Output Transformer question
Discussion in 'Shock Brother's DIY Amps' started by Meteorman, Nov 10, 2017.
  1. Meteorman
    Meteorman Tele-Holic
    679
    Dec 23, 2012
    State College PA
    I'm building a Supro S6424 clone, and am using a ClasssicTone 40-18062 power transformer, which is listed as a 10watt PT. Somehow I ordered the ClassicTone 40-18061 OT, which is listed as their 35watt Valco-style OT. (Pretty sure I meant to order their 10-watt OT 40-18063, but ...).
    So will the 35watt OT perform in this circuit ? Or am I stressing some part of the circuit to drive it?
    Would it eliminate any chance of breakup grit?
    Thanks for any insight.
    /mike
  2. Wyatt
    Wyatt Tele-Holic
    917
    Nov 3, 2004
    It will work, but looking at the tube plots, the 5K primary may give you reduced wattage (vs. 7.5K)... you may have to tweak bias a little.
    But you also what are usually "benefits" of larger iron — bigger, tighter low-end; less compression; etc. However, most of this works against the nature of why these amps are so popular...we want the amp to compress, we don't want the bass to be heavy, etc.
    What's better is subjective. Small iron is part of what gives these amps their nature that made them famous...yet, these are the exact same things -- headroom, compression, low end -- that are the first complaints of people who are more in love of the idea of vintage small amps than the actual amp itself.
    Meteorman, FenderLover and Wally like this.
