Nut thickness Matters?
Discussion in 'Tele-Technical' started by mickeyspringer, Sep 20, 2017.
  1. mickeyspringer
    mickeyspringer TDPRI Member
    11
    Apr 25, 2011
    Hollywood
    Does nut thickness (not width) make a difference?
    Is there a tonal, tension, sustain or resonance difference between skinny fender nuts and thicker Gibson nuts?
    Would a Gibson nut on a tele neck give it a steeper break angle at the wound strings and make it more stable and resonant when it comes to open notes?
    i am building a tele shape except every thing but the shape will resemble a 59 lp jr. (Mohogany, wraparound angle bridge, p90)
    scoop neck straight tele style head but just make the nut slot thicker like a Gibson.
  2. Nick Fanis
    Nick Fanis Friend of Leo's Ad Free Member
    Mar 3, 2003
    Athens-GREECE
    No.
  3. blowtorch
    May 2, 2003
    Wisco
  4. KokoTele
    KokoTele Doctor of Teleocity Vendor Member
    albany, ny [not chicago]
    I'm not sure I've ever seen similar enough designs with just that variable to know how to make a comparison. There are so many other differences in the designs of recessed headstocks (like a Fender) and angled headstocks (like a Gibson), that I think this is probably one where you wouldn't notice the difference.
  5. Bob M
    Bob M Tele-Afflicted Silver Supporter
    May 11, 2011
    North of Boston
    No matter how thick the nut is you file the slot on an angle that creates a break point. The physical thickness of the nut is not important. Just more material to remove.
  6. ndeli55
    ndeli55 Tele-Afflicted
    May 12, 2008
    oklahoma
    I've heard thicker nuts can cause string binding which makes some logical sense. Larger contact patch, more friction. Rubbing is racing! Wait, what are we talking about again?
  7. flyingbanana
    flyingbanana Poster Extraordinaire
    No, because you really want the strings to contact only a tiny part of the nut anyway, with some drop off in the back of the nut slot.
  8. 3-Chord-Genius
    3-Chord-Genius Friend of Leo's
    Apr 3, 2015
    Winchester, VA
