NU-X Pedals
Discussion in 'Pedal/Effects Owners Clubs' started by Talacaster, Mar 2, 2013.
  1. Talacaster
    Talacaster TDPRI Member
    33
    Nov 4, 2009
    Essex UK
    Hi All
    I was wondering if anyone has any experience with NU-X pedals, specifically the "Time Force" delay , "Mod Force" multi effects and the "Drive Core" overdrive or any other NU-X pedals for that matter.
  2. Talacaster
    33
    Nov 4, 2009
    Essex UK
    NU-X Time Force Delay pedal
    Hi All
    Ok time to report back on the NU-X (pronounced New - X) Time Force delay pedal.
    This delay pedal is nice enough and does pretty much what I need it to do, it seems to be a clone of either a TC Electronics Nova or an Eventide Time Factor. Comparing the 11 different delay types, to be honest they mostly all sound the same. For example the Analog & Digital delays both sound the same, the Analog delay repeats don't degrade like an old analog delay would. I don't see any point in having a separate "Slapback" type either as all you need to do is adjust the time and repeats for a slapback setting so this particular delay type is pointless in my opinion. I'm not running a stereo rig so I couldn't really test the Pan , Stereo or Ping Pong types (Ping Pang according to the manual LOL). I've never heard a Tube delay so no idea if this is an accurate representation or not. For me there are just too many pointless delay types, they would have been better off with maybe 3 to 6 types that REALLY do sound different from each other than trying to pack in too much pork to make the pedal seem more versitile than it really is.
    That being said it's actually not a bad pedal at all for a Chinese clone, I needed a pedal that would work in a line level series effects loop in my Tech 21 Trademark 60 amp and this pedal does just fine in that respect, it doesn't choke or clip like my Boss DD-3 did. There is a config section where you can set the I/O sensitivity between -20db & +4db , it worked fine in my effects loop on both settings. You can also select between True Bypass and Buffered (FET) beware that the Tail function only works in Buffered mode (which only makes sense if you think about it) but the manual doesn't state that. You can set it to power up in either "Manual mode" which you would use for creating a patch or "Preset mode" which is what you would use to step through your various presets, if it powers up in Manual mode all you have to do to get to preset mode is hold down the On/Off switch for a few seconds and it switches over to preset mode. In Preset mode the display will show in big letters P1 then P2 etc so it's very easy to read. The manual is a good laugh, lot's of engrish....someone really needs to proof read it and correct it.
    The construction is pretty good again for a Chinese clone, the footswitches are particulary nice, the type you see on more expensive pedals (not like the cheapy ones on my Joyo pedals) however I do have concerns about the four pot/controls. The knobs wobble a bit and so I pulled one of the knobs off to have a look, the shafts are not metal, they are some type of Nylon/Plastic and there is a bit of play inside the housing. Only time will tell if this is an issue or not but I'm surprised at this considering the general overall good construction of the pedal (cost cutting measure perhaps?). The input jacks are of good quality (again unlike my Joyo pedals) and the housing, although plastic, seems of very good quality so I don't have any particular worries or concerns there. Again, only time will tell how the pedal holds up to regular gigging but kept safe in a good pedalboard I should think it would be fine. I don't think this is one of those pedals you can just throw in a box after a gig like I've seen some people do with Boss pedals. I don't think it could take that kind of punishment.
    The pedal has 9 presets which you can select as 1-3 , 4-6 etc which is nice because if, like me, you are only using 3 presets you don't want to have to scroll from 3 to 9 to get back to 1. The Tail function is a nice addition (only in Buffered mode remember) and works as expected. I've not played much with the Tap Tempo and only played a little bit with the Loop function so can't comment too much about that but then again I didn't buy the pedal for that anyway. The tweek knob has different functions depending on the delay type, for example on the Analog and Digital types it controls the brightness of the repeats which is nice, on the Tube delay it controls the distortion on the delay repeat. It's pretty quiet and I couldn't detect any noticable noise in the signal chain either in buffered or True bypass mode. One interesting or strange thing is that as you turn the time knob, the delay time does not increment in a linear fashion but in chunks. Ie 40ms doesn't increase to 41 then 42 then 43 etc, it moves up in strange increments (40 , 62.93 , 78.94 , 87.18 , 95.43 etc..) so if you need an exact ms time you may find that difficult. Using a BOSS DD-3 for example you wouldn't be able to dial in an exact ms time either so it's not really an issue just an observation worth mentioning , it could be that all delay pedals increment in this way?.
    For me it does what I need it to do, I only need 3 presets, a Slapback, Medium delay around 450ms 2 repeats low in the mix & Long delay around 600ms 3 repeats higher in the mix and this pedal does that just fine, it's better than having 3 separate pedals and works just fine on a 9 volt PSU , I don't know if it requires a regulated supply or not , I tried it with a cheapy unregulated and regulated switch mode supply and it worked fine with both so that would suggest that it doesn't require regulated.
