OT rating?
Discussion in 'Shock Brother's DIY Amps' started by sds1, Dec 6, 2017.
  1. sds1
    sds1 Tele-Holic
    539
    May 4, 2017
    Orlando, FL, USA
    Hey guys,
    So I goofed on a repair and ended up with the wrong output transformer. Cut the leads and the reseller obviously won't taking it back.
    I might have recourse but I'm not sure -- I'm ramping up for a build I MIGHT be able to use it on. Can you guys please advise?
    The 40W transformer in hand is ClassicTone #40-18105
    http://www.classictone.net/40-18105.html
    And the build I'm working up to will be 2x5881 cathode biased output section with a 430V B+.
    5881 datasheet:
    http://www.tubeampdoctor.com/images/File/DATA SHEET 5881 Tung-Sol.pdf
    What do you guys think? I don't want to push it.
  2. clintj
    clintj Friend of Leo's
    Apr 4, 2015
    Idaho
    I think that'll work just fine. It's a 40W unit suitable for, say, a Vibrolux Reverb which runs 6L6GC tubes. I'd want to draw a load line or two to see whether to run it at specified impedance or intentionally mismatch it higher, though.
    sds1 likes this.
  3. D'tar
    D'tar Tele-Afflicted
    Jan 11, 2013
    WNY
    mmmmmmmmmmm....Vibrolux Reverb:cool:
    Edit... not cathode bias:(
  4. aerhed
    aerhed Tele-Holic
    938
    Dec 24, 2016
    Boulder, WY
    You're gonna run 5881's at 430v?. I like them under 400v.
  5. Phrygian77
    Phrygian77 Tele-Holic
    870
    Apr 30, 2016
    Crawfordville, FL
    If it's cathode biased, the plate voltage won't be 430 VDC.
    aerhed and sds1 like this.
  6. sds1
    sds1 Tele-Holic
    539
    May 4, 2017
    Orlando, FL, USA
    Thanks Clint. Fellas across town at The Amp Guys concur. Was afraid I was going to get stuck with that OT for the Bassman. Worked out lucky for me I guess.
    peteb likes this.
