Join TDPRI Today
Pickguard install question
Discussion in 'Tele-Technical' started by steve v, Dec 21, 2013.
  1. steve v
    steve v Tele-Meister
    489
    Jun 18, 2009
    Eagle Mills, NY
    I'm putting in a different pickup in the neck of my Tele and just ordered a pickguard without pre-drilled holes. I was going to use the old pickguard as a template to drill holes in the new one. Is this the best way to do this or am I missing something completely obvious ?
  2. fendrguitplayr
    fendrguitplayr Poster Extraordinaire
    Oct 11, 2006
    Greater Boston
    That will be fine, or you could buy a guard pre-drilled.
  3. KokoTele
    KokoTele <img src="http://www.tdpri.com/gifs/vendor.png" /> Vendor Member
    albany, ny [not chicago]
    Yeah, why didn't you just order the pickguard pre-drilled?
    Using a template will probably work. I'd double-stick tape them together and clamp them to a block of wood as a backer.
  5. KevinB
    KevinB Doctor of Teleocity
    Mar 4, 2007
    New Jersey
    Or...you could mount the pickup to the body, vintage style?
  6. flyswatter
    flyswatter Friend of Leo's
    Jan 12, 2013
    Quebec
    It will be harder to countersink the screws as they would be on a pre-drilled guard. You'll need the flattest head screw you can find unless you can recess the holes in the new guard.
  7. steve v
    489
    Jun 18, 2009
    Eagle Mills, NY
    I didn't buy the guard pre-drilled because I figured the holes wouldn't line up
