Join TDPRI Today
Peavey Valverb; What do you know, what do you think?
Discussion in 'The Stomp Box' started by shakedancer, Jan 31, 2006.
  1. shakedancer
    shakedancer Tele-Afflicted
    Apr 3, 2004
    north of Boston
    I bought one when it 1st came out. Haven't used it much. I think it could use some tubes. Is it safe to open up and replace the tubes, or should I take to a tech? How do you feel overall about the reverb and tremelo?
  2. I don't know about maintence on them...
    but they are great! I've been looking for one forever! A friend of mine has one and it sounds amazing!
    Good stuff!
    Johnny Isaacs
  3. shakedancer
    Apr 3, 2004
    north of Boston
    Thanks Johnny!! I'll know who to PM if I ever decide to sell it ;) Yeah, you don't see many floating around!
  5. Thanks!
    I think they're great!
    Johnny Isaacs
  6. Jean-Baptiste
    Jean-Baptiste Tele-Holic
    633
    Sep 16, 2004
    One of the coolest things Peavey ever made, and it was discontinued in less than a year, IIRC.
    Takes three preamp tubes (12AT?) that are very easy to replace. No need for rebiasing, so I see no reason to take it to a tech. The stock tubes are not the highest quality, so expect to hear some improvement when you upgrade. I wouldn't go for overhyped/priced brands like MesaBoogie or GrooveTubes- Sovteks or ElectroHarmonix should do nicely.
  7. shakedancer
    Apr 3, 2004
    north of Boston
    Ok, you guys are making me glad I have this. 8) I don't own any other rack stuff. I bought this at the time to have reverb with my BMRI. Jean, I'd have to get the book out, but I think there is 3 12AX7's in there. They are the original tubes and I think one or more may be going bad. It does have a caution notice about opening the case, but I figured as long as I go right to the tubes there should not be a problem. I don't have to have balanced tubes for this, do I? I'm getting some JJ tubes from Euro for my Pro JR, and thought I'd get 3 Pre amps for the unit.
  8. BB
    BB Friend of Leo's
    May 17, 2003
    Great Pacific NW
    Yeah....you don't see many of these around anymore. I've played through several and always came away with the same thought....."MAN.....I NEED ONE OF THESE BAD!"
    Beautiful, lush reverb and hypnotic, pulsating trem. Why they quit making these, I'll never know. I'm still on the hunt to find one cheap. Need to hit some of those out of the way pawn shops!
  9. Deacon Blues
    Deacon Blues Tele-Holic
    560
    Mar 24, 2003
    Northern New Mexico
    Yep
    I keep hoping to snag one those. The prices keep going up, too.
  10. Jean-Baptiste
    633
    Sep 16, 2004
    But when they were readily available I heard NOTHING but complaints about them. There was even a 'mod' to correct a percieved "volume drop" when the trem's engaged...
    That's why some trem pedals employ a boost- most users have never heard real amp tremolo, and think there's something wrong
  11. Deacon Blues
    560
    Mar 24, 2003
    Northern New Mexico
    RE:Volume drop
    The Valverb has a +4db boost, if I remember correctly. I don't know if all versions had the boost, or if it was something Peavey did later to correct the percieved volume drop.
  12. shakedancer
    Apr 3, 2004
    north of Boston
    Ok you guys just hit on something! I hadn't used it in a long time and thought I needed tubes because the volume does drop off with the Tremelo engaged. Can you direct me to the Mod for this? If not no big deal. Unit adds alot to sound with just reverb on. Has drive, and seems to add muscle to the amp. I don't use Tremelo much at all.
  13. chet.d
    chet.d TDPRI Member
    4
    Aug 8, 2008
    philly
    To revive this thread a bit...
    Is it just my valverb or do any other folks find it noisy?:confused:
    I love the sound and tremelo but find it hard to use with the noise.
    I did change the tubes but that didn't solve the problem. considering finding a tech to check it out.
  14. stripey
    stripey NEW MEMBER!
    Cambridge, UK
    To help revive this thread a bit further...
    I have a Valverb. In fact, the reason I'm here now is that I was playing it last night, A/B-ing it with a Lexicon LXP-1, because I thought I was going to have to sell one or the other, so I was trying to decide. Ended up deciding I probably have to keep both :)
    Yes, the Valverb is a little noisy. I don't know if there's much you can do about it. However, the noise in mine only seems to come when the far right-hand master volume is cranked up. The far left-hand input gain doesn't introduce noise.
    So I keep my gain up high (around 3 o'clock) and my volume down low (around 9 o'clock) and that works well enough for me. The rest of my signal volume is generated by the amp.
    The Valverb is a really nice valve-driven spring reverb. It doesn't do any other reverb sounds, which is either a point for or a point against, depending on your position. But I have it sitting under my '75 Champ and it's exactly the right size with the rack ears taken off :)
    I might try all-new JJ tubes, now I read the earlier posts here. Couldn't hurt to replace the stock tubes, right?
  15. chet.d
    chet.d TDPRI Member
    4
    Aug 8, 2008
    philly
    So... Had a tech check mine out and it needed a new transformer.
    It now sounds great! Was going to sell it but, mmmm maybe not.
    Still interested in that +4 db tremelo mod though.
    Haven't found a solid mod plan for that yet...
  16. e-merlin
    e-merlin Doctor of Teleocity
    Jan 13, 2004
    Garden City, KS
    One of the coolest pieces of Peavey gear ever. If it ever comes up for sale, I challenge Mr. Isaacs to a steel cage death match over it! I was busy paying off two Peavey Bravos and a Peavey ProFex II when the Valverb came out. Never had a chance to own one, but would love to have one.
  17. willvis
    willvis TDPRI Member
    41
    Dec 18, 2008
    nashville tennessee
    valverb
    The Valverb is pretty cool. I've had one since I bought it new around '91. They are pretty much cheap junk when you get right down to it---the tubes are cheap, etc. Mine was a workhorse, in a little rack with a delay on top of my Super Reverb back in the '90s. But I have Burriss Royal Bluesman head now, so the Valverb can't compete with that fine, fine tube reverb and tremolo!
    Probably the best Tremolo I've heard. If I need to go super slow---The Burriss doesn't go that slow---I have an old Demeter Tremulator...
