oh great tele-meisters, please benefit me with your tele-kinesys (just a question)
Discussion in 'Tele Home Depot' started by mistermikev, Jun 24, 2019.
  1. mistermikev
    mistermikev Tele-Holic
    phoenix
    just wanted to draw on the wealth of tele wisdom here:
    I'm planning on doing a tele, and have approx 6 bodies worth of wood similar to below. Since setup takes more effort than anything else... I figured I might as well do 2: a thinline and a butterscotch blonde.
    so, looking at the wood below... was initially planning it for tele #1 - a thinline. the top would cover the side with the dark streaks. but looking at it... I really like the grain, and am torn about hiding it... perhaps instead making it my #2 tele, which would be a butterscotch blonde? It def hides my join better.
    so, what say you... is it a bad idea to use dark streaks and then do a trans finish? my gut says yes, altho the darker grain might look good. Extra points for teles that have trans finish and dark streaks.
  2. Dacious
    Dacious Poster Extraordinaire
    Godzone
    I'd use that for blonde. The pickguard and control plate will cover the plain bits mostly.
    The grain is great on the top bout.
    Skydog1010 and mistermikev like this.
  3. mistermikev
    phoenix
    that is what I thought about the top bout. it'd be a shame to put that under a top.
  4. Ronkirn
    Jacksonville, FL
    the dark streaks are typically the heart wood from Black Ash... which, as was told a generation and a half ago, the original Swamp Ash .. I actually prefer the look, its not quite as bland as the "virgin" clear stuff...
    r
    mistermikev likes this.
  5. David Barnett
    That blank would've made a nice Strat, with all the drama right where the forearm contour would go.
    Blond, with a dark grain filler, will look killer on that wood.
  6. teletimetx
    teletimetx Poster Extraordinaire
    Houston, TX
    all due respect, OP, but I was under the impression that there was actual sunlight in Arizona - did you wait for the cloudiest dark day to take photos? (JK) I hadda do a little digital revising just to see what was going on - Ima old dude, just about put a permanent squint on...
  7. mistermikev
    phoenix
    thank you sir. very much appreciate your input. was trying to see a few pics on the net of what it might look like, and am wondering if it's just not that common, or if it's just not visible once you have a blonde finish on - as I can't seem to see much for examples.
    thank you sir! there may be a strat coming out of the sm stock at some point... but I'm switched in to "tele mode" for the time being! Not sure any of the other pieces have that lovely upper bout streak... but then I hadn't noticed it until it was planed a bit.
    hehe, this was in my grage and despite having flash on... the hazey lightbulb behind me was just casting enough of a shadow that... well, you see.
    cheers all and thanks again for the advice!
