Join TDPRI Today
Pine Tele 1/4 sawn body?
Discussion in 'Tele Home Depot' started by soulfixinman, Jul 23, 2009.
  1. soulfixinman
    soulfixinman Tele-Meister
    120
    Jul 21, 2009
    Summerville, SC
    I am wanting a pine tele body with the tight grain that runs up and down the body
    I am assuming that is called a quarter sawn pine Telecaster body,
    I have been looking and can't seem to find the source,
    I am guessing the problem may be the wood is hard to come by?
    Can somebody make me one?
    thaks
    Dave R.
  2. Colt W. Knight
    Colt W. Knight Doctor of Teleocity
    Jan 21, 2007
    Tucson, AZ
    A truely quartersawn piece of pine is going to be difficult to find because most pine trees are not large enough when they are harvested to quarter saw a chunk that big. Second, with exception of a few builders, no one really cares about quarter sawn pine.
    The best approach would be to glue up a two-piece guitar blank using a 2x8 with really nice tight grain patterns. Plus, one piece pine blanks big enough for teles are really hard to stabilize without a lot of experience in working with such wood. A forum member here, Marty(GuitarBuilder) makes just what you are looking for, excellent quality pine tele bodies. I would just send him a PM.
  3. Colt W. Knight
    Jan 21, 2007
    Tucson, AZ
    http://www.geoffswoodwork.co.uk/conversion.htm
    Here is a handy, no nonsense explanation of how lumber is sawn.
    As far as pine being hard to find, thats really a yes or no answer depending on what you are looking for, and where. Most real lumber suppliers will have some 8/4 pine. Its used a lot in new home construction and remodeling to make ledges or decorative gussets. This is almost always going to be flat sawn. However, if you will notice how lumber is flatsawn, a certain percentage will also be quarter sawn. So you really need to dig through the lumber pile to find the piece of wood that suits your grain needs. If one lumber yard doesn't stock the wood you are looking for ask them if they know of another local supplier, or if they can get some in for you. Most likely they won't special order anything under 1000 board feet, so they are ussually more than happy to reccomend you another source.
    Here is one of my pine teles. You will notice it has a tight grain pattern on one side, but heart wood on the other edge.
    end grain
    That particular body isn't anywhere close to being quarter sawn, but it sounds fantastic. However, I made about 6 blanks from that one board. 2 where one piece, and the other 4 cracked and warped. I was able to salvage another 2 by making them 2 piece bodies. If the board were 100% quarter sawn, I wouldn't have had that problem.
  5. PeterUK
    PeterUK Friend of Leo's
    Mar 4, 2003
    Nottingham, UK
    Is this quarter sawn?
    This is my current project:
    Is this quartersawn? It's a 1-piece pine body.
    :D Peter
  6. guitarbuilder
    guitarbuilder Doctor of Teleocity
    Mar 30, 2003
    Thanks for the plug Colt!
    Peter....not quartered.. in quartersawn the rings would look like this on the endgrain
    lllllllllllllllllllllllll
  7. guitarbuilder
    Mar 30, 2003
    Tonewoods had some spruce that was close like this:
  8. Colt W. Knight
    Jan 21, 2007
    Tucson, AZ
    Nope that is flat sawn. It was cut like this.
    But it does have a nice tight grain pattern, and its a lovely piece of wood. It will make a fantastic guitar.
  9. Ricky D.
    Ricky D. Poster Extraordinaire
    That's flatsawn. Quartersawn would have end grain which is perpendicular to the top all the way across.
  10. PeterUK
    Mar 4, 2003
    Nottingham, UK
    Hee hee! Thanks.
    I don't really care. It's a wonderful piece of wood, light as a feather and I can't wait to hit that first chord with it when it becomes a.....
    .....Blingcaster!
    :lol: Peter
  11. soulfixinman
    120
    Jul 21, 2009
    Summerville, SC
    Yes I like that grain....did you do nything to enhance the pine grain lines?
  12. soulfixinman
    120
    Jul 21, 2009
    Summerville, SC
    I found this one and bought it...Sugar Pine 4.4 ounces
    I hope the grain turns out lookin' good cause I want to do a translucent or clear
  13. Nick JD
    Nick JD Doctor of Teleocity
    Picture a quarter of a pie.
    Now cut the straight sides off the piece of pie.
    You got two quarter sawn pieces of pie.
    NOW EAT THE PIE!
    I like pie. Especially quartersawn pie.
  14. otterhound
    otterhound Poster Extraordinaire
    Dec 14, 2008
    Manheim Pa.
    Our quarters are made from metal . Probably won't make a very good pie . What do they make them from behind the black stump ?
  15. Telenator
    Sep 19, 2005
    Vermont
    That body is going to have absolutely beautiful grain once you put a finish on it. Nothing like a one-piece body!
  16. Mojotron
    Mojotron Poster Extraordinaire
    Dec 21, 2008
    Seattle
    VG (vertical grain) Fir is expensive but very cool looking as a 1/4 sawn wood. That might be worth checking out.
  17. Colt W. Knight
    Jan 21, 2007
    Tucson, AZ
    The only thing on that guitar is two coats of sanding sealer and two cans of DEFT Nitro Lacquer. The guitar is yellower than that particular picture.
  18. Colt W. Knight
    Jan 21, 2007
    Tucson, AZ
    Your body is beautiful, and it will have an even more beautiful grain pattern with a translucent finish. There are a few tricks you can use to make the grain pop out even more. If you want a colored finish, you can stain it with alcohol based stain, but pine doesn't stain even so try it on scrap first to see if you like it. Then lightly sand all the raised grain. Then spray it with sanding sealer and tinted lacquer.
  19. soulfixinman
    120
    Jul 21, 2009
    Summerville, SC
    I usually stain my maple necks with vintage amber, but what I have is water based stain...I could just hit it with some sanding sealer and RR tinted clear. What is the deal on the MInwax wood hardner I have read some use to make the pine harder and I think I read it seals any sap in the wood also?
  20. Colt W. Knight
    Jan 21, 2007
    Tucson, AZ
    I dont use it on a guitars, but I have used it for shelves. It does harden the wood surface, and it also works as a sanding sealer.
    Water based stain works as well, I just prefer alcohol because it evaporates quicker, so it expediates the sanding process.
    But sanding sealer and tinted lacquer will do a good job of bringing out the grain a little more too.
