Nu-tube valve replacement?
Discussion in 'Amp Central Station' started by Fenderflame, Jun 29, 2018.
  1. Fenderflame
    Fenderflame Tele-Holic
    590
    Aug 2, 2013
    Mid Sussex, UK
    Just a thought, as Korg are busy 'nu-tubing' everything, is it possible to make a Nutube loaded replacement for a traditional valve? Could you make a nutube with EL-34, EL-84 or 12-AX7 pins that would plug into regular valve sockets?
    If it could be done then the increased life-span would justify a cost uplift (kind of like what happened with domestic lamps - an SES Led directly replaces older SES lamps).
    Any thoughts?
    losrogers and Guitandanza like this.
  2. cincyguitarplay
    cincyguitarplay TDPRI Member
    80
    Mar 7, 2008
    ohio
    I wonder why they never called it "NuValve"....:)
    AxemanVR likes this.
  3. ponce
    ponce Tele-Meister
    433
    Dec 21, 2011
    Croatia
    I just saw an advertisement on that product on YouValve the other day.
  4. warrent
    warrent Tele-Afflicted Silver Supporter
    Sep 15, 2009
    toronto
    I doubt it.
    Here are some videos:
  5. warrent
    Sep 15, 2009
    toronto
  6. luckett
    luckett Friend of Leo's
    Jun 14, 2011
    I wonder if that would appease the "It's not a tube!" zealots?
    It's not a power amp valve and it's not a substitute for traditional valves. The circuit would need to be designed around the nutubes. It runs off of a much lower voltage and than something like a 12AX7.
  7. Guitandanza
    Guitandanza Tele-Meister
    220
    May 31, 2015
    Connecticut
    I’m not crazy about their sound compared to say and Orange, or some such, SS amp. I never hear anybody swooning over the tone.
    Silverface likes this.
  8. Silverface
    Mar 2, 2003
    Lawndale CA
    "NuValve" would be British wording.
    This is just another "not a tube" being marketed as "sounding like a tube" that doesn't.
    Next.
    OneHenry likes this.
  9. gusfinley
    gusfinley Tele-Meister
    167
    Jun 11, 2014
    SLC, UT
    In short, No.
    The NuTube is a preamp tube and not a power tube. If you made a drop-in Power tube replacement with it, you would need a power amp inside the replacement tube as well.
    It also is more expensive that a normal tube ($50USD on ebay for one) so it is not economical.
    It has less gain than the 12AX7 so you'd need to add some solid state amps in the replacement to achieve the same levels.
    It also operates at much lower voltages, so you would need to add voltage conversion to the replacement.
    I think they are a bit larger than a 9 pin miniature tube as well....
  10. Knowcaster
    Knowcaster Tele-Meister
    470
    Jun 30, 2007
    Pittsburgh, PA
    Would you be using NOS or new production NuTubes?:lol:
  11. Pointmonger
    Pointmonger Tele-Holic
    800
    Aug 29, 2009
    Austin, Texas
    Nu Old Stock?
  12. OneHenry
    OneHenry Tele-Holic
    599
    Apr 16, 2018
    North carolina
    I have no idea what a "nutube" is, but understand what you are trying to acheive, and there are solid state replacements for a limited number of vacuum tube types. I wouldn't be surprised to see a solid state replacement for a 12AX7. A solid state replacement for a power tube would be interesting, but I doubt that it would be a tube shaped plug-in deviccepdevice. It would require a power supply to convert the tube's B+ supply to power the solid state devices, enough solid state devices to handle the power requiremnts, and it would require enough heat sink area to keep the solid state devices cool.
  13. OneHenry
    OneHenry Tele-Holic
    599
    Apr 16, 2018
    North carolina
    I looked at an article on nu-tubes, they are tubes, although they are weird tumor infested tubes.
  14. BigDaddyLH
    You call that a tube? Now this is a tube!
  15. Ringo
    Ringo Poster Extraordinaire
    Mar 16, 2003
    Memphis TN
    I've never seen or heard of the KT120 or KT150 , what were they used for ?
    How about this one, 5948A, don't know what it is used for but it's HUGE
  16. BigDaddyLH
    Hah! The KT120 and 150 are for crazy hifi guys. In a (hypothetical) guitar amp I think a pair of KT150 could be pushed to nearly 300W.
    Jakedog likes this.
  17. DougM
    DougM Tele-Afflicted
    Jul 5, 2017
    Honolulu, HI
    There seems to be many here who are ill-informed. The Vox MV50 AC sounds like a real Vox to all who work at the guitar shop that I worked at until recently, and many of them are devout tone (and tube) snobs. And that large tube is tiny compared to some of the broadcast (transmitter) tubes used for TV and radio.
  18. radiocaster
    radiocaster Friend of Leo's
    Aug 18, 2015
    europe
    There have been a bunch of those for the preamp, Jet City made some and so did AMT, and also at least one other company or two, some from the early 2000s or 1990s. I think maybe some were also made for the power amp, although I don't remember that well. Some were really expensive, I do remember that.
