Join TDPRI Today
One tone pot
Discussion in 'Stratocaster Discussion Forum' started by Twangfan, Jul 10, 2013.
  1. Twangfan
    Twangfan TDPRI Member
    13
    Feb 20, 2013
    So. Wisconsin
    Since I've been a Tele player and just recently got a Strat, I'm having trouble getting used to the volume knob being in my way. I would like to eliminate one of the tone pots and move the volume pot down out of the way. I've read other posts that say practice, practice, practice and you'll get used to it. I don't think that I will get used to it. Has anyone else done this, and was it worth it or should I just stick with the p,p,p advice above? The mod can't be that difficult, and it's not a real expensive Strat to begin with but I really enjoy playing it for the versatility of the sound. Thanks for any info or opinions.
  2. richinva
    richinva Tele-Meister
    359
    Apr 13, 2010
    Rice, VA
    I did it as well. Easy mod, and now I am much more comfortable negotiating the knobs.
    If you don't like it, it's easy to put back.
  3. Forum Sponsor Sponsored posting
  4. lineboat
    lineboat Friend of Leo's
    Aug 6, 2012
    I'm not gonna say don't do it, but I will say keep trying before you change it. I finally got used to mine, and glad I did. If you're out, and pick up another Strat, you'll be used to it, and won't fumble while playing. Just my 2 cents.
  5. supernewt
    supernewt Tele-Meister
    128
    Feb 16, 2009
    Raleigh NC
    In that Strat wiring diagram, the tone now works on the bridge pickup too, yes? That seems a nice configuration.
  6. strateles
    strateles Tele-Holic
    575
    Feb 7, 2013
    Eastern NC
    It does take a while to get used to coming from a tele.
    I actually enjoy the dual tone now, in pos 2 and 4 you can set the tone on either pup a little different to get alot of different tonal shapes
    pos 4 w/ the neck pup low on the tone knob and the middle pup a couple steps brighter is one of my favs on a strat for leads.
  7. NastyMojo
    NastyMojo Tele-Afflicted
    Aug 1, 2012
    TOC,NM
    I've never had a problem adapting to different models. I feel at home on Strats,Teles,Lp's,Danelctro ..ect
  8. kidmo
    kidmo Friend of Leo's
    May 25, 2008
    Funkytown
    Yes, the lead is jumped between the two commons. Someone correct me if I'm wrong, but if you want the bridge with no tone control (as some do) you can move the jumper to just the neck and middle lugs and run a separate jumper from the bridge lug straight to the output jack.
  9. waparker4
    waparker4 Doctor of Teleocity
    Nov 9, 2011
    Philadelphia, PA
    Just this part
    and not this part
  10. J. Hayes
    J. Hayes Friend of Leo's
    May 18, 2005
    Virginia Beach, Va.
    Hey TF.........
    I now have 4 Strats in my collection and have had others in the past. I've always had the (always in the way) top volume knob removed and the volume knob moved to the middle hole with the tone knob on the bottom and working on all three pickups. I had that done the first time in the late sixties at the repair shop at Fender when they were still in Fullerton. They had no problem doing it and didn't give me any flak at all about it, the tech even thought that it was a good idea.............JH in Va.
  11. gtrguru
    gtrguru Friend of Leo's
    Apr 29, 2011
    Detroit Metro
    I switched my strat to 1 volume / 1 tone a couple years ago and never looked back. I had to get rid of the middle knob so my sausage fingers didn't get in the way during volume swells. I followed the SD wiring scheme and had no problems.
  12. Rhythm Thief
    Rhythm Thief Tele-Holic
    731
    May 11, 2013
    Herefordshire UK
    I prefer the master vol and master tone arrangement, but keep the volume in its usual place. You do get used to it over time; I had the same problem as the OP when I first started playing Strats, but now it's not an issue at all.
  13. Wrong-Note Rod
    Wrong-Note Rod Friend of Leo's
    Mar 4, 2009
    atlanta
    Heh, two of my strats dont have a tone knob at all.
    "tone" is over-rated you know.
    anyway, hell yeah, yank off the volume knob closest to the bridge, and re-wire it to suit your needs.
    Personally, the strat that I have that has an actual functioing tone knob, just affects the bridge pickup and not the other two, which is directly opposite what Fender intended. Sort of. More or less. Maybe not. I dont know.
  14. jefrs
    jefrs Doctor of Teleocity
    Nov 20, 2007
    Newbury, England
    I think even Rory's strat only had one tone pot, because the other had stopped working he simply wired the remaining one to do the lot. It certainly worked rather well.
  15. stnmtthw
    stnmtthw Friend of Leo's
    Apr 2, 2012
    New Mexico
    I have all three knobs on mine, but the middle pot is a tone control for all three pickups and the rear pot is a blender for the neck and bridge pups. Works really well for me.
    If the knob is in your way, yeah, yank that sucker out. And I highly recommend wiring the bridge pickup through a tone control. It really opened up a pickup that I never used before the mod. Without a tone control, the bridge pickup on a Strat is usually set somewhere between "icepick to the eardrum" and "banshee shriek", at least to my ears.
  16. Twangfan
    13
    Feb 20, 2013
    So. Wisconsin
    Thanks for all of the replies everyone. Even though I agree with those that say I'll get more used to it in time, it'll always be in my way. I'm going to take it out because I enjoy this guitar too much to let this take away from my fun.
  17. HarveyTBirdman
    HarveyTBirdman Tele-Meister
    188
    May 29, 2013
    Brisbane, Qld.
    It won't take long to get used to it.
    I got a strat 2 1/2 weeks ago, and for the first couple of hours i'd find the volume turning itself down.
    Took a little while, as my usual guitar was a prs copy, and i'd changed the volume to the first tone knob and replaced the volume with a toggle on that one, but after readjusting my aim it doesn't happen anymore.
    My point is if you change it on this guitar, you might find it hard on the next one you play or buy. Just aim your pick between the neck and middle frets and you'll never hit the volume again.
    Another thing i found that aiming there helps with is keeping your wrist off the floating bridge and getting unwanted tremolo sounds, which i found I used to do when resting on my bridge in a modifed super strat.
  18. chris m.
    chris m. Friend of Leo's
    +1 on re-purposing a pot to work as a neck blender. Bridge plus neck is a great sound. And I like a tone knob for all three pickups.
  19. tap4154
    tap4154 Poster Extraordinaire
    Apr 14, 2009
    Southern California
    I've been mainly playing my Jimmie Vaughan Strat again after years of mainly playing Teles, and after a few weeks you get used to the controls again. Several years ago I wired an "expander" circuit in it, with a push-pull pot on the bridge tone control to activate it, so I can get bridge/neck, which is my favorite Tele tone. Middle pup has no tone control on JVs. Just neck and bridge, which is how it should be IMO.
  20. chris m.
    Hey Tap4154, I should have a Jimmy Vaughan Strat arriving in a day or two. I plan on trying the wiring as stock for awhile (although I'll probably put a treble bleed bypass circuit on the volume pot).
    I will probably also ultimately wire the bridge and neck to one tone pot, freeing up the other tone pot to be a neck bleed pot. But if I like the middle pickup straight up with no load, then maybe I won't wire it into the tone pot...although in my experience I don't hear a lot of difference either way when the tone pot is dimed.