    At basically 1/3 the price of a TC or Eventide don't expect it to be of that ilk but for £75.00 I would say it delivers quite a bit for the price and at the moment I'm happy with it, it stays on the pedalboard. I gigged with it the other night and it did the job....I bought mine from www.djmmusic.com , they seemed to have the best price at the time in the UK.
    valvestate likes this.
  3. Talacaster
    33
    Nov 4, 2009
    Essex UK
    Just wanted to update anyone interested in this pedal that the current draw is 190mA.
  4. A.B.Negative
    A.B.Negative Friend of Leo's
    Aug 26, 2008
    Scotland
    The switch on my Nux Mod Core died in less than a month.
  5. denisk
    denisk TDPRI Member
    30
    Feb 25, 2013
    Croatia
    I am really happy with my time core. Now I can finally run two amps in stereo :) works great.
  6. henram36
    henram36 Tele-Meister
    145
    Sep 12, 2013
    Seattle
    I have both the Time Core and Mod Core. I do like all the features Nux packs into a single stomp box, but like Talacaster said, there's not a lot of difference between the delay types in the Time Core. I can here the "harder" repeats of the digital as compared to the "analog" setting. I don't here a bunch of difference between the "tape" and "analog" settings though. The Tape might be a little darker. The 40 second loop/hold and tap tempo are nice features though.
    On the Mod core, my first pedal failed (input I think), my second one is going strong. I like the vibrato, chorus and tremelo in that order. They're nothing special, but again, great to have on a single pedal. I don't care for the phaser, u-vibe or flanger. The rotary is kinda cool, but I don't use it much as it's fairly close to what the chorus does (on this pedal) and the chorus has more adjustments. I do like the "tweak" feature which allows you to shape the sound a little more. It's sort of like a "mix" setting I suppose.
    If you get one of these pedals and use a cheaper patch cable (cheap $2 Hosa, for instance) you'll want to put an o-ring or something on the male end to keep it from messing up the weak inputs on these pedals. I know from experience that bad things happen when you shove a cable into one of these inputs. They just aren't well built. Similar experience with the Biyang pedals.
    Bottom line: I don't think I'd buy either again if they decided to go out on me.
  7. russtyler101
    russtyler101 NEW MEMBER!
    Hi all, I found this thread through a Google search. : )
    I'm trying to find out if the NUX Time Force is right for me. I understand that this pedal is from China and essentially a budget product but at first glance it seems like it could be for me.
    I use a lot of delay and as I am getting busier with my band I need a pedal that can store custom settings with different tempos. Does anyone know if the Time Force will store different tempos in the 9 different available 'slots'. I've also been looking at the BOSS DD-20 and Vox Delay Lab but the price difference is HUGE!
    Any guidance would be appreciated!
  8. Talacaster
    33
    Nov 4, 2009
    Essex UK
    Russtyler101
    Yes it stores different tempos, types, feedback etc for example I have 3 presets
    1: Slapback (around 125ms I think)1 repeat
    2: mid length repeat around 400ms analog, 2 repeats mix low
    3: long delay 3 repeats around 500 ms digital higher in the mix
    so you can preset any combination you like. I have to say this pedal is power hungry, needs around 180mA of power and at the moment it's kind of noisy (digital whine in the background) which could be because I'm using a Diago switched mode psu to power it. I tried daisy chaining it with other pedals on 1 psu (either linear or switched mode) but it was way too noisy so at the moment I'm daisy chaining all the other pedals off one linear psu and the Timeforce is powered alone by the Diago switched mode psu. I need to try powering it with a regulated linear psu alone to see if that eliminates the digital whine.
    All in all it's ok but it's not great, too much chaff in this pedal. They really should have made it do just a few things really well and less power hungry in my opinion. I'm contemplating getting something else but at the moment it's ok.
  9. Donnerdeal
    Donnerdeal TDPRI Member Vendor Member
    35
    Jul 8, 2013
    Guangzhou
    Nux Mod Core
    Nux Mod Core is the all-in-one box that includes 8 types of modulation effect that the players have wanted.
    Chorus, flanger, phaser, tremolo, pan, rotary, u-vibe and vibrato.
    Each model can be change from mode normal to deluxe.
    True Bypass.
    Agitator likes this.
  10. Talacaster
    33
    Nov 4, 2009
    Essex UK
    Well more problems with this NUX Time Force....goodness me!
    1. Tap tempo ONLY works when in manual mode, it doesn't work when you are in preset mode....Bummer...the manual has no mention of how to use the tap tempo so I had to spend ages working it out.
    2. Tap tempo plays back the WRONG tempo, you tap in a tempo and it plays back about 10% or more faster , although the LED is in time with the tempo you tapped in, the play back tempo is NOT, so although it works it DOESN'T work if you know what I mean..... it's useless.
    3. If you are in manual mode (so that you can use the "Useless" tap tempo function) and set the parameters as you want then engage the "Useless" tap tempo, when you stop the tap tempo you do not revert back to your original parameters. The pedals remains at the tap tempo speed....UGH!!!! UTTERLY USELESS!!!
