Old German Jazzbox: the dead shall rise again
Discussion in 'Tele Home Depot' started by parkwood, Jun 22, 2018.
  1. parkwood
    parkwood Tele-Meister
    369
    Dec 16, 2010
    Kyiv
    RadioFM74,
    rdwhitti,
    Kriticaster,
    Macrogats,
    Thank you!
    Rob, i really got nothing to impress a skilled pickup builder like you) Sorry
    But here it goes: i've had a Korean p90 in the bin.
    It just looked to me a bit too massive on this guitar. So i cut all what i could around the bobbin, and the pole piece screws on the bottom too.
    I've made two versions of the new housing. First had triangular sides and eventually was rejected. Second one is more simple and imo fits the guitar better.
    The cover is very tight on screws and sides. So I'll just use regular p90 mount to attach the pu to the top, and cover it with the housing.
    These supports were used to glue up the hosing in the first case and bend in the second. I had a negative fittings for the rounded sides somewhere, but they seem to be gone. That's all)
  2. Barncaster
    What position are you envisioning for the pup? It’s pole spacing is probably 50mm which will probably be a better fit for the neck as far as string to pole spacing goes. Chances are it might have too much resistance for the neck position however. PM me if you find this to be correct and want a good P90 neck recipe.
    Also, beautiful job on the rounded P90 pickup mod. That shape is a favorite of mine and always looked so right on Paul Bigsby’s guitars.
    Rob
    Kriticaster and El Tele Lobo like this.
  3. parkwood
    369
    Dec 16, 2010
    Kyiv
    Yes! Bigsby! That's where i might have seen that. Thank you!
    The p90 reads around 8,6k, spacing is 48 mm. I believe it's meant for the neck position originally. But i'm not so limited by individual saddles anyway.
    I'm good with it positioned 20 mm away from fb end. I mean distance to pu cover.
    Thanks
  4. Barncaster
    8.6k is a lot of resistance for a neck pickup. You could probably make it work well and retain clarity with 1Meg pots and a .022mF cap.
  5. parkwood
    369
    Dec 16, 2010
    Kyiv
    ok, Rob,
    when done, i'll take her to my studio and do a clip with a propper setup. We'll see what's your verdict will be. Overall, you're seem to take my build more serious then i do) thank you very much for that)))
    El Tele Lobo and Barncaster like this.
  6. parkwood
    369
    Dec 16, 2010
    Kyiv
    Anyway, i was lacking pickguard and tr cover. And for a long time wanted to mess with the epoxy faux tortoise idea. So here it goes:
    I'm using slow stuff that is recommended for 'jewelry' making, claimed to be fully cured in 24 hours. Tr cover will be Ric-ish. Here is a thin plexiglass template, oversized, sided with tape. Saving some epoxy while it's clear.
    Tinted with the fair amount of glass paint
    pouring
    not much needed
    making shades with brown
  7. Barncaster
    Personally, this guitar is going to end up in a far superior state in comparison to when it originally left the factory. I like your style and you are doing a fantastic job.
    The whole concept of restoration/ rebuild vs new build is really interesting to me.
  8. parkwood
    369
    Dec 16, 2010
    Kyiv
    paint spreads out quickly
    More brown dots on the first dots
    ... and some more
    Makeing swirls with a toothpick
    ... and more brown
  9. parkwood
    369
    Dec 16, 2010
    Kyiv
    Oh, i like recycling idea too) As for the guys who made this guitar originally, i have a privilege of making it just once)
    Kriticaster likes this.
  10. parkwood
    369
    Dec 16, 2010
    Kyiv
    back to epoxy
    adding some of saved clear
    I'm moving it to make it flow
    anyway it'll live own life while curing and gonna spread more naturally
  11. parkwood
    369
    Dec 16, 2010
    Kyiv
    First layer done
    Adding a second one. It's needed to make it level, yet keep the paint, which basically stays on the surface
    Cured. Tape removed
    Truing up, making it thinner Can be done even with the low angle plane
    Then i cut it to final shape and remove plexiglass. It splits easily, and that's why it has to be re-attached with superglue. The smoth side, which was facing plexiglass, now will be on the top. I sanded epoxy and plexi for a better grip.
  12. parkwood
    369
    Dec 16, 2010
    Kyiv
    Considering it'll be lying on black, Not as transparent, as i was hoping. Should have tint the second layer less.
  13. parkwood
    369
    Dec 16, 2010
    Kyiv
    And as approved by Hallo Spencer, Musikwinkel will go on the headstock.
    No free font, as was promised: i've basically stolen Musima logo. Just made letters thiner.
  14. 10orgtr
    10orgtr Tele-Meister
    254
    May 3, 2011
    western PA
    Very nice on the tort.
    Cheers,
    Woody
  15. Barncaster
    Paint the underside of the tort with silver, gold or white and it should wake up the tort pattern even while mounted on a black surface.
  16. hopdybob
    hopdybob Tele-Holic
    750
    May 28, 2008
    netherlands
    craftsmanship and creative all the way, respect!
  17. parkwood
    369
    Dec 16, 2010
    Kyiv
    Thanks,
    woody and hopdybob
    well, that's not exactly what i want) one of previous attempts was made on white plastic. But i'd like it keep it transparent. Thanks
    Here is pg made the same way
    I should get me something above 2000 grt...
  18. coldengray
    coldengray Tele-Meister
    408
    Sep 30, 2009
    Charlotte, NC
    Absolutely love this thread. So impressive.
  19. El Tele Lobo
    El Tele Lobo Friend of Leo's
    Oct 21, 2014
    Agreed! This is a fascinating thread. Reminds me a little bit of restoring an old car with some of the improvising you have to do. Can’t wait to see how everything turns out!
  20. Kriticaster
    Kriticaster Tele-Holic
    531
    Nov 5, 2017
    Crete, Greece
    Wow! Love your work with the pick guard and truss rod cover!
    It never occurred to me that it was even possible to do what you’ve done! Outstanding!!
