Join TDPRI Today
Piqtronix attack decay attack LED intermittently flashing
Discussion in 'The Stomp Box' started by goldspanner, May 1, 2012.
  1. goldspanner
    goldspanner Tele-Meister
    126
    Nov 26, 2011
    Brighton
    the attack indicator LED has recently just started flashing randomly and intermittently.
    Is it likely to be as simple as the LED being worn out, or something more complicated?
    any help appreciated
    Alex
  2. lefty73
    lefty73 Tele-Holic
    983
    Jan 19, 2011
    03842
    Electronics novice here, but it could be one of the leads on the LED has gone askew/awry. If you can, take the unit apart and look for any obvious signs of damage or weirdness. Take a pic or and post it if you can - that'll help the more experienced peeps on this board diagnose the problem.
    If the pedal still works fine (sounds like it does?) then I wouldn't sweat the LED for now.
  3. goldspanner
    126
    Nov 26, 2011
    Brighton
    thanks for your help. If I can get the screws out i'll take a peek.
    It's not all that annoying apart from when the led goes out completely for a couple of minutes. The pedal still works perfectly though
