Pathfinder 15 - no tremolo woe.
Discussion in 'Amp Tech Center' started by Bri-Sonic, Apr 3, 2013.
  1. Bri-Sonic
    Bri-Sonic Tele-Meister
    Warwick, UK
    Guys,
    I've just picked up a Pathfinder 15 (no reverb) for silly money. It's in lovely condition and sounds great, but the trem doesn't work. A bit of googling and it seems like it might be an opto coupler issue. I've found this on Ebay which seems to be the correct component:
    http://www.ebay.co.uk/itm/251188793466?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
    Question is am I going down the right path here? If I am replacing with the component above is it easy enough to find the original on the circuit board, and do I need to solder it a certain way round?
    Any advice gratefully received. The amp has the potential to be a gem and I want to get the best from it (without screwing it up!)
    Cheers,
    Mark
  2. waparker4
    Philadelphia, PA
    Have you tried cleaning the footswitch jack with contact cleaner? I reckon it could be dirty and cause the amp to think you have always set the tremolo "off" w/ the footswitch.
  3. Commodore 64
    Commodore 64 Friend of Leo's
    Kent, OH
    VTCL5C3 is the Vactrol you want. I can't open your link at work.
  4. Bri-Sonic
    Warwick, UK
    Commodore 64 - the Ebay link is to a VTCL5C3.
    waparker4 - sounds like the footswitch jack may be worth a look. The amp's in lovely condition, but there is a smidge of rust around the jack sockets. Should I just squirt it in or spray a jack and push it in and out?
  5. waparker4
    Philadelphia, PA
    I'd spray a 1/4" plug and push it in and out, but do some searchin' by all means
  6. Commodore 64
    Kent, OH
    I've replaced optocouplers in 4 vox amps now. 2 Cambridge and 2 Pathfinders like yours.
    You don't use the middle lead on the one with 3. Just fold it back and or clip it off.
  7. Bri-Sonic
    Warwick, UK
    Stupid question but how easy a job is it? I'm pretty confident with an iron.
    I'm in two minds whether to do the led mod at the same time.....
  8. TNO
    TNO Friend of Leo's
    NC-USA
    Do the led mod. Then try it with the boost on and the gain set very low.
