Join TDPRI Today
original Hywy 1 Tele pups?
Discussion in 'Just Pickups' started by Prefix, Feb 6, 2013.
  1. Prefix
    Prefix Tele-Meister
    388
    Jan 25, 2013
    Toronto
    Anyone know what p/ups should be on an 04 Tele Hywy1?
    { pre-downgrade, i mean upgrade ;p }
    http://www.fender.com/en-CA/support/articles/telecaster-service-diagrams/
    the wrong parts diagram comes up when you click onthe;
    "Highway 1™ Telecaster® 011-8000 08/01/00 Download""
    I have emailed Fender and recieved an automated response indicating that i will get a reply eventually, unless it is a performance related issue.
    thanks!
  2. thebrownmule
    thebrownmule TDPRI Member
    I'm pretty sure most hwy 1's came with tex mex pickups
  3. Prefix
    Prefix Tele-Meister
    388
    Jan 25, 2013
    Toronto
    thnx!
  5. sjtalon
    sjtalon Poster Extraordinaire
    No they have their own deal.
  6. Prefix
    Prefix Tele-Meister
    388
    Jan 25, 2013
    Toronto
    Any clue on specs?
    Wen the neck pup is only on, it sounds like a wet blanket has been draped over my amp
  7. sjtalon
    They called them : Hot Vintage Tele
    Neck should read about 9.7 KΩ
  8. Prefix
    Prefix Tele-Meister
    388
    Jan 25, 2013
    Toronto
    Can I check that while its wired?
    Seems pretty high to have such a muddy sound.
    What would the bridge be at ? 12ish?
  9. sjtalon
    I'm checking if I have anything on the bridge.
    Lift your control plate up, put your sel. switch all the way back ( #1 bridge only) then put your red probe on the switch terminal with the neck wire on it. Should be a white wire.
    Meter on 20X
  10. Prefix
    Prefix Tele-Meister
    388
    Jan 25, 2013
    Toronto
    Thank you kind sir, truly a pleasure.
  11. Mightyaxeman
    Mightyaxeman Tele-Afflicted
    May 12, 2007
    Pennsylvania
    You can. Put a cord in the jack and turn your volume pot all the way up then meter across the tip and ring of the other end of the cord. The reading should be pretty close to what you'd get right at the pickup.
  12. sjtalon
    u betcha.
    I didn't have anything on the Bridge, but I doubt it is as high as 12, most likly 10 ish.
    .02
  13. Prefix
    Prefix Tele-Meister
    388
    Jan 25, 2013
    Toronto
    if i took the cover off of the neck pup, would it be a little brighter??
  14. Prefix
    Prefix Tele-Meister
    388
    Jan 25, 2013
    Toronto
    Anyone?
  15. Colt W. Knight
    Jan 21, 2007
    Tucson, AZ
    Preupgrade had blue/yellow plastic leads, plastic baseplate on the bridge pickup. Wish I had a picture of a set I had laying around. They were kinda harsh sounding.
    Here they are in a pinecaster I built
  16. sjtalon
    Got a neck pic. I remember trying to find a pic of the bridge for my files and all I have is the "upgrade" one. That has blue and yellow leads as well like you mentioned the older ones have. Did the older ones have white string too ?
    pre-upgrade (circa 2004 )
    Neck Fender # 0063081000
    Bridge Fender # 0063082000
  17. sjtalon
    Found that they were the same as those on the Classic Series 60's Tele (MIM), which I have this pic of:
