cheap meters are generally fine for low power, non-critical testing and checking - but I use and trust an old LCD Wavetek USA (ex British Telecom issue) -Cat II 1000v. I've tested transformers putting out 750+vAC with it, not sure if I'd trust a $5 Chinese with life-threatening volts, go Fluke or equivalent if your life depends on it.
    I got one of these - very useful for sorting through geraniums. Way better than using your MM!
    jddub440 likes this.
  3. rogb
    rogb Tele-Holic
    London, England
    These seem well regarded for non mains-HV work? Under £15 lol!
    jddub440 and zippofan like this.
  4. ftbtx
    ftbtx Tele-Afflicted Silver Supporter
    The west side of Texas
    I've been using a Fluke 87 V for the past seven years at work without an issue.
    jddub440 and rogb like this.
  5. teleteej
    teleteej TDPRI Member
    Vermont
    Nothing but a Fluke for me.
  6. magicfingers99
    magicfingers99 Tele-Afflicted
    atlanta
  7. magicfingers99
    atlanta
    a
    most folks have no clue what true root mean square evens means, let alone whether they need it. For a 1st meter, unless you are working in an electronics lab, a fluke is overkill and now overpriced as well.
    Fluke has been buying up a lot of the test equipment manufacturers. Dale is now owned by fluke among others, they are cornering the market and raising prices and discontiuing service on older meters.
    if you are buying your 1st meter, you probably don't know what all the features are, and what they do. My brother borrowed my fluke and burned it out testing his battery/alternator on his car. I bought him a 10$ meter, its all he really needed.
    I replaced the fluke, I get them free when they can't be calibrated anymore and for what I do, I don't need a cal sticker.
    if you know you need RMS and the rest of the things a good several hundred dollar meter brings, it is a great investment.
    for just simple continuity and polarity testing, a 10$ meter is fine.
  8. brokenbones
    brokenbones Tele-Meister
    Indy
    If you're building effects pedals and testing batteries, I would recommend looking in the dirt cheap to good budget categories of multimeters. That will put you in the $10-$60, new, range. In the good budget category I would suggest brand names such as Extech, Triplett, BK Precision, and Mastech.
    Features you're going to want or need:
    1.600V/10A
    2. Resistance rating of at least 10Megs. This shouldn't be any issue with any meter.
    3. Diode/Continuity setting.
    4. Backlight. -this is subjective to some but I would recommend it.
    Features I wouldn't worry about in your situation.
    1. True RMS
    2. Auto-Ranging
    3. Frequency Counter
    Now, the one feature I left out of both categories is a capacitance checker. Some meters have them built in and some people will buy a stand alone ESR meter. I think you'll need one eventually and I wouldn't buy one unless it has "in-circuit" testing capability. That capability and the range of capacitance it's able to test are the two important factors when choosing a capacitance meter.
    jddub440, rogb and magicfingers99 like this.
  9. Marc Morfei
    Marc Morfei Tele-Holic
    Philadelphia, PA
  10. ICTRock
    ICTRock Tele-Afflicted
    Tampa,FL
    frequency counter ... the feature I wasn't expecting to use that I ended up using for analog delay based effects
  11. zippofan
    zippofan Tele-Holic
    Pennsylvania
    The cheapo I picked up on Amazon has the freq counter too. I have a standalone counter that I used back when I did a lot of RF work, and I wouldn't trust a $20 DMM from Amazon when calibrating a transmitter oscillator, but for checking the clock on my Aquaboy build it was very handy. I didn't have to drag out the big counter and plug it in, just used the DMM.
    I also couldn't believe how useful the little 30 buck handheld scope was too, bought it on a whim with some Amazon gift cards and used it more than once on builds with a cheapo 10x probe. I have a usable analog scope I built in 1985 and a good Tek probe, the handheld worked just as well, plus I could store traces which isn't possible with the analog scope.
    I have the Peak DCA on my wishlist, can't have enough tools or test equipment :D
  12. Andy B
    Andy B Tele-Afflicted Gold Supporter
    Colorado
    Why is a good quality meter overkill? A meter that is reliable, consistant, and you only have to buy it once. I've used Fluke meterr ever since the Fluke 77 was new. Never had a problem with any of them.
  13. DHart
    DHart Friend of Leo's
    Scottsdale, AZ USA
  14. radiocaster
    radiocaster Friend of Leo's
    europe
  15. thegreatshocka
    thegreatshocka Tele-Meister
    Columbus, Ohio
  16. Ziggy587
    Ziggy587 Tele-Meister
    Long Island, NY
    I got that Innova meter just to keep around the house (since I keep my main multimeter in my workshop). Since I mainly wanted it just to check batteries and quick continuity checks, I didn't really care about quality. I guess that's why I was impressed how good it is. I would definitely recommend this one as a budget meter.
  17. PCollen
    PCollen Friend of Leo's
    Man of the World
    I had a DT-9505A for several months, then it just quit working. But for the price it was a great meter while it lasted. Maybe I just had bad luck. I'd buy another but I also have an old Fluke that I've used for over 35 years without fail, albeit with less functionality than the DT-9205A.
  18. jddub440
    jddub440 Tele-Holic
    Tacoma
    Thank you all for your replies, I'm definately gonna go over this thread from time to time to refresh myself on some of these tools....I'm gonna start cheap with that DT-9205A and figure out what features I use most or use at all. You all Rock!!!:cool:
    Urshurak776 and rogb like this.
  19. jimdkc
    jimdkc Friend of Leo's
    Independence, MO
    Please don't spend $10 for a Harbor Freight DMM. Wait for a "Free with any purchase" coupon (Or at least a $5 coupon!)
    (I have about 3 of them!)
    They are a decent starter meter and will be OK for a lot of users.
    zippofan likes this.
  20. Monkey_Relish
    Monkey_Relish TDPRI Member
    South East Corner of Oz
