Join TDPRI Today
picked up clicking noise on PC
Discussion in 'Recording In Progress' started by T Prior, Jan 14, 2013.
  1. T Prior
    T Prior Poster Extraordinaire
    Charlotte NC
    during recording and playback
    intermittent with phones or monitors
    I have been fighting it now for a few months
    WIN XP Sp2 maxed out ram 4 gig which is actually 3.2
    M Audio Delta 24/96 ASIO
    PT 8
    Certainly most everything is plugged into the same outlets
    no wireless
    lots of AC plugs and outlet boxes
    unplugged many items doesn't help
    annoying..it's not in the recordings
    could be a cable..of course...
    the one common item I didn't check is the phones amp which drives both the phones and the monitors. I'll do that today
    all suggestions considered..even hanging myself.
  2. winny pooh
    winny pooh Friend of Leo's
    Jan 24, 2006
    South London
    If its not in the recordings then no prob right?
    If you are at low buffer settings when tracking then your pc may not be keeping up. In the playback engine there is a clickable dialog box that says "may cause clicks and pops" you can investigate. Again it may be performance related: no seperate hd for your audio files or processor overload. Go to view>CPU usage, anything above 60% will start giving issues soon.
  3. T Prior
    Charlotte NC
    ok so I swapped headphone amps...just happened to buy a second one last week...
    same cables, same phones, click noise is perhaps 50% less ! odd..still there but not near
    what it was
    back to the main HPhone amp..
    then cables..they have not been changed and connectors have not been changed in years, including the connector on the M Audio Delta Audio bd... I of those around here as well..somewhere....
    we'll see...
    suggestions and opinions matter here !
  5. T Prior
    Charlotte NC
    Yes I will check again , this PC is ONLY for recording, no net, no nothing,. almost zero tasks...certainly a great suggestion Its running at 85% currently
    yes I have a separate HD for storage but not for tracking , I like keeping the programs and work project on the same HD...saved files and bulk storage on USB drive...
    I feel the PLAYBACK clicks are a sign of something I am missing..something right in front of me...
  6. neocaster
    neocaster Poster Extraordinaire
    Jan 26, 2006
    Chester County, PA
    Where is your mobile phone when you're recording?
  7. T Prior
    Charlotte NC
    good point.:!: .on the other side of the room, 10 feet.....and I always get emails it is business connected...my Laptop is wireless to the router as well, about 10 feet away... always getting emails...
    never thought of this...one never knows...
    Went back to the main HPhone amp..more clicks than the new one..but it could be a gain thing... as it has a front end level control which effects all outputs..or maybe two things are going on at the same time..like the new Iphone 5 !
    Made changes to the PC, cache and display functions, turned them all OFF...should have done that a long time ago but I am still thinking Audio bd connector and audio connectors old and dirty..never been cleaned...especially because it's NOT in the recordings which to me means it's not the PC... But what do I know, I'm just a peasant...
    cleaning the PC connectors and changing cables next
  8. woodman
    woodman Doctor of Teleocity
    Nov 28, 2004
    Mint Hill, NC
    Dunno if this is responsible for your clicks and pops, but this is not the recipe for best system performance. Even if it's the best HD ever made, your startup drive is gonna have to jump back and forth, keeping the OS stable AND running the application AND managing the massive torrent of audio throughput that recording requires. I think the PT manual even recommends recording to a separate drive. If your PC will accommodate another SATA internal drive, that's your best bet. They're cheap and fast!
  9. T Prior
    Charlotte NC
    Woody yes I know and agree, and I probably will do this..but the clicking just began a few months back and i have been using this PC for many years.
    I do have a 1T USB drive..I will record to that drive going forward..
    Are you running the main program from the PC or MAC HD and then starting the new project and recording to the 2nd or ext drive ? I did this just a week back and the click noises were alive ! I would like to know what your configuration is..
  10. woodman
    Nov 28, 2004
    Mint Hill, NC
    The system and the audio applications need to be on the startup drive. When I open a new project, I save it to a second SATA internal drive, which handles all the audio chores for the duration of the project ... before I had the second internal drive capacity, I used an external Firewire drive. But SATA speed leaves Firewire in the dust.
    As I said, I dunno if this is the cause of your noise, but in my early digital days I experienced all sorts of gremlins recording to the system drive. When I started recording to another drive, they all went away.
  11. Tom Cook
    Tom Cook Tele-Meister
    291
    May 5, 2010
    +1 , on any wireless , phone or computor, signal can cause this type noise !
