Join TDPRI Today
Peavey T-60 partscaster build questions
Discussion in 'Other T-Types and Partscasters' started by jackkavanagh, Jan 28, 2014.
  1. jackkavanagh
    jackkavanagh TDPRI Member
    12
    Jan 28, 2014
    England
    Hi, I'm new to the forum and this is going to be my first attempt at putting together a partscaster. I recently purchased a T-60 body from ebay that's now on it's way and also have a maple tele neck on the way. My question is: Will a standard tele neck plate fit the pre drilled holes in the peavey t60 or will I need to hunt down a t60 neck plate?
    Also this will be my first time trying to wire up a guitar. I'm going to go for a single humbucker with a volume knob and a jack output. What am I going to need for this set up and does anyone have any tips, videos, wiring diagrams or general advice?
    Cheers!
  2. 985plowboy
    985plowboy Tele-Holic
    753
    Feb 5, 2012
    South Louisiana
    The T60 has a lot of routing under that big pick guard. You may want to order some "blank" pick guard material to make a custom guard to house your custom electronics choice.
    I'm clueless about neck interchangeability.
    Put some pictures up as you go along. We all love a good partscaster build.
    Best of luck.
  3. jackkavanagh
    12
    Jan 28, 2014
    England
    Yeah already got some 3 ply pickguard material on its way! I know that peavey t60 necks are interchangeable with standard fender sized tele necks, I just don't know if the neck plate is interchangeable.
    I'll post pics as soon as stuff starts arriving in the post and I start working on it. Cheers!
  5. bo
    bo Friend of Leo's
    Arlington, VA
    If the neck plate is like on my T-27 then the answer is a definite "no". I suspect you'll have some dowel and drill time ahead of you.
  6. loopy reed
    loopy reed Tele-Afflicted
    Nov 14, 2007
    Nashville, TN
    I don't think the neckplates will be interchangeable. IIRC Peavey neck mounting screws aren't spaced as far apart as Fender.
  7. Il Duce
    Il Duce Tele-Meister
    334
    Nov 11, 2013
    NYC
    I have a T-60 that is in pieces so I used the neck on a Strat and it was a perfect fit.
  8. jackkavanagh
    12
    Jan 28, 2014
    England
    Yeah the T-60 neck plate is the same size as a T-27 from what I understand. May just have to bite the bullet and buy one off ebay. Probably gunna end up being quite expensive taking into account shipping from the US and customs charges.
  9. jackkavanagh
    12
    Jan 28, 2014
    England
    Were the mounting screws on the neck plate in the right place? Did you use the strat neck plate or the t60 one?
  10. MrCairo46
    MrCairo46 Tele-Afflicted
    Interesting that the Peavey Neck fit your Strat. Strat Heels are usually curved and tele's flat making them not always compatiable. I've built 1 T-60 and am working on number. This one I will plan to use a Tele neck rather than the thin Peavey neck. The T60 neck has a very thin profile and can cramp you up. For pick guards , check out a TDPRI supporter WD Music products. They carry T-60 pickguards in many great colors.The toughest parts to fuind (or should I say expensive) are the volume and tone knobs.
    They go from $19 to $30 each on ebay.
  11. loopy reed
    Nov 14, 2007
    Nashville, TN
    For wiring diagrams, Seymour Duncan's website has just about any diagram you would need.
  12. jackkavanagh
    12
    Jan 28, 2014
    England
    Cheers! I'll have a look now.
    Does anyone with a peavey t series neck plate fancy helping me out with a few measurements? Just need to know screw spacing.
  13. jackkavanagh
    12
    Jan 28, 2014
    England
    Body and neck arrived today along with the tuners and string trees.The guy I bought the body off also chucked in the pickguard and bridge. Pickguard will come in useful as a template for the new one I'll be building. Gunna start stripping the finish from the body today and maybe fit the tuners to the headstock.
  14. loopy reed
    Nov 14, 2007
    Nashville, TN
    This is gonna be neat! I love T-series Peaveys.
    Ah who am I kidding...I just love Peaveys. There, I said it, I'm out. No turning back now.
  15. bo
    bo Friend of Leo's
    Arlington, VA
    Nice. Btw, IIRC Peavey neck plates are a shorter rectangle than Fender neck plates. This seems to allow for some flexability in the neck that the longer Fender plates didn't (or maybe it's an issue with how Peavey builds necks). You can either search for a Peavey plate and drill the neck for it, or fill/drill the body for a Fender plate depending on your preference. I like my necks fairly rigid. Can't wait to see the final result!
  16. jackkavanagh
    12
    Jan 28, 2014
    England
    Think I'll probably fill and drill the body and fit it for a fender neck plate. Also, the body is routed for the neck angle adjuster, is it a good idea to get rid of this if I decide to use a fender neck plate instead?
  17. loopy reed
    Nov 14, 2007
    Nashville, TN
    I wouldn't say that's necessary. Does it still have the adjuster in it? If it were me I'd leave it. I like them.
  18. jackkavanagh
    12
    Jan 28, 2014
    England
    Yeah it's still in there, can't figure out how to adjust it though. The adjustment screw is too far forward giving it a pretty severe angle. Is it just adjusted from the back with an allen key?
  19. bo
    bo Friend of Leo's
    Arlington, VA
    I'm not sure it would work with a Fender sized plate. It's basically just an adjustable shim.
  20. loopy reed
    Nov 14, 2007
    Nashville, TN
    Yep, that's how it's done. You'll probably need some neck angle, most t-60's I've seen and set up either have or end up with a bit of angle. Of course that depends on how tall your Tele neck is compared to the Peavey.
  21. jackkavanagh
    12
    Jan 28, 2014
    England
    Not done much work on this as I've been out of the house. Lace Finger Burner arrived yesterday but not had chance to do anything with it. Going to build the pickguard this week while waiting for the other electronics to arrive. Loosely assembled some hardware so I could get a shot of what it'll look like.
    The last photo is of the neckplate I have up against the pre drilled holes in the body. Looks like the spacing is only very slightly off. Could make filling and drilling new holes a bit risky. Looks like I might have to build or buy a t series plate.
