Join TDPRI Today
Pickup Selection Help
Discussion in 'Just Pickups' started by zooyuka, Feb 13, 2012.
  1. zooyuka
    zooyuka Tele-Meister
    496
    Jul 17, 2006
    Youngsville, LA
    I have MIM tele that I would like to change the pickups on. I really dislike the stock pickups. The bridge pickup I find to be to shrill and sounds more honky than twangy. I prefer the neck pickup, but I find it too muddy sounding.
    I'm not sure what pick ups I would like. I would like to have a nice fat classic rock tone. Would the Custom Shop Texas Specials fit the bill for this? I'm open to any suggestions.
  2. TeleLover223
    TeleLover223 TDPRI Member
    16
    Mar 24, 2011
    Michigan
    Have you thought about changing the electronics first? On my squier
    CV tele I got a 4 way harness from TundraTone.com and it clears my pickups right up and sounds A LOT better. Anyways, just a thought.
  3. zooyuka
    496
    Jul 17, 2006
    Youngsville, LA
    No, I'm pretty ignorant when it comes to this stuff. All I know is I don't like the sound and want to change it. Whatever I do, I plan on paying someone to do it for me.
  5. ludashoeless
    ludashoeless Tele-Afflicted
    dimarzio twang king pickups. i put them in my mim tele and theyre great. i also heard good thinga about keystones
  6. Televised
    Televised Friend of Leo's
    Apr 26, 2009
    Portland, OR
    I'd check out the "Wilde" green tab regarding Bill & Becky Lawrence on the supporting vendor tab at the top of the page.
    The Bill Lawrence "Keystone" Pups that I purchased for my '06 MIM Tele is still one of the best bang for the buck gear items I have, (Tele Set < $75). However, if given the same choice today I would probably purchase the Bill Lawrence "Micro-Coils", (Tele Set < $100).
    Hard to go wrong with either one and certainly reasonably priced. The tone I would describe as Clear, Rich, and quiet for single coils.
  7. zooyuka
    496
    Jul 17, 2006
    Youngsville, LA
    What about the lil '59? Do any of you have thoughts on that?
  8. musicmatty
    musicmatty Former Member
    Aug 18, 2008
    Maryland
    To answer your question...Yes..in my experience of owning them along with several other brands that I own. The CS Texas Spcls have a nice warm tone..You could certainly do Classic Rock with lower output pups...but your stock Tele pups are probably ceramic..and not so twangy. If you want some Twang..go with lower output 6-6.5k pups that are either AlNico 3 or 5 mags.
    Good luck in your search..Youtube has lots of video demos
  9. Teleterr
    Teleterr Tele-Afflicted
    Feb 7, 2011
    Lewes De.
    If '52 OVs are still on sale for $62 @ Amazon, they'll do it fine.With a 4 way switch you'll even get a strong output.
  10. AllroyPA
    AllroyPA Tele-Meister
    452
    Aug 27, 2010
    Rofo, PA
    Alnico 5's over 3's IMO ...
  11. zooyuka
    496
    Jul 17, 2006
    Youngsville, LA
    They are 77 now at Amazon, but that still seems reasonable. I keep going back and forth if I will try and install them myself. How difficult is it for a noob? Will I need to adjust the magnets?
  12. Teleterr
    Feb 7, 2011
    Lewes De.
    I don't think they adjust.Too bad they went up,but ebay has them all the time.They are the only original p/ups I never changed.I think mine are AlNiCo 5s.
  13. zooyuka
    496
    Jul 17, 2006
    Youngsville, LA
    How difficult is the wiring?
  14. Mreilander
    Mreilander Tele-Holic Vendor Member
    630
    Apr 3, 2011
    Vancouver Canada
    Just put the wires for the new ones were you took off the old ones. You pickups will come with a diagram.
  15. zooyuka
    496
    Jul 17, 2006
    Youngsville, LA
    Ok, I'm just uptight about making the swap myself. How much does a shop usually charge to swap them?
  16. harphunt
    harphunt TDPRI Member
    88
    Feb 10, 2012
    Michigan
  17. BWNadeau
    BWNadeau Tele-Afflicted
    Feb 2, 2011
    Lachute, Canada
    My tech was charging me $40, but I was changing stuff so often I just started doing it myself.
    For the sound you're after, I would recommend you check out a set of Budz Guitars 42 and Tall pups. A nice fat, warm bridge, and the sweetest sounding neck pup I've ever played.:cool:
  18. Mreilander
    630
    Apr 3, 2011
    Vancouver Canada
    ^^ yes. It's easy, once you do it you'll be looking for the staples 'easy button'
  19. zooyuka
    496
    Jul 17, 2006
    Youngsville, LA
    Ok, I'll take the plunge and do it myself. What tools would I need?
  20. Mreilander
    630
    Apr 3, 2011
    Vancouver Canada
    You'll need a philips screw driver to take off the control plate, pickguard and pickups. A bigger (I think a #2) phillips Screwdriver for the bridge . A soldering iron, and a little bit of solder.
  21. zooyuka
    496
    Jul 17, 2006
    Youngsville, LA