  12. T Prior
    Charlotte NC
    Thanks Woody, yes I have done this recently but had been recording to the main HD... creature of habit I suppose , but for several years all was well..
    bad news..I just went thru the exercise of opening the project, saving it to the USB drive , reopening it from the USB drive and the clicks are there, as I thought they would be...but the experiment is GOOD...as I am really convinced now it is either the M Audio Delta Interface, connections, cables etc... I will get past this and it really is time to use the USB drive for audio...I mean it is 1 T byte ! That could be one real long guitar solo for sure !
  13. telleutelleme
    telleutelleme Doctor of Teleocity
    Jan 15, 2010
    Houston
    Tap tempo? I had this experience during playback with it coming through the mixer monitor from a floor pod with that feature. I didn't realize it was on andf it took me a while to find it.
    My cell phone creates that problem as well and it has happened with it next to a powered monitor. Does it at work if I set it next to the office phone.
  14. T Prior
    Charlotte NC
    well I'm on to something...
    I cleaned the M Audio Delta PC bd audio terminals, cleaned and reseated the bd, changed cables..blah blah blah... clicks/pops were still there , but perhaps not as obvious.. but then..as I was putting it all back together, still wearing the phones, I unplugged an ac adapter from the newly added AC outlet strip..of a few months back ... CLICK/POP...just by unplugging the ac adapter...that ain't good... I then realized that I did reroute the AC lines several months back and used some supposedly hi end AC power strip with some sort of conditioning that my daughter told me was the best...well maybe not...
    I am going backwards today with the AC wire routing and strips.... I am thinking you are not supposed to hear anything thru the system in the phones when you plug stuff in ! Maybe this thing I started using a few months back is a POS...
    more later
  15. Old Cane
    Old Cane Poster Extraordinaire
    Sep 7, 2007
    Murfreesboro, TN
    Glad it's physical. It can be irritating to to find but at least if didn't hose up any tracks.
  16. winny pooh
    Jan 24, 2006
    South London
    Do you use Adat ins?
    Updated drivers? 3rd party hardware in PT hmm
  17. T Prior
    Charlotte NC
    Maybe..but things are looking UP
    I did change the AC power routing again, re-layed out the cables to and from the PC to the pre-amps etc...
    The one track I have been listening to a has a few glitches in it, very few...this is the most recent project...even running it from the USB drive..it's not a big deal if this file is a bust..I was not anywhere near done anyway and it has a programmed drum track..not like I need to get a drummer over here ! !
    While running the track in question though I did view the PC resource..it was at 95% with PT loaded..then I ran it from the HD..same thing ! go figure...But even the PT book says running on the PC HD may cause issues with multiple tracks and effects programs..so perhaps my project is too small to make a difference.
    Now I did go back and review the most recent projects from 2012..all clean..no clicks, so it is possible that I caused a few clicks/pops in the most recent session...or have a corrupted file...
    over the next couple of day's I'll recreate the project and see what happens..
    I think it will be best to run audio from the separate HD seeing I have it already have it, plus with the changed AC box and cables re-routed maybe I beat the beast !
    t
  18. T Prior
    Charlotte NC
    No, none of that..I had been running fine for a very long time, didn't change any installation sets or drivers, in fact went the other way, removed all sorts of CxxP from the PC and then de-fragged...which took all of about an hour...
    good point though..thanks
  19. jefrs
    jefrs Doctor of Teleocity
    Nov 20, 2007
    Newbury, England
    You have plenty of RAM but do you have enough page files and temporary file-space set up? - MyComputer <properties> advanced settings / perfomance settings / advanced ...
    Setting these up right can reduce your CPU usage.
    I have absolutely zero problems running XP on a 3.2GHz P4 with 2GB and a Creative X-Fi, but then I do have six hard disks - music recording files are big.
    Stop all the Windose sound schemes - silent, no clicks or pops.
  20. T Prior
    Charlotte NC
    All of those windows things are off..no schemes..no windows "thingy's....this is a recording only PC, the clicks/pops only started recently, CPU performance is running around 95% with all tracks running..
    I have been running for several years with NO issues....
    but I will still check it, always good to make certain...
    thanks
    t
  21. winny pooh
    Jan 24, 2006
    South London
    If this is in the same place each time you may be getting clicks and pops from edit points on individual tracks. This is why between any two regions (when you overdub you get new over old etc) you need to select across them and apply a cross fade (cntrl F). It used to drive me nuts.
    What CPU meter are you using??? You said 95% ? If the Pro tools cpu meter said that my PC would be freaking out.