    The more I use this pedal the more I realise it's trying to be all things to all people and failing. NUX has tried to pack way too much into one pedal and expect it to work, don't get me wrong....some stuff does work ok. For example you can preset up to 9 different programs and that does work but I find that more often than not I want to manually set the parameters depending on the room etc so having presets, although sounds like a good idea on paper, for me just doesn't really work so well in practice.
    If NUX had concentrated on doing fewer things better instead of too many things half assed, this would have been a good pedal. That's probably why the price has dropped around 30% from around £75 to £45 -£50
    In my experience if the device has been designed in the USA or EU but built in China it generally makes sense, is intuitive to use and more to the point works but if it's designed in China and built in China then these type of issues arise. Chinese designed stuff is always just awkward to use, at least for my western mind anyway.
    Also trying to get any useful information from NUX is impossible unlike companies such as Tech 21, Electro Harmonix (USA) or T-Rex (Denmark) who are very quick to reply with useful information.
  11. elmoscafeo
    elmoscafeo Tele-Afflicted
    Jun 29, 2012
    Chicago Suburbs
    I posted this in another thread and want to get opinions from the folks in this one, also.
    Now that some folks have had a chance to play with their Nux Mod Core pedals, has anyone owned one over 6 months and still use it?
    I've found some reviews that make it seem like it's the greatest things since a pocket on a shirt with a few reviews talking about a bad switch or a bad input jack, but there seems to be no follow up reviews or opinions given.
    I'm itching to buy one but I still have a basement full of old junk that I've acquired over the years and don't really want to add more junk to it.
  12. henram36
    145
    Sep 12, 2013
    Seattle
    If you can find one for about $30 or less in good operational condition go for it. I had one for about 6 months, but was only using the chorus setting anyways. Now I just use the mod settings on my dd-20. Sold my mod-core for $30, fully functioning.
  13. elmoscafeo
    Jun 29, 2012
    Chicago Suburbs
    Hmmm....I think that pretty much sums it up. You sold yours after 6 months, which seems to be the average timespan before people give up on them.
    The price makes them attractive but, a ketchup sandwich is cheap also.
  14. Talacaster
    33
    Nov 4, 2009
    Essex UK
    NU-X Junk Poo Poo
    I wouldn't bother with NU-X again, my advice is don't waste your money, you will only sell it later. They pack WAY too much into one pedal and don't do any of it very well....you just can't be all things to all people. They have come way down in price probably because of all the bad reviews they get, I bought my Time Core for £75 and sold it for £38 a year later.
    I'm not bashing Chinese gear at all because I bought a Biyang AD-10 delay and it's great but then again it's only concentrating on being a simple delay unit but it comes through with flying colours. I have a Biyang CH-10 chorus on the way as well because of the quality of the AD-10.
    So it's your money but I won't buy NU-X again......
  15. Anode100
    Anode100 Friend of Leo's
    May 9, 2014
    Behind my beard.
    I've been using the Mod Core for a year or so - and love it.
    £30 got me chorus, phase, flange, tremolo and rotary effects.
    You *do* get what you pay for, and if the switch craps out, I'll simply put a new one in.
  16. boyatheart
    boyatheart TDPRI Member
    59
    Sep 9, 2013
    Phuket
    Are you sure the pedal is not set to a sub-division other than straight 4/4 time when you say the tap tempo is wrong? The tap LED will show you the tempo you tapped, but the repeats will follow whatever the sub-division is set to, so if it is set to dotted eighths for example then it will sound wrong if you are expecting quarter notes.
    By the way, I don't have this pedal currently. I'm thinking about getting one, but the comments about current draw concern me. I use a pedaltrain volto, so I wonder if that will be any good powering this pedal.
    Anyone used a Volto with the Time Force?
    Was it noisy or did it drain the Volto before the end of a gig?
    I only have 3 other analog (low current draw) pedals on my small board.
    Cheers.
  17. denisk
    denisk TDPRI Member
    30
    Feb 25, 2013
    Croatia
    I have a time core for almost a year now and I never had any problems with it.
    In fact I bought another nux box, this time a loop core. I just upgraded the firmware on it :)
    Input jacks on both pedals are fine, all my cables go all the way in without any problems. The switch on time core is still like the first day I bought it.
  18. himay
    himay TDPRI Member
    8
    Oct 9, 2014
    New England
    Just got my loop core and loving it, but how do you get it into firmware upgrade mode? I followed the directions of course. Any other tips appreciated. I must be missing something obvious.
  19. denisk
    denisk TDPRI Member
    30
    Feb 25, 2013
    Croatia
    It took me some time :)
    As far as I remember, i pressed and hold save+stop+footswitch buttons and then powered the pedal on by plugging the cable on 'OUT L'
  20. himay
    himay TDPRI Member
    8
    Oct 9, 2014
    New England
    Ok, I got it to update to version 2.3. So far it's a great tool for practicing on simple chord loops. Just scratching the surface. Looks like a winner.
