NPD: Mission Engineering VM-1 Pedal, but...
Discussion in 'The Stomp Box' started by littlebadboy, May 24, 2019.
  1. littlebadboy
    littlebadboy Tele-Afflicted
    Midwest, USA
    A Mission Engineering VM-1 Volume Pedal was offered on Facebook for $55. We agreed on $50, met with the guy, had a little chat, and parted.
    It feels and weighs like a tank! I like the feel, I like the sweep, but... there seems to be a little but not so audible sound at full heel zero position. Is this how it is?
    Chain was guitar> VM-1 Vol Pedak> Boss GT-100> Headrush FRFR
  2. 4pickupguy
    4pickupguy Poster Extraordinaire
    Fort Worth, Texas
    Pop the cover off the bottom. You’ll see a rack and pinion arrangement. remove the screw holding the little white plastic loop that is the rack spring. Disengage the rack (straight gear) from the pinion (round volume pot gear. Turn the volume pot to the full off position. With the pedal treadle in the full off position re-engage the rack to the pinion. Replace the rack spring loop. Reinstall the cover. I hope this does it for you. I have to do this every now and then on the Mission exp pedal...
  3. littlebadboy
    Midwest, USA
    Thanks so much! I will follow your instructions when I get the time.
    4pickupguy likes this.
